Question about Compaq FP 7317 17" LCD Monitor
RIGHT SPEAKER THE RIGHT SPEAKER ON MY MONITOR LOSES SOUND SOMETIMES. I'VE CHECKED THE VOLUME CONTROL AND WANTED TO KNOW IF I CAN USE ANY OTHER SPEAKERS FOR THIS PROBLEM.. I BURN CD'S A LOT AND DON'T WANT THE MUSIC FADING IN AND OUT. THANKS IN ADVANCE FOR YOUR ASSISTANCE.
    Sergeant:
  • 226 Answers
When did you purchase your monitor? if it sitll have warranty then call the manufacturer to replace it. You have encountered minor defects. However u can have sound for your computer. Use a desktop speakers connect it to the back panel of your tower case/casing. there u can locate the jack for speakers, jack's color is green. regarding to the CD's you burned, Speakers cant affect the quality of sound burned in your cd.
Posted on Jan 17, 2008
I cant get sound from my Logitech speaker system.I've checked everything.I don't know why it's not working,but in the control panel it says "There is no system on"
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
May 08, 2011 | Logitech S120 2 Speakers
No sound from monitor
make sure you have selected the right speakers and that the monitor has built in speakers and the leads attached have secure seating and are not bad/faulty
you might have to uninstall then reinstall the sound drivers
if your computer came with a motherboard disk the drivers could be on it
control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
Dec 28, 2010 | Kogi L7CH Monitor
Need more volume on computer speakers
Buy yourself some stand alone speakers, a base & two side speakers, they cheap these days, base speaker has buit in amplifier & plugs into mains, or get surround sound 5speakers & a base, again mains powered, loud enough to annoy neighbours on full. Built in monitor speakers are renowned feeble tinny sounds. Right click speaker icon, bottom right, on your desktop toolbar, open volume control, ensure volume sliders set to max.
Oct 02, 2009 | ViewSonic VX910 19" LCD Monitor
Can not get this monitor to play sound on PC using XP Version 5.1. a driver needed?
there is not a windows xp 5.1 so I am going to take a wild guess and you mean you want 5.1 surround sound
If your computer plays sound through its own speakers normally then you do not need a driver.
I took this from the FAQ
  1. Make sure the audio cable is plugged in to the back of the monitor and in to the Green port in the back of the computer.
  2. Press the Right Arrow button on the monitor itself and set the volume to 10.
  3. Double check your audio settings on your computer and make sure nothing is muted.
This is not one of the better monitors in this price range having only a VGA input but is suitable for most people.
Aug 14, 2009 | Sylvania CL772B 17" Flat Panel LCD Monitor
Cannot raise the volume
Speakers built in to monitors are notorious for being quiet. But, check the sound in control panel and see if it knows you r useing that type of speakers. And of course check monitor itself for a manual volume control.
Jun 24, 2009 | ViewSonic Optiquest Q19wb LCD Monitor
Speakers don't work!
Sometimes, the colors on the jacks should be reversed. Try doing that - reverse which colors the jacks go into on the back of the PC and see if you get sound that way. Turn the volume down, just in case,
Jun 21, 2009 | HP (400745-001) Sound Card
I have no sound at all
Have you checked that sound is coming from the computer? Make sure you don't have the output muted and that your volume is turned up. Check the output by plugging in a pair of headphones or another speaker system. If that's all normal, the problem is in the speakers.
The speakers aren't actually a part of the monitor although they do hang on the sides. Check that the audio cable from your computer to the input jack on the right speaker is plugged in at both ends. Check that the power adapter is plugged into a working AC outlet and that the power plug to the speaker is firmly seated. Does the power indicator light when you turn the speakers on? Is the volume control up? Those AC adapters sometimes do fail. The adapter is replaceable if it's gone bad (you can find a suitable one at Radio Shack).
If everything else is checking out and the speakers still have no sound, the amplifier integrated circuit has failed. While this could be repaired, you can probably buy a new set of speakers for what a service shop would charge to replace the amplifier.
May 30, 2009 | HP Compaq FS7600e CRT Monitor
I sometimes lose sound from my left speaker and it crackles.
this is a speaker input pin problem, like pin is dameg or input pin is not atech proparly in computer problem is still present remove the cable and install new one cable in speaker
Mar 11, 2009 | Audio Players & Recorders
We have a HP vp15 monitor. Recently we have not had any sound.
Monitor control buttons are located on the front panel of the monitor on the lower right. Make sure that you connect the built-in monitor speakers to the computer, using the audio cable (green connector). The connection on the monitor is located on the back of the monitor. On that monitor I believe the volume button is the second one (from left tot right) on the lower right. Also you may want to check your systems volume on your computer by left clicking one time on the little speaker on the lower right of your screen by the clock.
Hope this helps
-Curtis
Rate It!
Jan 29, 2009 | HP Pavilion vp15 Monitor
Only getting half the volume
The first things I would check would be the volume control within your operating system. If I assume you have Windows XP, you would go to Start-->All Program-->Accessories-->Entertainment and click "Volume Control". Make sure all of the sliders are at least 1/2 way up. You might also want to check to make sure the cable from the speakers to the computer is plugged into the proper jack (usually the green one), as sometimes computers have jacks for rear speakers, which might make them sound quieter.
Mar 04, 2008 | Logitech Z-2300 Computer Speakers
Compaq FP 7317 17" LCD Monitor Logo
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
