Question about Brother MFC-8840D All-In-One Laser Printer
Doc cover open
Hi! my MFC-8840D SAYS: DOC COVER OPEN. and solution you have is to replace the left hinge. is it easy to replace it? or do i have to bring it to a technician? if i can do it myself - then, i can go ahead and order the hinge from you. my email is: jacklynfinds@yahoo.com
  • 7 more comments
  • Anonymous Dec 27, 2007
    how did you resolve the problem?
    Please le me know, my email adds msousa4u@aol.com
  • jack-lyn Jan 01, 2008
    comment very helpful. short and clear. thanks much. MORE POWER.
  • sidc Jan 01, 2008
    The left hinge on my brother MFC-8840DN is broken. Where can I order a new hinge?
  • MetalJazz Jan 05, 2008
    Soulvisitor, thanks for posting this solution.  I'm having the same problem, and I can see that the left hinge of the ADF is broken.
    If I order the part you've included the photo of, how would I install it?  From looking at my printer, it looks as if I would:
    -  Life the whole ADF off and out of the top of the flatbed casing (it looks like the ADF is just held in place by plastic "posts" that fit into the top of the case (?) )
    - Unscrew and remove the broken hinge
    - Screw in the replacement hinge,
    - Attach the ADF to the top of the flatbed casing by fitting the plastic posts back in their "sockets" in the top of the flatbed case
    Can you tell me if this correct, and if you have any additional tips?  I've never made this type of repair before.
    Thanks,
    Barb
  • Anonymous Feb 10, 2008
    I have the same problem the left hinge is broken is it hard to replace and can I order the part from Dell. Please answer ASAP
    Thanks
    Jim Smithson
    Focus Realty
    Jim@focusrealty.biz
    Cell: 901-371-7905
  • spoiler1969 Feb 26, 2008
    i need to order a left hinge cause machine say doc cover open thorn_1969@yahoo.com
  • VIKASG Feb 28, 2008
    I AM GETTING THE MASSAGE " CHECK ORIGINAL", I SAW THE HINGES ON THE LEFT SIDE IS BROKEN. CAN I ORDER FROM YOU? AND HOW MUCH FOR IT?
    THANKS!
    VIKASG
  • timmy_c Mar 23, 2008
    I seem to have the same problem. Where can I order a new hinge - can I do it online?
  • anthro Jan 19, 2009
    would someone please let me know from whear I could get any drawings or pictures showing how to replace the left hinge?
  • Brother Master
  • 1,113 Answers
3 screws easy fixdoc cover open - f5f7046.jpgno tec needed bout 25 bucks for hinge see my other post re this problem 8025, 8820,8840,8225 same same
Posted on Dec 28, 2007
  • Soulvisitor
    Soulvisitor Dec 28, 2007
    fixya or I dont sell parts, if it is hinge then you should see crack in it
  • Soulvisitor
    Soulvisitor Jan 05, 2008
    posted by MetalJazz on Jan 05, 2008
    Report abuse
    In a post here, Soulvisitor gave a solution to someone else's problem that also helped me. My Brother MFC-8820D is also showing "Doc. Cover Open" message in the LCD when it's first turned on. Pressing a small black lever at the back left side of the underside of the cover is the only thing that will clear the message, but, no matter what, the ADF will not work at all. The problem seems to be due to a broken left-side hinge of the ADF.
    Soulvisitor posted this photo of the replacement hinge that is needed:
    I can easily order this part. However, how would I install it? From looking at my printer, it looks as if I would:
    1) Lift the whole ADF off and out of the top of the flatbed casing. It looks like the ADF is just held in place by plastic "posts" that fit into the top of the case (?),
    2) Unscrew and remove the broken hinge,
    3) Screw in the replacement hinge,
    4) Attach the ADF to the top of the flatbed casing by fitting the plastic posts back in their "sockets",
    Can anyone tell me if this correct, and if there are any additional tips? I've never made this type of repair before.
    Thanks,
    Barb
    Have the same problem? Click Here
    Solution #1
    posted on Jan 05, 2008
    Soulvisitor
    Rank: Guru
    Rating: 86%, 631 votes
    Look at back of machine and at your new hinge, note the screw hole, if you undo both of those on the back of the printer, entire doc feed will come up and out, BECAREFULL just lift A LITTLE is enough to enable hinge base to be free of sockets (many cables attached) and place doc unit slightly sideways on copy glass to enable yourself access to 3 screws that hold hinge.
    Comment by Soulvisitor, posted on Jan 05, 2008
    The Hinge is the plastic post. Yes Barb you will be right your instructions are sound just remove lock screws first.
    When you pull the doc feeder out the hinge that is broken may leak springs and bits but fear not for the bits cause you have the new one.
    lock screw marked with x
How to remove back corner panel at feeder cable in Brother MFC 8840D
If you mean the top left of the doc. feeder, you remove the cover by flexing slightly, remove a phillips screw, lift the scanner cover and there's a square hole on the lid with one of those flex clip retainers that you use a screwdriver to lift.
Jan 22, 2010 | Brother MFC 8840D All-In-One Laser Printer
Tip
Doc feeder Nogo/ Doc cover open?
If you can use the glass and can print, but you cant fax or use doc feeder, then have a look at Left hinge it will be cracked, If you push down on left corner you should be able to use doc feeder when in that position
Here is part that breaks on every machine.
Here is link to purchase one for $25 bucks, three screws and job done, easy fix!
on Dec 24, 2007 | Brother MFC-8440 All-In-One Laser Printer
Tip
Cant use doc feeder?
on Dec 24, 2007 | Brother MFC-8840D All-In-One Laser Printer
The error message says Doc. Cover open but the cover is closed
You will probably have a broken hinge at the back left hand side of the Doc. cover.
This means that the cover won't close properly at the back corner, and the cover sensing switch won't actuate.
Dec 08, 2009 | Brother MFC-8840D All-In-One Laser Printer
Doc cover open errror message on a mfc-8840d and cant' seem to print anything and the mode always is in fax mode and we can't seem to change it.
That error happens when the left hinge in the back breaks and the scanner cover won't shut all the way. temporarily you can tape the switch that is above the hinge and when the error is gone the modes should change again. The hinge is #LP2403001.
Oct 16, 2009 | Brother MFC-8840D All-In-One Laser Printer
Doc. Cover Open displayed...remove original and then close cover.
Left rear hinge is cracked stopping lid from closing fully. Tape down black switch left corner near glass rear. Or replace hinge
Dec 15, 2008 | Brother MFC-8840D All-In-One Laser Printer
How to replace broken hinge on ADF on Brother MFC-8820D printer
Jan 05, 2008 | Brother MFC-8840D All-In-One Laser Printer
Doc cover open
Yes there is and I know your problem have a look at the left hinge on lid that you lift to put down an original for copying, it will be breaking apart, the switch is black in that same corner on doc feeder base, as the hinge breaks apart the doc feed lifts in that corner causing "doc cover open" cause that switch no longer gets pushed in when lid is shut
Dodgy repair - tape switch closed, but doc feeder will not work properly/can use glass.
Repair - Easy removal of three screws and replacing 20buck hinge bought from brother dealer...part no.LE8731001 Hinge assy left.
Now that's FIXYA!
Nov 19, 2007 | Brother MFC-8440 All-In-One Laser Printer
Document Cover Open
I had the same problem with mine. Lift the top scanner, and check the hinges on the left. That error message means that the little black sensor on the left next to the hinges is not meeting flat with the unit when closed. Hold the sensor in for a few seconds, and your printer will start working properly.
Oct 11, 2007 | Brother MFC-8840D All-In-One Laser Printer
Brother MFC-8840D All-In-One Laser Printer Logo
391 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
