Back to:
Tags:
Motorola WR850GP Router
XBox 360 not compatible with Motorola WR850G (by 3 users)
posted by wishbar on Dec 26, 2007
can't get xbox 360 to connect to xbox live, the connection test fails at MTU, wired or wireless. My WR850G (not on Microsoft compatible lsit) doesn't allow me to change that, except when using PPPoE, which isn't applicable to my cable provider.
Comment by wishbar, posted on Dec 29, 2007
I have latest firmware (6.1.4), but it started working after cycling power to the router and cable modem.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by Guest, posted on Jan 08, 2008
I also am experiencing this problem. When I set the router for PPPoE, I lose my internet connection. Please Help!
Comment by truegamer44, posted on Dec 29, 2007
I have the same exact problem. Any help?
Best Solution
Thanks for Trying (70)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I am surprised that you are having this problem. I own the WR850G and I have no problems connecting to xbox live. I have my router connecting to the dsl modem using pppoe. And the router is set to allow any other devices connecting to the router to use dhcp. Note that I have my xbox 360 using dmz from the router's settings. Even though I had it at one time not using dmz, it was still going on xbox live. Maybe you need to update the firmware in your router. I know mine has the most up to date firmware released.
Rating Locked! (?) wishbar has rated this solution as Thanks for Trying
Thank You!
Was the solution helpful?
Show your appreciation by commenting on XBox 360 not compatible with Motorola WR850G:
I don't want to Accept this solution
Can you Help with these Routers problems?
Routers
have 1 laptop and wan to use wireless
Routers
attempting to connect a printer to the wireless system....
Routers
I have two laps with same config, brand and VISTA home...
Routers
after u save thr running configuration at...
Every time I try to FTP upload to my website, I get 0 byte...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
