Hi, I have camaro 1991 and I wanna change my delco radio to new nextar mp3 audio, when I can get wiring instruction for replacement my old radio, Thanks
You can get an electrical schematic from a chassis manual for that model Camaro from Chevrolet, which will detail the pin-out (wire location on the multi-wire connector(s) that plug into the back of your radio); but it will cost about $100 or more. It would be easier to trace / detect the wires on your own. If you know how to use a test-light and can wire a radio to work temporarily, it will be a breeze. First identify the power source, which is usually red, the igniton feed is usually yellow or grey, the ground is usually black or brown. There will also be one wire leading to the radio from your dimmer, which you can identify by turning your dimmer switch to dim and bright while testing all the leads until you find the one that dims and brightend your test light. After nailing those down, the only thing left will be the five or six speaker leads. There will be one or two ground leads and four speaker leads (if the car has six or eight speakers, the extra ones are branched, which is sometimes obvious on the connector, because you'll see two leads attached to a single pin. If you need further instructons or run into another snag please let us know.
Hope this will FixYa!!!
