Dell Latitude D600 PC Notebook
Problem for Dell Latitude D600 PC Notebook
I need to reset the bios password on a dell
By wv1jdd on Oct 13, 2009
I need to reset the bios password on a dell latitude D600
Solution #1
posted on Oct 13, 2009
Somewhat Helpful)
weblord
Rank: Wiz
Rating: 82%, 325 votes
there's a software that does it but it's not free
http://www.theonlypcdoctor.com/dell/dl-dell.htm
Was this helpful?
Yes
No
Solution #2
posted on Oct 30, 2009
Not Rated)
happymark
Rank: Guru
Rating: 90%, 18 votes
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Was this helpful?
Yes
No
Popular Solutions for Dell Latitude D600 PC Notebook
Questions and Unsolved Problems for Dell Latitude D600 PC Notebook
Do you recommend Dell Latitude D600 PC Notebook?
Answer
Answer
Sound plays fine until computer gets hot, then it quits. Once it popped my ear with earphones in.
Answer
Monitor goes black (no green, no to flashlight test) even while we are working at fast pace and... (More)
Answer
Auxiliary monitor periodically goes black while still working. Wiggle mouse and it comes back up.
Answer
It just wont work, it does read some cds but will not download programs or burn etc...
Describe your PC Laptops problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptop Experts
Top Computer & Laptop Repairmen
in , AK
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
