FixYa.com
Tags:
Faberware 12-55 Cup Coffee Urn
Water heats but stops perculating (by 2 users)
posted by fejjkcnar on Dec 26, 2007
This machine heats up the water real hot but only percs a few times before the red light comes on. We end up with clear hot water, no coffee.
Comment by fejjkcnar, posted on Dec 27, 2007
What's it look like? What if I can't find it? Where can I get one?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by ishaque5, posted on Apr 06, 2008
This is my exact problem. However, I don't understand the solution. Sometimes it works sometimes it doesn't. There is nothing loose on my perculating pump.
Best Solution
posted on May 24, 2008
Thanks for Trying (70)
fizteach
Rank:Apprentice Apprentice
Rating: 70%, 2 votes
Check the spring under the grounds basket on the pump tube. This is supposed to hold the end of the tube down in the heater well. It should compress when the lid is pushed down on the basket and twisted to lock in under the handles.  I have found a good source of parts for Faberware urns and percolators at goodmans.net. The thermostats and heating elements can be easily replaced and the urn returned to original condition. Rich of Colorado
Rating Locked! (?) fejjkcnar has rated this solution as Thanks for Trying
Solution #2
Not Rated (0)
Buffalo12980
Rank:Wiz Wiz
Rating: 84%, 794 votes
check for a "dip tube" that may have come off its tubing between the reservoir and grounds basket.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Coffee and Espresso Makers problems?
instruction manual
How can i obtain an instruction... Answer This...
Kuppersbusch cafe profi machine
Please, help to find solution... Answer This...
coffee maker parts
Durabrand 16 cup coffee maker,... Answer This...
Faberware Coffee Urn 55 cup
The spicket broke (spelling). I... Answer This...
model number
Hi my model number is...fsu255 Answer This...
Repair Service
Find Coffee and Esp. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
