My copier keeps throwing a C-13 error code. Any idea what this means? Please help!
The trouble is that Minolta did not provide a chart of error codes in the user manual; mostly error code issues would require a technician to repair anyway -- or at least somebody trained to do preventive maintenance. If you have a routine repairman, or if you have My Konica-Minolta access, you should be able to get more information that way. Other things to check:
If you're in the United States, you can check Konica-Minolta's Sales/Service Locator for a local repair outlet. Otherwise, you may need to contact Konica-Minolta directly.
i have same problem if you can help me
I've found - while searching on the Net in order to fix my latest problem with my B&W laser printer - your name in connection to possessing a user manual for Minolta DiALTA di 151...
The problems is as follows:
The printer is not working in the printing mode, when after switching on it keeps on throwing No. C 13 36 or C 13 3b on the display [over the last week or so, I managed on several tries to print just a single A4 page and after that it stopped every single time]... While the copying works fine and with no problems [I've just gone through circa 25 copies of A4]...
Could you please help me out with this. Many thanks in advance,
Zdeno
Slovakia
[email protected]
