There is an access panel in the front lower
right remove that there is a big nut thing in side unscrew it and clean
out the filter trap
Sounds like a problem with the door lock, door switch or the door switch actuator. Door lock is usually a single assembly with the switch. Check the pin on the door first. Model # is probably mistyped, won't come up, so can't tell anything specific.
thanks for the reply i got a new door lock today and its still the same
the last time i had this problem it was the brushes
but they was only replaced 3 months ago im sure they cant have gone again
as i checked them and they got more than enough left to continue to work
and the reason why it dont come up is cause if u search for the model without the /s u will find it as im sure the /s is just for its colour
it makes no difference if i clean the filter trap it still is the same
nothing makes a difference
so ive got whirlpool coming out to look at it
but thanks for all the help
