Question about Frigidaire GSTF1670A Front Load Washer
Frigidaire FWT647GHS0 Front Load
I've had my washing machine for several years and about after one year it starting making a really loud noise during the spin cycle. This has continued to get worse overtime. Now when I try to rotate the drum by hand it rotates about halfway then sticks and won't move. Its almost like something has gotten past the seal and is on the outside of the inner drum. Is this possible? If so how do I take out the inner tub to check?
  • 2 more comments
  • jhsoto Jan 12, 2008
    Ok, I changed the belt which was part of the problem but now the belt slips against the tub. Is the pulley bad? I'm wondering if it is warped. I don't want to spend alot of money replacing parts.
  • ronanronan Oct 04, 2008
    I have the same problem. Drum bearings clearly shot since I can feel the play when I take off the felt. Was about to spend $200 on the parts until I saw the post that this is a liefetime warranty part. Have you managed to get the repair done under warranty?
    Ronan
    Canada
  • wannagowash Feb 05, 2009
    i believe i have a similar washer. it has started to make odd noises and is not going into the very fast final spin leaving clothes very wet. i thought it sounded like a bearings thing. i took off the back and found that the belt is rubbing against the plastic tub. it has worn a groove into the plastic. i will look closer at the bearings to see if that might also be a problem but i can't get the belt to stay centered.
  • Anonymous Mar 28, 2014
    also some loud noises during spin cycle
  • 156 Answers
You have a bad rear bearing in the rear housing the rear housing is a warrenty part for life on the part but there is parts that should be replaced at the same time expereance guy can do it in about 2 3 hours if not chould be a long hard prosses
Posted on Mar 03, 2008
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
The drum is loose when the washing machine is not in use. When it's in use it makes a loud whirring noise like a train going through my house. This happens on an empty load as well. The machine is a front...
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Aug 29, 2010 | Frigidaire GLTF1670A Front Load Washer
LG washer - loud noises & brown spots on clothes.
The drum bearing has perished this wild cause the noise and the brown spots on your clothes is probably the grease from the bearing
May 05, 2017 | LG WM2077CW Laundry XL Front Load...
Front load washer ~ 1 year old started making noise during the draining cycle
Access the drain pump and clean out whatever is in there. Front load machines need the drain pump cleaned on a regular basis.
Aug 18, 2009 | Frigidaire Washing Machines
Loud banging noise during final high speed spin
I have the HE3T which is 6 yo. Last week it started making a loud banging noise in the spin cycle. I had a repairman come out. He said it is the drum bearings. He said that it is a problem with these machines and to call Sears. He said that the drum and bearing is one assembly and that Sears should cover it.
I called today and Sears todl me that I have to pay for a Sears technician to come out a determine if it is indeed the problem. If so, it will be covered under the lifetime warranty on the drum. I have to pay for the service call $75.00 and if it is the problem, I will be reimbursed. Cross my fingers!
May 21, 2009 | Frigidaire ATF6000ES Front Load Washer
Looks like the drum has droped
You will need to get the bearings replaced. Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Sep 18, 2008 | Frigidaire ATF6000ES Front Load Washer
Drum makes loud noise when spinning
HI thanks for the question. Frigidaire has a life time warranty. on that part .call them. thanks the appliance doc. please rate my answer. thanks.
Apr 29, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire top-load washer Loud noise during spin
its either the upper spin bearing or lower spin bearing. the upper can be replaced by itself but the lower requires the transmission the be replaced
Nov 20, 2007 | Frigidaire FWS833A Top Load Washer
Noise during spin cycles
GE WPXH214ACC Washer drum makes loud noise when spinning sometimes. We've had it since 2005 & never had this happen before. Washer is level, must stop & redistribute clothes to correct. Just started happening now.
Oct 12, 2007 | Washing Machines
Frigidaire GSTF1670A Front Load Washer Logo
935 people viewed this question
Top Frigidaire Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Jason Harris
Jason Harris
Sal De
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
