Question about Brother IntelliFax-2820 Laser Fax
Paper jam inside
Our brother fax 2820 says it has a paper jam inside, but I can't find any paper. I did get the error message to go away once, then we sent a fax to it and the paper from the try didn't go but 1/2" then jamed again. How can I reset the factory settings? I call brother and they won't help me.
  • 286 Answers
Open the rear door on the unit. Inside, you will see a black "Flap" which is called the rear paper chute.
On that chute, on the inside, you will find the paper exit sensor actuator.
The problem is that your actualor is stuck. This is a common problem on this print engine. You should eb able to see how it works. There is a little tab that has to fit into a little slot. Line them up and the machine should start working fine again.
Posted on Dec 30, 2007
    Scholar:
  • 95 Answers
You may also have a problem with the paper feed (clutch, dirty feed/pick up tires) section, or even a dirty sensor as Jay mentioned. A sensor in modern office equipment is generally a photo sensor, which means it shoots light from one side to be detected on the other side of it. If it's dirty, it will give you a flase reading. Try cleaning the tires that pick up the paer from the tray (don't force them down if they won't rotate easily) with mild soap and water on a rag, and also try fresh paper. Sometimes if paper has been sitting for a while, or in damp conditions, it will pick up moisture and give you paper feed problems... which is what it sounds like you are having. Sounds like the paper may need even be making it to the sensor in the 1st place if it on comes out of the tray 1/2 an inch. Good luck
Posted on Dec 27, 2007
  • 328 Answers
Check inside the machine for a little black sensor flag that may be stuck.. It should be able to swing freely. There are two or three of them in various places of the paper path.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Jammed paper
There are 3 places to check for jammed paper.
Turn off the fax machine, then remove the tray and open the back cover, and open the front cover to remove the drum and toner (cartridge) and look inside machine.
After you find the jammed paper put the cartridge and tray back in machine and close all the covers.
Error message should go away.
Apr 06, 2010 | Brother IntelliFax-2820 Laser Fax
Machine will not send messages, Enter FAX No. Push Send and this message appears, Paper Jam
Have you opened up the Document feeder and checked inside?
I sounds like you might have something caught in the paper path.
Dec 03, 2009 | Brother IntelliFax-2820 Laser Fax
Error message says unable to print on Brother 2820. It will not answer an incoming call but will transmit a fax. Machine is in almost new condition, barely used.
when you send a fax do you get transmission report? open back to see if there might be a jam, remove cassette to see if there is a jam. if these areas are clear of paper then you have a mechanical problem and it would have to be seen by a tech
Nov 14, 2009 | Brother IntelliFax-2820 Laser Fax
Brother fax machine says back cover open and it is not open. Why?
This message comes up sometimes when paper is jammed inside. Remove paper thru back cover.
Mar 05, 2009 | Brother IntelliFax-2820 Laser Fax
I have an Intellifax 2820 and there is an error message of paper jam inside... I have cleaned all paper out of machine... please help me
A jam sensor may be stuck by a paper scrap. Try manually pushing a sheet of paper through the machine IN THE DIRECTION IT IS NORMALLY FED. This may force out any stuck scraps. The jam sensors are usually located where the paper feeds and where it exits the machine. Also, make sure ALL ACCESS PANELS YOU OPENED TO CLEAR JAMS ARE CLOSED PROPERLY. Otherwise, the jam code will not clear.
Nov 25, 2008 | Brother IntelliFax-2820 Laser Fax
Fax fixable? error msg
We call the moose method of clearing paper jams, the RCMP method, cuz they only know how to shoot to kill. You did good. Except, there is no such thing as "Bending" anything. The term is "re-form."
Dec 21, 2007 | Brother IntelliFax-2820 Laser Fax
Brother MFC 3240C Paper Jam Error Message
If it is not resetting then either there is still something on a sensor or you did something to a sensor by accident.
here is the manual
http://www.retrevo.com/s/brother+2820+fax++manual
Nov 21, 2007 | Brother IntelliFax-2820 Laser Fax
Can't print faxes due to error messages
Please check rear door area for paper, can you use manual feed slot? Power off machine with all jams removed and paper loaded, then power on, can you tell us exact error message/lights that are shown in this state?
Oct 15, 2007 | Brother IntelliFax-2820 Laser Fax
Brother fax 2820
Out of the lower paper tray when you go to print? Try this, remove the cassette tray and use a water dampened cloth and clean the gray paper pickup roller off. A lot of times this has paper fiber build up that causes the paper not to feed. The printer has a certain timing pattern for when paper should reach a certain sensor, and if it doesn't, then a jam error will occur.
Jul 18, 2007 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFax-2820 Laser Fax Logo
774 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
