Question about Vtech IP5850 Answering Machine
Message The letter A is showing up where the number of messages is displayed. When people call, they cant leave a message.
  • 4 more comments
  • Anonymous Jun 19, 2008
    same as above
  • aus--user Jun 29, 2008
    I have the same issue with Ablinking along with CL, The A just started recently and the caller is not able to leave a message.
  • ravenwillow1 Jul 30, 2008
    Can't get messages, A stays on in window.
  • canaanyouths Dec 30, 2008
    It just shows CL blinking all the time. We only have messages that say "Power Failure" in an automated voice and there haven't been any power failures. No one else is able to leave a message now.
  • Anonymous Jan 03, 2009
  • Anonymous Mar 15, 2009
    Callers cannot leave message - tells them "I'm sorry, but the person you called did not activate the voice messaging service". I already put my recording message in - why won't it take???
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Vtech Master
  • 102,366 Answers
You machine is set to "Announce" mode. Follow the instructions on pages 25-26 of this manual to switch to "Answer" mode.
Posted on Jan 15, 2013
In the past few weeks, I have received text messages from unknown email addresses. These messages contain the words from a text message received from a friend a few hours earlier. Within a few minutes,...
Sounds like you have been hacked. You should change your pass word and if you had a question. Change it as well. When you change your password use some capital letters as well as small case letters and put some numbers in as well. do not use common words as hackers can figure them out as well.
Nov 09, 2017 | LG IC LG VX9100/Env2 Models 950 Mah...
My Hitachi air con (heat/cool) unit is PC-P1H is showing the message H.01 05 and it says the word
Switch it all off. Switch on the outside unit then the inside unit and reset the clock and temperature settings
May 17, 2012 | Hitachi Heating & Cooling
Tap the letter or number and display shows the letter or number directly below.
This is due to a miscalibration of the touchscreen. The touchscreen needs to be recalibrated. A procedure can be found here:
http://www.sharc.net/discus/messages/6/77.html?1286154637
- Jim
Feb 26, 2011 | Garmin Nuvi 660 GPS Receiver
Need to record phone numbers on speed dial - have lost the owners manuel - 4 line phone
Storing a Name and Number in Memory
1. Press the STORE button on the handset, ENTER NUMBER is displayed.
2. Use the keypad to enter the phone number (up to 32 digits).
3. Press the SELECT button. The display shows ENTER NAME.
Telephone Operation
17
4. Use the touch-tone pad to enter a name (up to 21 characters). More than one letter is stored in each of the number keys. For example, to enter Bill Smith, press the 2 key twice for the letter B. Press the 4 key 3 times for the letter I. Press the 5 key 3 times for the letter L. Press the 5 key 3 times for the second letter L, and press the 1 key to insert a space between the first and last name. Press the 7 key 4 times for the letter S; press the 6 key once for the letter M; press the 4 key 3 times for the letter I; press the 8 key for the letter T; press the 4 key twice for the letter H.
5. Press the STORE button again to save your selection. ENTER LOCATION is displayed.
6. Enter two digits to enter the location, ranging from 01 to 40. For example, to store the record in location #5, press “0”, “5”. After entering a valid location number, the record will be saved. If the memory location you selected is not empty, OVERWRITE? will show in the display. Press the STORE button again to confirm the current record and overwrite the old one or press the EXIT button to select another location.
7. To enter another name and number in a different memory location, return to step 1 and repeat the process.
Good Luck.
Jan 30, 2010 | RCA 25413RE3 Corded Phone
Problem with entering anti-theft radio code for Honda Fit: The radio screen says: "Enter Code:" I enter the confirmed correct code, but when doing so when the actual code (all numbers) turn into letters or...
when you use the "preset keys" (the keys on the radio with numbers on them) to enter the code, each time you press a code number, a letter appears [c, o, d, e]. once the word is spelled out, from entering the correct 5 digits, the radio is reset, ready to go.
BUT if you miss a number, enter a wrong number, whatever, each number pressed, still makes a letter appear from the word "code". once the word is spelled out, by entering ANY 5 numbers, if ANY of the 5 is wrong, the radio displays a message "Error" and then a number 1 thru 10.
When you see the word "Error..."
the next preset button you push, starts the whole thing over again. The radio says "Enter code". That is when you enter the 1st of the 5 digits, the letter C appears, enter the next digit, the letter O appears, enter the next digit, the letter D appears, enter the last digit, the letter E apperas, the radio is reset, ready to go, if you got the 5 correct numbers entered.
you have 10 chances to enter the right 5 digit code. Each wrong try of 5 digits yeilds a display of "Error 1", "Error 2", "Error 3", etc 'till you get to 10 incorrect tries of 5 digits each.
If you dont get it right in 10 tries, you have to leave the radio "on" for an hour, then it will let you start the 10 tries over again.
Apr 26, 2009 | 2007 Honda Fit Sport Hatchback
Cant see the lost call numbers
Hmmm. One can filter the display of various types of phone calls. Check your setting for the Messages log.
1. Open "Messages"
2. Open the "Full Menu"
3. Select "Options" (this is specific to messages, not the "Options" from the main menu which is for the phone in general).
4. Scroll through all the display filters and options and you should find the one you want.
or
1. Messages
2. Menu
3. View Folder
4. this allows you to view various types of calls.
Good luck.
Apr 19, 2009 | RIM BlackBerry Bold 9000 Smartphone
Trouble entering message into itext sms text messenger
I updated someone else's instructions to make them more clear...
Instructions to a Sakar sms text messenger - sending text messages.
Press the NUMBERS/LETTERS below the keypad icons.
Example: SEND a message from one Messenger to the other
  • For the messenger (USER 1) receive a message
    • Press SMS button,
    • then the RECV button and leave it like that - don't do anything
  • On the messenger (USER 2)sending the message
    • Press SMS
    • Type with the numbers/letters (NOT THE PICTURE)
    • Click SEND (it will display P/i ?)
    • click the (I C Q chat) button with the smiley face
  • The message will appear on messenger (USER 1) display
Dec 29, 2008 | Sakar Cyber Gear Slide Click Text...
Need instructions for the itext SMS text messenger from Claire's
    • Press SMS button,
    • Press SMS
Dec 28, 2008 | Toys
Caller cannot leave a message & the letter A is showing on the recorder
Your system is set to "Announce" instead of "Answer". Since you neglected to specify the model of your VTech answering system I can only suggest you enter it into the search box here to download a copy of the manual to learn how to switch the mode.
Oct 05, 2008 | Vtech 5.8GHz Cordless Phone with Digital...
Don't have manual and phone shows "SENT" and ext #?
i want to setting toshiba dkt-2020 code number
May 14, 2008 | Toshiba DKT-2020 Corded Phone
Vtech IP5850 Answering Machine Logo
64 people viewed this question
Top Vtech Lands Phones Experts
David Burbee
David Burbee
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
