Question about Hoover U5450-900 Windtunnel Supreme Bagged Upright Vacuum
Bad smell after using my windtunnel for a couple of minutes i noticed an odd smell. i turned it over and checked, the belts are fine but i cleaned out the hair anyway. after doing that the self propel seems to struggle and it is hard to push. when i look through the window on the top i can see the brush spinning freely but then when i push it, it slows down dramatically and then picks up again. the suction is fine. what do you recommend?
  • leftycat Jan 20, 2008
    umm, geez i don't know. what and where are the roller bearings an how would i know if it were them? thanks for responding, i appreciate your time.
    Filmmaker:
    Uploaded 5 video answers.
  • 152 Answers
It may be the roller bearings?
Posted on Jan 02, 2008
I have a Hoover WindTunnel with a bag that makes a burning smell. I cleaned the brush and the belt looks intact. It still smells really bad. Could it be as simple as needing a new belt?
yes it could be that simple. sometimes the belt will wear and stretch. Generally I advise my customers to replace the belt once per year, or as soon as something gets caught to stop the brush from turning.
Your belt number should be on the model/serial plate on the bottom of the unit there. 38528-###. I am guessing its a 38528-033 but could be 38528-040. Your model/serial plate will be more accurate.
Nov 05, 2010 | Hoover Ultra U6430-900 WindTunnel Bagged...
After a few minutes of using my vacume it starts to smell like burnt rubber. like the belt is burningthe only belt I can see looks fine and is turning the brush
but how tight is the belt and how easy is the brush to turn? if the belt is slopy it will slip on the motor drive spindle,,,and it will get very hot then,,, also if the brush head is tight that makes the belt slip too,
Aug 11, 2010 | Hoover U5780-900 Windtunnel Cyclonic...
HI, my motorized brush barely turns.It makes a hot rubber smell. I took apart and noticed the spindle the belt turns on discolored from heat. Cleaned it, but still no turning of the brush.The vac is a...
That means that the belt is stretched and it is slipping on the motor shaft, that is why it is hot and smells like burning rubber. You need to replace the belt. Here is the correct belt you need:
Hoover Windtunnel Canister Belt
Dec 24, 2009 | Hoover S3765-040 WindTunnel Bagless...
The brush roller stops turning and I can smell the belt burning, then it will catch and start working normal. I looked under the plate to check the belts and they looked okay and no hang ups of string or...
better to replace both belts the smaller one is stretched out thats whyits slipping ,be sure to clean the old rubber off the motor shaft before replacing the belts.it will cause the new belts to run unevevly and go bad before their time
Aug 30, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Loose paint is stuck in my Hoover 5753-900. Now it won't turn on
Take the bottom plate off where you would install a new belt. the impeller is clogged up. use a wire to poke out the clogs. you can use a shop vac to **** out the debris. check your belt for wear spots while your at it. you may need a new one . befor removing the belt. make sure you notice in what direction it is installed. If you put it on backwards you brush will turn in the wrong direction,not good. draw a picture if need be. Ok good luck DFD
Apr 11, 2009 | Hoover U5753-900 WindTunnel Bagless...
Burning smell coming from vacuum
use a penny to turn the 2 screws on top a quater turn then fold down the vacuum and lift up the cover and you will have access to the belt. Clean the small hepa filter with soapy water. their may be 2 of them. The cannnister filters need to be shaken but not washed. Good luck.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 09, 2009 | Hoover U5753-900 WindTunnel Bagless...
Hoover U5468-900 WindTunnel Supreme suction is suddenly poor
The other possibility is there is a blockage in the foot. these models have dual channel air flow (windtunnel) and become blocked when not cleaned depending on use. under the roller there is a cavity that can be removed for cleaning. a hot motor can be caused by poor air flow.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Mar 15, 2009 | Hoover U5453-900 WindTunnel Supreme Bagged...
Rubber smell, Hoover
Well it sound like you do need a new belt because of how the smell is you might want to stop using it because the smell comes from the burning and over heated belt my solution would be to get a new belt and that should fix it if you need anything else you know whre to find me.
Jun 30, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover U5450-900 Windtunnel Supreme Bagged Upright Vacuum Logo
213 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
