Question about Dayton G73 Utility Heater
Dayton mod#3e219b gas heater
Unit runs ok with top cowling off, but with cowling on unit dies out with in sceconds. Unit has a new air pump installed and a new ignitor. Hopefuly you can help us.
Thanks Dale
I have the same type problome with the model 3VE50A 125,000 BTU if the upper cowlen is off it runs fine but as soon as you put the cover on it shuts down all of the filters have been cleaned per the manual and i have installed all new fuel lines ,air lines and have adjusted the pump pressure to the sujested 5 PSI
  • 26 Answers
In the original manual for 3E219B it does say the pressure shoule be 5psi. If you would like I can email you a copy of the mail just email me at sandyk@bealsmotor.com. As for the 3VE50A you can go to http://www.bealsmotor.com/heathogprices.html and click on the model and find the correct pressure for that heater. There is also a place to order parts. Check to be sure you have no air leaks in the filter cover or air lines or fittings, clean filters and then adjust your pressure.
Posted on Jan 21, 2012
  • 625 Answers
Who told you air pump is supposed to be 5 psi? at the desatech site in their PDF troubleshooting guide air supposed to be 3.0-3.5 psi.
Posted on Dec 27, 2007
Where to buy need parts for 3E219B need new filters
Do you need air filters or fuel filters or both?
Jan 14, 2011 | Dayton E52 Utility Heater
Dayton 70,000 btu kerosene heater only runs consistently with 3/4 of a tank of fuel or more. Once it is below 3/4 it keeps shutting off. I have cleaned filters, tried to set pressure but pressure won't go...
If you can only get 4 psi from the pump then you have a problem with the rotor. This could be from the vanes not coming out properly of if you have replaced or serviced the rotor you may not have the clearance set properly between the pump ring and the top of the rotor.
Make sure to inspect the pump cover for any small cracks..
If you pump pressure in not enough the unit will not be able to pull fuel from the tank and you will see the burner cone slowly start to go from the orange color to a dark color and the unit will shut down.
Feb 10, 2010 | Dayton (3E386) Heater
My Dayton Gas Unit heater will not stay on. The
Have you tried the flue vent? If not, an easy way to check this would be to take the vent pipe off of the unit and see if it continues to have the problem. In most cases, this happens when you have blocked return air or dirty filters, flue blocked, or induction is blocked from switch or housing. One other possibility would be a dirty/clogged a coil which isn't allowing sufficient air to push out causing the limit to trip. I hope this helps somewhat.
Feb 06, 2010 | Dayton Gas Furnace Heater
Have a dayton hanging garage heater when trys to start acts like gas valve not opening heaters brand new.what should i look for
I have never seen a dayton gas heater but I will try. If this is an LP Gas
System are you using a 30lb. Cylinder, 100 lb cylinder or a whole house
Tank.
Next are you sure you got the right gas unit for the right gas system?
If using LP gas did you put an external pressure regulator before the unit?
Next is the a hot surface glow coil or a spark system ignition system?
If you have to hold the controller down and press a button similar to a outdoor gas grille is it sparking?
If it is sparking,did you bleed all of the air out? This could take several
tries on a new unit. Does this have a wall mounted thermostat that
controls the heater? Finally check to make sure that the gas valve
is switched on if it has that option.
Good Luck
Jan 14, 2010 | Heating & Cooling
My dayton NG heater fan will not shut off properly
Sounds like a bad fan switch. The switch is located on the heat exchanger and is 110 volt bi-metal switch. Follow the wires from the blower going back to the heatexchanger. Graingers can get you a new switch if you give them your model number. www.grainger.com.
Dec 12, 2009 | Dayton Heating & Cooling
Dayton kerosene heater 3E219B will not turn on
I have a Dayton Model # 3e219b 150,000 BTU potable heater and it runs fine with the top cover off.But if I put the cover on it will go out is less than a minute and trip the reset.
Jan 31, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
No spark
has the transformer fallen off the motor assy.there are two screws that hold the transformer on.some times they vibrate out and the transformer losses it's ground.if they are in and tight you need a new one.cost about $80.00 for new one
Jan 17, 2009 | Dayton E52 Utility Heater
Dayton 175k heater
the air pressure is not correct on either units.the photo cell DOES NOT look for light any more,it count the light flashes.if the flame is not in the right possition the heater will shut down....after the unit ignites the ignitor is no longer used to keep the unit working,just the fuel that is being fed to the flame ball.that's why the pressure is so inportant.......
Jul 08, 2008 | Dayton E51 Oil Filled Utility Heater
Dayton e51 kerosene heater
We have a 3VE53C 400,000 btu heater , the fans will come on you can hear the ignitor and fuel will run out of the front of the unit. It trys to fire twice and will not. Then you get the E1 error sign.
Jan 21, 2008 | Dayton E52 Utility Heater
air compressor output should be 3.5 psi. to the fuel nozzle. the cowlings purpose is to channel the air-fan output through the rear vanes of the combustion chamber. if these openings are restricted then air can't get into the chamber. check to see that the fan blades aren't jammed against the cowling. if they won't spin then you won't get any air through the unit.
Dec 21, 2007 | Dayton E52 Utility Heater
Dayton G73 Utility Heater Logo
300 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Ronny Bennett Sr.
Ronny Bennett Sr.
vance jones
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
