Question about Belkin (F5D5231V4-SN-PD) Router (F5D5231V4SNPD)
Vista and the internet
My Vista pc used to work hard connected to my belkin router. It stopped in November. The OS gets the download, Norton gets its updates but no web browsing. I need help
  • 556 Answers
SOURCE: wireless router
I may be confused but this router model number does not seem to be wireless enabled are you sure it is correct F5D5231-4?
secondly for general wireless security see
Posted on Dec 06, 2007
SOURCE: Belkin Wireless N router/Embarq 660 modem/No internet
Posted on Jun 12, 2009
  • 58 Answers
SOURCE: Cannot access router's web based advanced user interface
The password on most Belkins is left blank, and the default IP address is
To reset the router to default,
•Unplug all LAN cables from the router.
•Unplug the router power cord connector from the back of the device.
•Using a paper clip or something similar that will fit into the reset hole, press continue to hold the reset button, then carefully reinsert the power cord, making sure not to release the reset button in the process.
•Continue to hold the reset button in for at least 15 seconds after inserting the power cord, then release it. After about 10-25 seconds the router will boot and it will be set back to the original factory default settings.
Posted on Sep 05, 2009
  • 32281 Answers
SOURCE: Belkin Nimo wireless router internet drop outs
There are a few things that can cause you to lose wireless connection with your wireless router.
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from walls and if possible locate the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? Ie. change the default password, setup encryption use WAP2 or WAP, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, ard welders, washing machines etc. If so the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply) .
4. Check the channels of the wireless routers and access points in your area and and change the broadcast channel on your wireless router to an unused channel or one that has the weakest signal strength. This will minimize the interference with your wireless router from the wireless routers and access points in your area.
Posted on Sep 29, 2009
  • 70 Answers
SOURCE: I want to secure my Belkin 'n' wireless router . I
connect any one of the computers to the router with a ethernet cable. open internet explorer, clear out the address bar on the top, and type when u hit enter, u'll get a router set up utility. in this page u'll have an option -security- below "wireless". when u click security, it'll ask for a password, leave it blank and hit submit. on the next window, choose the option WPA/WP2, then u'll have some more options, look for PASSWORD(PSK).. put in a password which should be 8 to 63 characters long, its case sensitive. click on apply changes.
Posted on Jan 10, 2010
Testimonial: "Thanks, this really helped and was step by step. "
  • 59 Answers
SOURCE: How to get Belkin wireless router to connect
choose the "connect automatically when network is in range" option from control panel > network and sharing center > Manage wireless network > right-click the wifi network click properties to get there. Also make sure your desired network is at the top of the list so it is preferred over others.
Posted on Jun 09, 2010
0 characters
1 Points
My pc doesnt reconize the belkin easy tranfer cable?
you have to have xp or vista to use the cable,next you need the disc that came with it,next you need to follow these instructions to a t,
25765837-ob2lulsg2cxkr1k21bthn3kl-2-0.png if you dont have the disc,then d/l it here,
  • Download OS compatibility: Windows XP Service Pack 2 32 bit, Windows Vista Service Pack 1 32 bit; size: 26.1 MB
Multilingual version
  • Download OS compatibility:Windows XP Service Pack 2 32 bit, Windows Vista Service Pack 1 32 bit; size: 395 MB
  • follow instructions
Jun 29, 2015 | Belkin Routers
XP PC connects/Vista PC doesn't/Connectivity issues
On the Vista Computer
Start>Control Panel > Network and internet > Network and Sharing center
On the Left Hand Side Click on Manage Wireless Networks
Remove your network From the List
Start > Connect to> Click on ur Network > Click Connect
Dec 22, 2009 | Belkin F5D7234-4 Router
Make sure your physical connection is correct. From the modem, the ethernet cable should plugged in to the Internet/WAN port of the router. And your computer to port 1. Access the setup page of the router again and Enable the MAC Address Clone setting. Clone the MAC Address of your PC there then power cycle the router and modem. You should be all set.
Apr 15, 2009 | Belkin (F5D8231-4) Wireless Router...
Belkin N1 wireless network not working
It might be an idea to upgrade the firmware which can be downloaded from manufacturers' website
Mar 20, 2009 | Belkin N1 Vision Wireless Router
My Belkin G Wireless Router won't connect to my laptop.
this type of problem can be fixed in simple steps -:
1. first check all connections, check lan driver
2. update belkin firmware,and restart laptop
3. restart belkin router and go and connect the laptop
4. for more information contact belkin Services i hope this will solve your problem..thanks
Mar 17, 2009 | Gateway Belkin F5D7230-4 802.11g Wireless...
Router works with Ubuntu but with locks up with Vista
You need to log on with admin privileges to make changes.
Confirm settings in vista network properties (tcp/ip) are correct.
Feb 18, 2009 | Belkin (F5D7230-4) Router (587009)
Setup asistant will not work with Belkin wireless router & computer
Try the manual method.connect router to pc with ethernet cable
1.logon to
2.Connection type ; PPPOE
3.type in your username@ISp and pass
4.Save settings
5.Configure wireless setting(SSID,Wep)
Configure pc with the same SSID and WEP
uplug the ethernet cable and check if your are able t connect wireless
if you still have issue use this guide
Cheers !!!
Feb 23, 2008 | Belkin (F5D7230-4) Router (587009)
Belkin Wireless Router
Hi Klarn,
Either you have the 5000 wrong, or that router is not compatible with Vista. Here is a list from Belkin,
Good luck
Jan 05, 2008 | Routers
Belkin Router doesn't connect to internet
GUYS, omg this is so damn unbelievable. I've searched EVERYWHERE on the internet until some genius told me that the reason why I couldn't get internet even though I connected to the router was because of the stupid Norton Internet Security Firewall that was still in use after uninstalling. After I downloaded Norton Removal Tool, EVERYTHING was back to normal. I'm NEVER going to use Norton again, I don't care how much they have improved I was using 2008 and it caused me so much trouble. I recommend everyone out there to not use Norton as well. People out there are saying that Norton is a virus itself in that it is VERY hard to uninstall.
Dec 14, 2007 | Belkin (F5D7230-4) Router (587009)
F5d7230-4 router
The driver software that you are installing is probably not for vista
Try to download an updated version for vista
Dec 02, 2007 | Belkin (F5D7230-4) Router (587009)
Belkin (F5D5231V4-SN-PD) Router (F5D5231V4SNPD) Logo
35 people viewed this question
Top Belkin Routers Experts
 C. Dante
C. Dante
steve morris
steve morris
Are you a Belkin Router Expert? Answer questions, earn points and help others
