Dayton model 3e473a
When heater is hot enough fan turns on for about 20 seconds than off for 10
repeats this about 7 times, ocasionally it will run properly
Had motor replaced 2 months ago has worked fine till now
  • coluta Jan 03, 2008
    Thanks to both for the help
    Part has been discontinued trying to find alternative
  • coluta Jan 05, 2008
    Thanks for all the help. Bought the unit at Grainger they were no help in getting part said was discontinued no alternate part.Buy a new unit for $700
    BVL sales in chicago had the part $24. Lucky for me.
    Great site
  • 1,420 Answers
Inside the heater there is a bimetal switch that turns on the fan when the heater reaches a certain temperature. I suspect this switch needs replacing. It is usually found attached to one of the fins in the core of the heater. Follow the wiring diagram from the blower motor to the switch.
Posted on Dec 27, 2007
  • 625 Answers
There's a high limit switch inline with the motor - may need replacing.
  • THOMAS MIERZWA
    THOMAS MIERZWA Jan 04, 2008
    Hi if you will go to this site: www dot fenwalcontrols dot com and search out products. Look for a surface mounted thermostat that is normally open. choose the cut in temperature you want and order it. when the core temperature reaches the cut in temp of the switch [stat] your fan will turn on. if you want it to run for a longer period of time, you could use the surface thermostat to turn on a pneumatic relay. the relay is tied into the fan circuit and closes when the relay is energized. as air bleeds out of the device eventually the circuit will open and reset. another use for the control could be to energize a solid state on-off timer like an Omron timer to turn your fan on or off.
Need fan motor for model 2E440
Try Grainger
dayton 2e440 heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
... a Dayton Model 2YU40 electric heater Need manual for Dayton. ... looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
Dayton rheostat fan motor Heaters Questions & Answers ...
www.fixya.com > Forum > Tags > rheostat fan motor > Heaters
Dayton heaters rheostat fan motor related questions and answers. ... UP BUT FAN WONT KICK ON Could be one of several problems dependant on the model you have.... The motors are noisy in 2 Dayton 2e440 heaters. I ... I'm looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
DAYTON Electric Wall Heater, Recessed or Surface ...
www.grainger.com/.../DAYTON-Electric-Wall-Heater-3...
W. W. GraingerShop DAYTON Electric Wall Heater, Recessed or Surface, Voltage 208/240, Watts ...Item # 3UG56; Mfr. Model # 3UG56; UNSPSC # 40101814; Catalog Page # 4277; Shipping Weight 20.65 lbs. ... Additional features include a built-in thermal cutout andfan delay switch for added safety ... Need Help Finding Repair Parts?
Jan 09, 2016 | Dayton Electric Heater
The pole buiding 24 in hanging Dayton sometimes the blower comes on like after 5 minutes after everything else kicks in and sometimes like when its supposed to and sometimes not at all?? All the electric...
I'm not sure whether this is a gas unit or not. With many gas heaters, the blower comes on when the heat exchanger gets hot enough and goes off once the heat exchanger cools. Other things are happening before the blower goes on. The blower is normally controlled by a "fan control thermostat". This stat actuates the blower when the furnace is hot enough so that cold air is not being blown around and allows the blower to run until the furnace cools enough to get out the remaining heat after the flame shuts off but not so long to again allow cool air to blow around. If this fan control is malfunctioning, you will get erratic runs from the blower or the blower may not run at all or run long or continuously. The fan control is the first thing to check.
Gary
Jan 31, 2011 | Dayton Gas Furnace Heater
Hayward Spa Heater H100ID blower will not stay on.
I had a similar problem and it turned out to be the solder connections on the control module. The connector that is soldered to this board (comes from the gas valve) needed to be re-soldered.
May 30, 2009 | Hayward H Series Induced Draft Abg 100,000...
I need a gas valve for a Dayton model 3E473A wall furnace
you can look for a gas that we go in place of the one you have, try national energy they sell gas valves and should have one to fit your heater , i would change the thermocouple as well .
hope this helps
Dec 08, 2008 | Dayton 511 Utility Heater
My Dayton garage heater model 2E636B does not heat up.
These heaters are the same as the marley heater, the element never gets red hot. the unit is set up so the fan kicks on after the element has heated to a certain temp and turns off after the element has cooled. It is common for these heater fans to cycle on and off quite often untill the air temp reaches about 55 degrees and then will operate normaly. If the fan still cycles too often you may have to replace the fan control and high limit switch. These are not very expensive and easy to replace yourself. they arte usualy attached to the back of the element with clips. The luke warm air is what these units put out. I have an equivelent to the dayton G73 and it heats a 24' X 30' garrage all winter in central Minnesota.
Nov 17, 2008 | Dayton G73 Utility Heater
Dayton blower fan repeatedly kicks on and off
chech the air filter is clean and the fan limit switch look to change fan limit
Nov 01, 2008 | Dayton Gas Furnace Heater
Dayton 3E372B Fuel Trimmer
sounds like the thermal couple could also be the ignition module.Is it spark ignition or hot surface
May 05, 2008 | Dayton (3E379) Heater
Heating & Cooling Logo
240 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Mack Baxter
Marvin
Marvin
