Code 1131 refers to the upstream O2 sensor before the cat converter.(NO heated sensor detected)
code 1116 means the water temp signals are out of range.(Maybe its unplugged?)
The codes for the O2 can also mean a Lean condition which may be caused by a vacuum leak.
Regardless of the electronics you should be able to do a compression test and figure out if the valve timing is off.
Remember to wipe the memory after you change things to see if they helped.
