Question about D-Link AirPlus DI-524 Wireless Router
Router disconnects I have a problem with my router that is really frustrating.  The router works fine but after exactly 2 hours and 6 minutes it disconnects. everything says its connected to it but it can't obtain the ip address. You have to disconnect the power and plug it back in. It's annoying especially when I'm downloading something and  I'm not home for the whole day or sleeping.
  • iamilya77 Dec 26, 2007
    no that didnt help because i dont know where to find that
  • OhMyOhMy Jan 09, 2008
    I don't know about the exact time, but the same thing happens to me. I can't even access the setup menu for the router, even if I setup the computer with a static ip address, still can't access the router, only by unplugging the router can I get it to work again.
Go into the router menu and check for "automatic disconnect after xx min" and set value to Zero.
Posted on Dec 26, 2007
Jordan
Sounds like your router is too hot. try turning on a fan to blow right on the router. if that doesn't help I suspect a bad router.
Jun 08, 2013 | Linksys Computers & Internet
Netgear router DN2200/wireless problems.
that really shouldn't hurt it unless it included a pretty nasty fall as he tripped over the cord.
are you certain it still has the correct power cord? i've seen people accidently switch the modem power cord and the router power cord and the router tends to not like that.
good luck
Mar 15, 2013 | NetGear DGN2200 Refurbished WirelessN N300...
I installed a beetel 450TC1 ADSL2 Router 2 days back. It works fine on my workstation PC. Using my laptop from another room (5 meters away), after 2-3 minutes usage, surfing stops, on checking says no...
1.Log into router. Using either 192.168.0.1 to 192.168.1.1 in a browser window that is ( internet Explorer or Firefox)
2. Verify wireless router name( on the computer) >>> ( on/off) ( router status window)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address. This set up in the "security tab" in the router. using 192.168.0.1 or 192.168.1.1 to access through a browser.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
8. check for firmware update at the manufacturers site for your model router
9. cell phones, cordless phones, digital TV's, can affect the data signal from a router. Also distance from the router can be a factor. If your router is in a basement place the router to a upper floor and center it in the room.
Oct 09, 2010 | NetGear WGR614 Wireless Router
I just replaced an old router with a new Belkin router.... I have 2 laptops that I use....problem is that it keeps coming up on that the "password" has changed and disconnects...I end up going in and...
Uninstall the belkin Setup and Router Manager software
It is very important to maintain a stable connection
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Sep 13, 2010 | Belkin (F5D5231-4) Router
Strict NAT type on xbox live...eircom is provider, there router
Follow this link and it'll tell you exactly what to do if the router your using is an eicom netopia http://xbox360help.blogspot.com/2007/09/xbox-live-eircom-router-netopia.html
I had the same problem when i started 3 years ago. now i recently bought the new wireless adaptor and have one of the new routers from eircom and after 20 minutes during gameplay it disconnects me from xbox live.it is really startin 2 annoy me now. does anyone know what could be causing this to happen??
Jan 12, 2010 | Netopia 2247NWG-VGx Wireless Router...
My Belkin n1 router disconnects from telstra every 2 hours - exac
This is a known problem with the Belkin N1 Vision Modem Router. The router keeps time by connecting to a Simple Network Time Protocol (SNTP) server every 2 hours. The solution is to go to www.belkin.com and download and install the pre-release firmware which is supposed to fix "A problem where the router could drop some connections on 2-hour intervals" among other things.
Sep 14, 2009 | Belkin N1 Vision Wireless Router
Linksys BEFW11s4 Wireless Router Security Issues
Try changing the router's channel (play around with 1, 6 and 11) and see if it works.
Jun 28, 2009 | Linksys BEFW11S4 802.11b Wireless...
Cisco 1811 router freez
replace your router, got a problem with the board...
Jun 18, 2009 | Cisco 1811 Router
Losing connection from the router
You may have an IP address conflict with another machine. why don't you just plug the router into the computer to see if that solves your problem first. If it doesn't. you should contact your internet carrier. You can also try this: turn everything off, and unplug EVERYTHING for a few minutes. Plug the AC adapters back into the devices FIRST, then into the wall. this will often drain power and solve IP issues.
Jan 02, 2009 | Linksys Wireless-G Broadband Router
Router causing lag after 10-20 min connected.
I know nothing about this type of router. Try pressing the button on the bottom and rebooting your router. Maybe that will help.
Jun 18, 2017 | Zhone 6211-I3-200 Router
D-Link AirPlus DI-524 Wireless Router Logo
449 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
