Question about Kenmore 24032\24036 Top Load Washer
My washing machine keeps leaking from the bottom
We changed the hose but it doesn't seem to solve the problem. What could the problem be all the water comes out on the bottom and several times has flooded the kitchen WASHING MACHINE LEAKING FROM UNDERNEATH.
  • 3 more comments
  • Anonymous Dec 30, 2007
  • mandtkeller Dec 31, 2007
    I have the same problem. Hoses are fine and it only seems to happen in the "super load plus" setting. I think the water is splashing out of the drum.
  • mike2747 Jun 13, 2008
    found water under my washing machine what could be the cause i dont see any leaking hoses
  • Toby Norton
    Toby Norton May 11, 2010
    What brand of washer is it? If it is a maytag, take the lower front panel off, you may find the water coming from the center of the machine. That would indicate a bad bearing. If it is a sears, kenmore, roper, estes, or newer maytag, you may have a leaking pump. Tilt the machine back and there will be a white plastic thing towards the front of unit with 2 black hoses going to it. You could have one of these hoses leaking or the white peice (the pump) itself may be leaking.
  • Anonymous Mar 18, 2014
    Hose spills water when filling
  • 246 Answers
We have not heard back on this in about a week. I'm presuming It's been repaired?
Posted on Jun 21, 2008
My washing machine is leaking water from the flood hose. What is causing this and what should I do to fix it.
Posted on Feb 22, 2008
  • 196 Answers
For me there is not enough information. What hose did you replace and when does the machine start to leak ?
Posted on Jan 02, 2008
2 Suggested Answers
SOURCE: My washing machine keeps leaking from the bottom
Posted on Mar 31, 2008
03 explorer the right hose to the heater core is hot the left hose is cold. I loosened the left ( cold hose ) and bled off some water and air the heater started warming but not hot so took hose completely...
When you released the cold end, it probably blew out some residue. Remove both hose from the engine and blow it out both ways with a water hose or air compressor. Add water each time, with air. Do this several times. I blow them into a box to see what comes out and when it stops coming out. This helps. Next would be replacing the heater core..All day job for me. I've done it. You have to remove the entire dash board and plenum.
Feb 17, 2015 | Cars & Trucks
There are several causis from water leaking from the back of the fridge did you check is not condensation? In case you will need to lower fridge temperature
Feb 24, 2008 | Whirlpool GS6NBEXR Side by Side...
Hello Harlan;
My name is Peter. I am a retired field service appliance technician.
Your drain hose is in the back on the right hand side. This is a rubber hose. After a time the rubber may be dry rotted and leak or become partly clogged with soap residue.
Once completing the wash cycle the soapy water may have not completely drained due to a partly clogged drain hose by the time the rinse cycle is complete flooding the washer drain pan.
You do not have water in the bottom of the washer because your pump removed it all, but at a slower rate
Ok, Lets fix this ourselves:
1.) On the bottom right front of your washed is a leveling leg.
turn the leveling leg one full turn clockwise. The right front may be pitched down, causing the drain pan level on this corner to be high. Your washer through vibration may have moved slightly. This is not going to solve the problem.
2.) Pull your washing machine out so you can see the drain hose. Run some laundry on heavy load. Observe to see if your drain hose is leaking. Your hose clamps may be loose and require tightening. If it is leaking it needs to be replaced.
3.) Even if your drain hose is not leaking it must be obstructed, flooding the bottom of your unit. This is easily replaced.
The part number for your drain hose is DC97-12534D. It cast about $24.00.
Nov 24, 2014 | Samsung Washing Machines
My GE washer leaks water during spin cycle only, seemingly from bottom of valve(?) where water hoses hook up, hoses look to be in good shape, only a year or so old.
If it is leaking at where the drain hose comes out of the wash machine, make sure the plastic spider clamp is seated securely in the groove on the drain hose. If that's not it, then, yes, you'll need to open up your washer to gain access to the inside of it. I don't know which model GE wash machine you have, but most of the GE top loaders can be opened by following the instructions in this youtube video:
Oct 19, 2014 | Washing Machines
Water runs out at the bottom of the front cover of the machine and doesn't spin properly?
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occur. Removing and cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Tips for leak:
Jan 17, 2013 | Washing Machines
My Bosch washing machine is leaking from the bottom of the right hand side of machine when not in use.
g'day, sounds like the leak is coming from the hose - this is because the leak is occurring when its off. Check seals on hose at the back of machine. You can always find old sets of hoses as well (or buy them), so you can try swapping them over. Keep in mind, with washing machine hoses (like gardening hoses), the seal is at the rubber washers not the thread on the tap... so plumbers tap will not stop a leak, it will hinder the seal.
An alternative solution is simply turn tap's off between washes...
Aug 07, 2011 | GE WWSR3090TWW
My model is Frig. Dehumidifier, 70 pint. model # LAD704DUL. I hooked up the hose for continuous operation, but the bucket fills up too, even though water is definitely coming out of the hose. It...
Check the float valve in the top of the bucket. It may be stuck in the UP position. If that the case, jiggle the float valve arm to get it to return to the DOWN position. That should solve the problem.
Jul 10, 2011 | Frigidaire Dehumidifiers
My dishwasher is showing error code a10 model ide 1005
Hi, the interpretation for error code A10 is: A10 = fill solenoid valve triac closed/open circuit - check valve/ operation - machine drains until level switch resets + 30"
Now, to try and solve the problem yourself: Turn off the water supply to the dishwasher & remove the hose, Run the machine for several minutes in a normal position. Turn the machine off, reconnect the fill hose, turn the water back on then turn the machine back on.
If this doesn't solve the problem, then you'll need to call a service person.
Jun 12, 2011 | Dishwashers
Kenmore 24032\24036 Top Load Washer Logo
497 people viewed this question
Sal De
 Brian Main
Brian Main
