Art cool keeps stopping
My art cool split keeps displaying a "ch" followed by an "s" and the unit is stopping--any idea what this is
  • Anonymous Jan 25, 2008
    its the 25th of january my birthday!! and mine just started doing the same what to do i don't know? checked the manual nothing there! anyone know please email me thanks
  • Jackie Jan 25, 2008
    mine is saying Ch then S it starts fine my airconditioner then just turns off by itself what the?? read all instructions and now checking the net for solutions... not even a year old what do i do?
    Problem Solver:
  • 6 Answers
CH5 is a communication error between the indoor and outdoor unit. The thermistors have nothing to do with this error code. Check the communication wire for continuity, make sure it is shielded and stranded wire.
Posted on Jun 05, 2009
  • 236 Answers
Try to unplug the unit or “off” after 10sec. “on” the circuit breaker and then start the unit.
But if the defect persist then you need a qualified technician. The below error may be the cause of unit failure.
- Out of range thermistor is also can also be the cause of tripping outdoor unit with matching blinking light same as low refrigerant.
- Dirty indoor and outdoor can also be the cause
Remote control units have diagnostic program in the
control, after 3 to 5 minutes of operating if the diagnostic
tools detect abnormal operation, then its shutdown the unit
to protect from damage. Thermistor sensor is one of the
parts that detect the operation of the unit. Out of range
or defective thermistor can shut the operation of the unit.
- If your indoor and outdoor is clean start the unit in cool mode and monitor the outdoor pipes. If your suction pipe is icing or dry then your unit is under charge, but if your suction is cold and sweating then the system is ok and sure that the thermistor sensor is defective.
- Out of range thermistor sensor in both return air and freeze up sensor can cause the tripping “off “ the unit. The resistance of both thermistor is 8 to 10k ohms, so can test by using ohm meter
Posted on Jan 26, 2008
Error code ch 05
Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Feb 03, 2011 | LG Art Cool LA181CNW Split System Air...
Our LG Art cool Airconditioner displays the error code CH 21. The unit turns on BUT after about 5 minutes the unit turns its self off. Please Help
Inverter compressor run current high. Check compressor windings all equal 1 to 4 OhmsCheck to earth 50 MOhm minimum, check run current. If high, winding is weak. Solution: Replace compressor.
Jan 11, 2011 | LG LSC183VMA Split System Air Conditioner
Lg split system ch 46 error? help!!!
Ch-46Outdoor unit suction sensor fault. Disconnect from PCB and measure resistance. 10 kOhm at 10°C and 4 kOhm at 30°C. If OK replace PCB, if not replace sensor
Jan 07, 2011 | LG Art Cool LA181CNW Split System Air...
LG air conditioner 24awn error code message Ch 6 inside fan runs outside unit not working
CH-06 REFERS Indoor unit coil sensor fault. Disconnect from PCB measure resistance. 10 kOhm at 10C and 4 kOhm at 30C. if not replace sensor. THANKS.
Dec 13, 2010 | LG Art Cool LA121HNP Split System Air...
LG Art Cool, 2 splits. Error code CH7
Multi Splits and Multi V = indoor unit is set to run in a different mode from the master indoor unit. Set ALL indoor units to cooling or ALL to heating to clear.
Splits = Compressor Over Current (CT2)
Jul 09, 2010 | LG Art Cool LA121CNP wall/window Air...
LG Art Cool Error Code CA
Compressor discharge sensor fault. Disconnect from PCB measure resistance 237 kOhm at 20°C, 168 kOhm at 30C. Replace sensor.
May 04, 2010 | LG Art Cool LA181CNW Split System Air...
LG dual split CH 46 display.....
We have an LG Split System with a Remote Touch Screen Control Panel. There is a message flashing "CH46". How do we fix this?
Jul 04, 2009 | LG Art Cool LA181CNW Split System Air...
Unit does not operate code CH 46 shows in panel
CH46 indicates that the suction pipe sensor is missing or faulty.
Apr 30, 2009 | LG Art Cool LA181CNW Split System Air...
LG error CH 64
What is the model of the unit?
Apr 07, 2009 | LG Art Cool LA121CNP wall/window Air...
Heating & Cooling Logo
927 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
