Question about Microsoft Xbox 360 Console
Screen resolution We can't read much of the print on the screen with our new 360. We have it hooked up to a conventional 26" screen Zenith and in most games, the fonts are near impossible to read. Is this common? is there a tweak?
  • 29 Answers
From the Console Settings screen in the System area of the Xbox Dashboard, you can configure the video output of your Xbox 360 console.
Change your display output settings from this screen. Display settings include screen resolution and screen dimension (or aspect ratio, either standard or widescreen).
In some cases you can select an "Optimal Resolution" button, which appears only when Xbox supports the native resolution of the TV or monitor and automatically applies the best setting but that might not work with your tv.
If you are using VGA you must choose from among the following output resolutions: 640 x 480, 848 x 480, 1204 x 720, 1280 x 720, 1280 x 768, 1280 x 1024, 1360 x 768, and 1920 x 1080.  Much like a PC you would want to select a lower resolution (640X480).  That will make your fonts larger.
Screen Format: The default setting is Normal (a standard 4:3 aspect ratio); select Widescreen to change the output aspect ratio to 16:9 if you have a widescreen TV or monitor.  You should select normal and not widescreen for a standard tv.
Hope this helps,
Bob
Posted on Jan 12, 2008
I switch my monitor from a 17 inch to 26 inch but on the new monitor its still at the 17 inch instead of the 26 inch
Change your video resolution to match the new monitor. Right click in a blank area on your desktop go to properties and change your resolution (in XP). In Vista or Windows 7, after right clicking on your desktop, choose Screen Resolution (about the 3rd one up from the bottom of choices).
Oct 17, 2010 | HP Hewlett Packard Pavilion Slimline...
No picture or sound with brand new xbox friend's xboxs worked ok
Look like ur Xbox 360 AV RCA cables is not making contact to the input board very well.Take some rubing achahol cleans the all those input holes,take the RCA AV connections make couples twises to the red,yellow and white,will help.Make contact with ur input board it should work.
Apr 28, 2010 | Zenith SY2551S TV
Proscan 32'' VGA port; TV says not supported on VGA input
Sounds like your resolution on your computer is set too high for your tv to accept. Try putting your computer resolution down to 1024x768 or lower and see if that works.
Jul 18, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
VGA connection just reads "no signal" Brand new TV and VGA cable.
i have a 26" insignia lcd tv that i use as a montor uou musr set the screen resolution on your computer to 1024x768. if you use a higher resolution it will say no signal.so use your montor to set the resolution to 1024x768 then hook it to the vga and it should work. bob griggs
Jun 15, 2009 | Insignia LCDTV26 26 in. Television
Im trying to hook up the computer to my flat screen and Im preaty cofussed. I plug it the Rgb)pc plug when turn computer on the tv shows no programable..What do i do?
To display a computer on a flat panel you need to match up the resolutions. go into the computer set up and make the display 720p or 1080p depending on what your tv is (the computer will read 1080x1900 and probably not say progressive unless you are using a aftermarket program instead of window). I do however recomend NOT using a plasma as a computer monitor as they WILL burn in. Even on brand new models the only brand I have found that has truely made it hard to burn in the TV is panasonic.
Mar 24, 2009 | Zenith P50W28B 50 in. Plasma Television
HD channels not working properly
you should have an aspect button, but go into your setting or options screen and adjust the resolution or aspect
Dec 06, 2008 | Protron PLTV-26 26 in. HD-Ready LCD...
I see two screens on my desktop.
You are using a screen resolution that is not supported by your monitor. Start the computer in safe mode and open display properties. What ever resolution and color depth is (usually 640x480 and 16 colors), click OK button. Restart the computer. Go to display properties and increase the color depth to the maximum value. Set the resolution to 800x600. Restart the machine. Do you see double screens? No? Great! Now try increasing the resolution to the next level. (1024x768). When you click 'apply' you will be give 15 seconds to say it is OK. So if you see double screens, do not click anything. Display will revert to 800x600 resolution (and you will see only a single screen!)
Sep 21, 2008 | ASTVision 5B 15 in.CRT Conventional...
PROTRON 26" LCD TV
There should be two seperate component ports, both do different types of signals (i/p). Try the other port and it should work.
Jan 03, 2008 | Protron PLTV-26 26 in. HD-Ready LCD...
Syncmaster 245bw monitor resolution screen and resolution issues
These two devices are not compatible, you may need to read the information on this LCD MONITOR to see if the resolutions are compatible, this often times happen when monitors are purchased!
Nov 25, 2007 | Samsung SyncMaster 245BW Monitor
Cant get higher resolution
read the manual on the tv and see if it is capable of all the resolutions
May 25, 2007 | Protron PLTV-32 Television
Microsoft Xbox 360 Console Logo
175 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
