Question about Intel Motherboard
Harddrive my computer is not turning on properly the fan and the green light comes on but it makes no noise and the only thing that comes up on my screen is no signal input yet everything is connected correctly im unsure of the brand as its is old all it has on it is pc company can you please tell me what the problem is
Does it beep??
try following:
remove all hardware (RAM, Videocard, disconnect all drives and add-on-cards if possible)
if they PC does not beep when you start up you have either a faulty Mainboard or a defective CPU.
if it beeps put in the RAM first.If you hear different beep you know your RAM is ok. then plug in your videocard. if PC does not start you have a faulty videocard --> replace it.
if you see sth on screen you know so far everything is alright. now plug in the other hardware one piece at a time. BUT REMEBER: always shut off the PC while doing that. better: pull the powerplug....
Posted on Dec 26, 2007
Thought it was the western digital harddrive,bought a new harddrive and the problem is the same. The computer when running gets very loud. Now I am wondering if the problem is actually the power supply....
Your P.C. may need cleaning inside, Dust may of gathered in Fans, HeatSink, etc. When you connect things to your P.C. normally extra power is needed from help run the process. Hence why your P.C. gets more noisier and things get hotter needing the fans to cool them. Or your Power Supply Unit (PSU) replacing for more Watts.
Aug 22, 2010 | Dell XPS 200 PC Desktop
Computer makes noise knocking sound near heat sink fan can not turn off computer
it must be the harddrive -back-up all files then run scandisc
Sep 17, 2009 | Computers & Internet
My computer will turn on there is a green flashing light by power socket there is no noise of fans or any computer movement
try to check your power supply it turns on only but the other wire is not working properly coz if your power supply works properly it the fan will run instantly.
Sep 16, 2009 | Office Equipment & Supplies
Screen does not turn on but green light is on.
Green light indicates the monitor is getting power. Nothing coming up on the screen indicates, No Signal.
No signal from the computer. This means the computer itself isn't working.
A bad power supply in the computer can cause this. A bad power supply is the leading cause of desktop computer failure. It is replaceable, and can be done by the owner relatively easy.
You may have a computer tower that the Power light comes on, you hear fan/s spinning, (Including the Power Supply fan), and it sounds like the harddrive is running.
ALL the lights in your computer use less than 1 Watt.
EACH fan uses 2 to 3 Watts.
A harddrive sitting there spinning in an endless loop, consumes about 2 to 3 Watts.
A Processor uses 51 to 125 Watts. Depends on what Processor it is.
A weak Power Supply will have enough power for lights, fans, and that harddrive sitting there spinning.
It won't have enough power to turn on the Processor.
[No processor operating, then the harddrive sits there spinning in an endless loop, because there is no processor to find the boot sector]
For a test, connect your monitor to a know good computer. See if it works.
Now connect that other monitor to your computer.
Sep 05, 2009 | Sampo P7011M (Silver) 17 in. Flat Panel...
What I stated about the green on light and the fan is all that is happening. There is nothing on the screen, I cannot get anywhere. Nothing happens other than the green on button light an the fan. when i...
sounds like your video card or on board video is out....checking the monitor connection on a laptop is one of the first items the system checks for, and if it's out, then you wont get anything, the other problem it has the same tsymtoms your describing is the hard drive is out, and if it is, the only thing that works is the power to the fan, all other intelligence of the puter is not there, if you have another harddrive, exchange them out and see what you get, or ask a friend to use his, you just need to make sure it's the harddrive or the monitor, you'll get an answer oneway or the other, another thing you can do, smell the harddrive and check for even the slightest smell of burt hardware, then smell the internal area of laptop,or the video card, if the smell is there you'll know,it's very distinctive, there's no missin it.......hope this helps
Apr 19, 2009 | Toshiba Satellite A135-S2386 Notebook...
With destop wont turn on
Robert was right make sure your computer is unplug from the power strip. now check the power supply cable to the mother board, then check the power cable to the harddrive, and then the DVD.once you put the power cable back into the computer you should get the power supply fan should come on, and the cpu fan should come on.
Next once you hit the on/off switch and green light should come on.
Jan 23, 2009 | Dell (9228C) 200-Watt Power Supply
Does not mount, Fan not spinning. 500gb D2 quadra
take the drive out and put it in a external case and see if that helps. if not the drive is dead.
Dec 13, 2008 | LaCie d2 Extreme (300793U) 500 GB Hard...
Not making a clicking noise, but actually playing a really wierd sound
The tones in repetition sound could be a defective harddrive. I've had that happen once on an internal harddrive...
May 31, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Dell dimension 5100, power button has turned orange
If under warranty contact Dell? I had this same problem, a new motherboard and fan assembly fixed this problem. Bad capacitors on the motherbard.
Apr 12, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Computer powers off while booting, green light stays on!
1. check the cpu fan is properly working with normal speed..
2. go to bios setup and restore all settings to default.
3. if windows start and problem comes after some time , then it might be virus. so, go for a virus scan.
Oct 23, 2006 | Asrock K7VT4A+ Motherboard
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
