Acer NSK8458AN Keyboard Logo
Posted on Oct 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When i type @ it shows " assist me in solving this problem
Anonymous
Level 3:
  • Master 507 Answers
  • Posted on Oct 13, 2009
Anonymous
Master
Level 3:
Answers
507
Questions
0
Helped
247171
Points
1453
Try typing this:
hold and press ALT then type 64 without letting go of ALT key.
2answers
My conlog meter is showing the rfcon error please what do I do
No connecting to your utilty company in South Africa. Just FYI, we are a North American site and my not always have the answer, in this case we do
Https://www.facebook.com/ConlogSolutions/posts/im-having-a-rf-con-error-cant-do-anything-on-the-gadget-please-help-on-how-to-re/962048393965724/
Quoting from link above: "Conlog Hi Ola-daniels, Please see below steps to assist with RFCON error :
* Press the Back arrow on the keypad - this step is to refresh the UIU ( the device)
* Type # 75 # - this is to check the signal strength
If it does not go back to the normal display
*Type # 80 # - this is to refresh the meter
Then lastly you can repair the meter and the UIU by # 36 #
The above steps will work better if you are outside the house because the meters uses the radio frequency connection
The above error will occur in instances of bad weather conditions or if there is load shedding or power failure
If the problem persists after trying the above you may contact the municipality or the service provider."
SOLVED: How do I clear up the rf con error on my meter ...
https://www.fixya.com > ... > The
May 7, 2020 - How do I clear up the rf con error on my meter because I want to ... Https://www.facebook.com/ConlogSolutions/posts/im-having-a-rf-con-error- ... Hi Ola-daniels, Please see below steps to assist with RFCON error : ... shut down the energy alimentation for 2 minute ,but if the defect persist error it show again.
SOLVED: Pole meter conlog rf con meter keep on freezing ...
Jan. 10, 2017
Meter reading shows rF CON instead of units available - Fixya
Jun. 24, 2018
SOLVED: Good day my conlog ip54 elecricity meter showd ...
Oct. 6, 2018
SOLVED: Rf con error - Fixya
Jun. 20, 2020
More results from www.fixya.com
Please Help With My Conlog Prepaid Meter - Technology ...
https://www.nairaland.com > please-conlog-prepaid-meter
Aug. 6, 2020 - ystar: If the conlog meter is showing rf-Con, it means power supply doesn't reach the meter at all its either Loss of phase from the transformer or a loose contact ...
How Do I Load The Activation Token On My Conlog Prepaid ...
Mar. 17, 2020
I Need A Technician To Fix This... - Nairaland / General - Nigeria
Jul. 22, 2019
I Need Number Codes To Reset Memmcol Prepaid Meter ...
Jan. 11, 2019
More results from www.nairaland.com
I am using server 2003 as file server wchich is in workgroup and connected to the network. problem is arising when any system from the network wants to access the shared folder the user unable to access...
Try this:
go to start>run and type: \\ server ip address
for example, if its 192.168.10.20, type \\192.168.10.20
Navigate to that shared folder, right click on it and create shortcut.
If the previous step doesnt work, go to server, unshare that folder, restart and share it again. Try accessing it.
Hope this helps
When i am connecting my reliance net setter huwaei 3g modem it shows an error 678
hi alkam49...
This is most common problems. It is due to poor connectivity. Problem can be anywhere between B.RAS - Tier 2 - DSLAM - Modem - PC of the customer.
Switch off / Switch on Modem (Power Switch at the back of modem ) and wait for 2 minutes. Then retry.
If problem is not solved then Reset Modem [Back pin (in the hole) to be pressed in switched ON condition]
[Note : Link PC in black type Modem or WAN / LAN in white type Modem will go Off and then ON and system may be stable. Then retry.
If problem is still not solved then
a)Check link lamp in Black type Modem or WAN lamp in White Modem. If it is blinking, then it is line problem.
b)Check Modem to splitter connectivity.
i) Jack in & Jack out the cable of / to the modem and to the splitter
ii)Jack in & Jack out the telephone connection of the splitter.
If lamp is still blinking - then it is due to poor line condition / fault.
The case has to be referred to Area Broadband Team for attending the fault.
try this and get going...
post comment for any further assistance.
thanks.
I have a acer 5630-6288 and my web cam along with the interduction deleted what should i do
Hello my friend you can reinstall the driver of your webcam if you have the driver. if you don't have the driver then you can donload it this site. Kindly click search driver then type your driver name then click search. then the result will show immediately after you click the search button.
Hope this will able to help your problem solved. If you need more assistance just reply to this post.
thank you and Godbless
Jonas
6helpful
Database corrupted
I am using nokia n72...when I am clicking Gallery it is showing database corrupted...some data might have lost & also opera is not opening? Please assist me to solve the problem.
8helpful
2answers
Laptop Keyboard problem
Press and hold the shift key then press the NumLock key.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Access to mail
try this
right-click the menu bar and check 'Web assistant'. the Web assistant should now be showing on the tool bar. click on it and uncheck 'Block ads on this site'. this works for me in yahoo mail and also solved a problem i was having with my website's webmail account (MailEnable WebMail).
if this solve your problem, please rate the answer
thank you
Oct 14, 2008 • Yahoo Mail
Remote Assistance
You know what I do.. If we solve the problem with remote assistance, I mostly take them back to fixya if already closed, then on the my profile page open the write a review link on the chat for them.
Yeah no problem.
Btw, I think it solved on its own I haven't changed anything but its only showing one email in all messages now instead of duplicates.
May 26, 2008 • Baby Gear
I have a Nokia N73 and want to clear the search assistance when I type a letter
Hey dude,
When u r writing or typing anything, go to options or settings and disable the dictionary words !!!!
Send me a feedback and rate my solution too.
Dont forget to post a clarification request for ur problem after it is solved.
SAJAN([email protected]/[email protected])
2answers
Microsoft Outlook
This is most likely occuring because you are using Outlook 2003 with Office XP. If you have upgraded Outlook without upgrading the rest of the Office components, you can solve this by upgrading Office or downgrading Outlook.
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
