Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
Wont release liquid or shampoo.
I have a Bissell pro head 2X steam cleander model no 9300-C
The little plug at the bottom of the bad for clean watter came apart and would not let water out now wont hold it in.
Inside is a little propeller a spring a washer and a little black plug. Flat on one side and beveled on the other. We have tried to put it back in various selection and cant fix it please help ASAD
    President:
  • 1,673 Answers
May be better to just replace it, CAP & INSERT ASSEMBLY - WATER TANK
Shouldn't be more then $5.
2036675
Posted on Jan 08, 2008
2 Suggested Answers
Agent Don
  • 310 Answers
SOURCE: Wont release liquid or shampoo.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618960&thid=601973
Won’t release liquid or shampoo.
Posted by lilmrsmcd on May 16, 2008
I have a Bissell Pro Head 2X Steam Cleaner Model # 9300-C
The little plug at the bottom of the bad for clean water came apart and would not let water out now won’t hold it in.
Inside is a little propeller a spring a washer and a little black plug. Flat on one side and beveled on the other. We have tried to put it back in various selection and cant fix it please help ASAP liquid bladder will not release water.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Bissell 9500 ProHeat 2X Clean Shot Upright. On the little black plug – they do wear out and need to replace it but use a genuine Bissell part when replacing the part other wise a replacement may not work. Q. #2 the little propeller spring usually is part of the solution tank and it is wise to replace the part with a new or a good used tank from Bissell, so check with your local factory authorized vac dealer that carries and services Bissell. I will give you the Bissell factory phone # listed below for further questions. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.bissell.com/ Customer Service 1-800-237-7691
Hours of Operation Monday thru Friday 8:00 am to 10:00 pm EST
Saturday 9:00 am to 8:00 pm EST
Mail To: Headquarters, Bissell Homecare Inc
P.O. Box 3606 Grand Rapids. MI 49501
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on May 30, 2008
Bissell 9300 m pro heat turbo 2x . i need the hose diagram for my machine please
I have had problems with the little red clips that squirt the water getting clogged, tiny little holes! I had to remove them and use a needle, then blowed them out with air compressor. I am also trying to find a diagram for this 9300-M model but cant find one.
Aug 26, 2010 | Bissell Vacuums
Wont spray
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
bvnvn
Jul 18, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
My Bissell Pro Heat 2X steam cleaner is not releasing the water
Have you tried cleaning out the small filterfrom the reserve tank? Also, check the tank/resevoir valve is operating properly, when you take it out to fill try to make water release from tank.
Apr 29, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Bissell Pro heat 2x the shampoo tank empties out
the o-ring is likely dislodged on the screw on cap
personally I would recommend just filling the soap container with water and a little bit of white vinegar instead of the detergent. You won't leave soap residue in your carpet that way.
Dec 22, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell steam cleaner will not spray shampoo
My Bissell stops releasing shampoo when the handle is lacked upright, when there is no water in the tank (the most common cause of this issue), or when water is not flowing through the machine because the sprayers are clogged.
Make sure the shampoo container grommet is releasing properly when you press the trigger. To check this, remove the shampoo tank from the Bissell, stand over a sink, and use a finger to push up inside the grommet on the shampoo container, the part of it that mates with the rest of the Bissell. Shampoo should dribble out when you do this. If it won't, the grommet may be clogged.
May 29, 2009 | Bissell 7950 ProHeat Upright Wet/Dry...
BISSELL PRO HEAT X2 CLEAN SHOT
Try checking the lint filter. It is located in the top clear plastic section (the one with the dial to switch from floor to tool use) and is on the underside. It is a small (1 inch square) red plastic filter with a little door on it. Open the door and you will probably find it is clogged with hair, carpet fibre., etc.. Clean this out and you will hopefully have suction again.
Nov 19, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Go Ahead. Use Us.
May 16, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
154 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
