Question about Sony VAIO VGN-AR130G PC Notebook
Keyboard replacement Is there a diagram that shows how to remove and replace the keyboard on the VGN-AR130G.
    Sergeant:
    Champion:
  • 310 Answers
Not that I know. first all plastic pops off the top. pops off not breaks off
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Posted on Dec 30, 2007
KEYBOARD REPLACEMENT SONY VAIO VGN T350P
every laptop is different some have screws underneath some have a part of the casing above the keyboard that can be removed by sliding it to one side revealing the screws underneath this could also house the power buttons and some unfortunately require the complete laptop motherboard etc removing first and i know with my sony this is what i had to do, so firstly check for a strip above the keyboard and try sliding it to one side, if there is a strip then youre in luck as it will normally reveal 3 screws holding down the keyboard which will allow the keyboard to lift and unclip and then you just need to unclip the ribbon cable from the motherboard, if theres no strip then you could try turning the laptop over and removing any screws that are directly under the keyboard and see if this frees it and also removing any memory and hard drive that may be hiding any screws, if this does not solve your problem then you are heading for a complete stripdown of the laptop base which unless you feel competent in doing so is best left to the experts, hope this helps
Dec 29, 2013 | Sony VAIO VGN-AR130G PC Notebook
Remove keyboard 646125-001
  1. Prior to replacing your replacement keyboard for sony vaio vgn-fe880e/h, make sure to remove the keyboard and disconnect the ac adapter from your laptop.
  2. The first step to replacing your laptop keyboard is to remove the screws from the back of your vaio vgn-fe880e/h. Sometimes your laptop will have a picture of a keyboard next to the screws that need to be removed. Otherwise, see your laptop manual for details.
  3. Above the laptop keyboard for sony vaio vgn-fe880e/h, you have a cover panel. If required, remove this part to easily access your keyboard. If you have screws above your keyboard, remove those screws.
  4. Now that you have removed all the screws, you are ready to remove and then replace your new laptop keyboard.
  5. To remove the vaio vgn-fe880e/h Keyboard, take a thin object and pry the keyboard out between the keyboard and motherboard. Be careful when removing the keyboard.
  6. Now that your keyboard is loose, simply disconnect your keyboard. In order to disconnect the keyboard, pay attention to the keyboard connector and connector cable. Unlock the connector cable device and remove your laptop keyboard. Your sony vaio vgn-fe880e/h connector cable should be easy to remove by simply sliding it out.
  7. Now that your keyboard has been removed, get ready to install your new laptop keyboard. Look at the back of the keyboard. If you see any screw holes, you will have a good idea of where to place the screws back in at the bottom of the laptop.
  8. Connect your laptop keyboard for sony vaio vgn-fe880e/h to the motherboard keyboard connection slot. Secure the keyboard cable. Now turn your keyboard in place, and align the grooves on the bottom of your keyboard with your palmrest or plastic bezel. Secure your laptop keyboard in place, make sure it fits properly and is snug. Now simply place the screws back in place.
Nov 30, 2012 | HP 646125-001 - Keyboard Tm - Us
How to replace keyboard on sony vgn-nr498e, broken left hand shift key, i need to replace entire keyboard
If you have the new keyboard, look at the bottom and locate the screw sockets. On the laptop at the bottom, match and locate the approximate location of where each screws are mounted. Remove only those screw. On some laptops, you might need to remove the keyboard top frame - if they are mounted with screws, remove them as well. Some laptops have a small picture or symbol of a keyboard for each screw that needs to be removed on the bottom of the laptop.
Dec 09, 2010 | Sony VAIO VGN-NR498E/S Notebook PC
It won't boot. says it can't find operating system.
Windows is corrupted beyond repair - you will have to reinstall it by using the recovery cd. If you don't have it you will have to order it from Sony.
Nov 28, 2010 | Sony VAIO VGN-AR130G PC Notebook
Replacement Instructions for VGN-FJ 290 for optical driver
Here is the manual for disassembly of your system. It is illustrated and shows the tear down to get the optical drive out. Save a copy for yourself for future reference.
http://tim.id.au/laptops/sony/vgn-fj.pdf
Oct 21, 2009 | Computers & Internet
Replace a VGN-FZ320E Keyboard
Remove the battery,remove two screws that secure the cabinet to the computer,release three dintents,rotate the cabinet cover towards the lcd.Once this is removed.Remove two screws that secure the keyboard to the system.Becareful as the keyboard is attached by a ribon cable to the system which you will have to release to completely remove from the system.
good luck
Oct 20, 2009 | Sony VAIO VGN-FZ320E/B Notebook
Replacing keyboard from VAIO FS-742/W sony laptop
Yes it does come out at the top. I have seen this article and thought it might help you. The first 7 steps show how to remove the keyboard..
http://www.mikeshardware.com/howtos/sonyhdswap/
Nov 25, 2008 | Sony VAIO VGN-FS742/W Notebook
Replacing Keyboard Sony VGN-N130G
Here is the pictures on how to remove the keyboard
May 20, 2008 | Computers & Internet
VGN-A190 Keyboard Replacement
While I can't find your specific model, this page lists a number of various models and ways to take them apart for different items. Since your laptop is not listed, just find another model in the same design/size format, and that may show you how to remove your keyboard as well:
http://repair4laptop.org/disassembly_sony.html
Jan 17, 2008 | Computers & Internet
Sony VAIO  VGN-AR130G PC Notebook Logo
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
