Question about Kenmore 43142 Front Load Washer
Kenmore 22422 not draining or spining
Its filled with water and will wash but will not drain or spin
If it is same as in photo (Frigidaire built) your drain pump is probably blocked/jammed. You have small children?? Kids socks seem to find their way to the pump often.....
Posted on Dec 26, 2007
Not draining and spining like it use to
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
Mar 27, 2011 | Kenmore 22422 Top Load Washer
My Kenmore washer somtimes won't go threw spin cycle
kenmore washers have a 2min. drain before it spines if leting it drain for 2min does not work u proberly need a new lid switch. haundi24
Jul 03, 2009 | Kenmore 22422 Top Load Washer
Will not fill with water goes right down the drain,works sometimes
Your drain line is too low or there is a air gap blockage.
Remove the drain line from the drain and hold it up high while filling with water and see if it fills and stops.
If so, correct the drain line problem.The drain hose should be 36 inches from the floor.
Apr 12, 2009 | Kenmore 22422 Top Load Washer
Won't spin or drain
Check to make sure your lid switch is working.
Nov 17, 2008 | Kenmore 22422 Top Load Washer
Kenmore 22622100
Check your drain hose an make sure it is not touching water. If it is hard to tell fill it and put it in spin. Then pull the hose out until you hear the water.Then zip tied the hose so it will not move.
Aug 03, 2008 | Kenmore 22422 Top Load Washer
Kenmore Elite Washing Machine will not start washing
turn it to drain spin if it works there change the pressure switch
Jun 02, 2008 | Kenmore 22422 Top Load Washer
Misti, usually no spin, no drain is a broken lid switch. part #3949238. See if the switch is busted off from the screws. Catriver
Dec 26, 2007 | Kenmore 22422 Top Load Washer
Kenmore 43142 Front Load Washer Logo
63 people viewed this question
Sal De
 Brian Main
Brian Main
