Kenmore washing machine
Out of balence
    Sergeant:
  • 288 Answers
If its out of balance when empty, the most common problem for this brand is the mount or the spring on 1 of the 3 stabilizing struts has come off. pull the shell off the machine and look for a spring or screw that has come off. Replace.
Posted on Dec 26, 2007
Water Sprays Upward & All Over - On The Floor - HELP
Have you checked the hose in the back it might be loose and it sounds like it is out of balence check the little feet that screw out and make sure its balenced and be sure not to over fill with clothing it may need to be rebalenced the drum
Nov 16, 2013 | Crosley Washing Machines
Kenmore elite type 580 no: 27087603 works well machine has been leveled and load is balenced yet it sound like theres a train running past in your back yard ' why so loud
Lol, the spin cycle on them is so powerful it will walk around your uitlity closet. Unly suggestion is to use wood or some other wedge to make a tight squeeze between the machine and the wall. This will keep the spin from allowing the machine to move or make loud noises.
Sep 20, 2012 | Refrigerators
I have a problem with the counter balence, the machine always shakes even though I have it balenced
check to make sure the levelling legs are locked into place. once levelled, there is a nut that needs to be cranked up to teh case to prevent them from coming loose again
Apr 04, 2010 | Frigidaire ATF6000ES Front Load Washer
I HAVE A KENMORE OASIS HE WASHER MODEL 110.27092601. WHAT MAKES IT SEEM AS THO IT BEATS THE WALLS OF THE MACHINE CABINET WHEN IT SPINS IT ACTS AS THOUGH IT IS OFF BALENCE
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 19, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Hi i have a kenmore washer est 7 year old about 4 mont. ago it started shaking bad and walkes all over. no mater how big the load is .is there a censer in it for balence
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
Check the components in the Machine Base section.
It's possible that one of the springs has broken or slipped from its' hook.
It's also possible that one or more of the three Base Pads which allows slippage between the top and bottom frames has broken.
Sep 24, 2009 | Kenmore Washing Machines
Washer and dryer where installed today. Stackable 3000
hi your sheets need to be even in the wash or it will fined a wobel out of balence cheers peter
Apr 05, 2009 | Maytag LSE7806A Top Load Stacked...
did the rod come out with the yellow strap when you pulled it???
if it did i would call sears they may have a strap issue that they need to know about the rod should have came out when you pulled the strap
also you need to grab hold of the console and pull it up till the rear legs come off the floor so that the rear leveling legs can reset then sit it back down and it self levels
hope this helps let me know if you need any more help
Jun 23, 2008 | Kenmore Elite HE4 Electric Dryer
Washing machine
cheak see if its balence and overloadingit
Feb 03, 2008 | Whirlpool LSB6200KQ Top Load Washer
Washer tub bangs
Click on "troubleshooting" above and type "banging" after clicking "find solution", i have a couple of postings there. You could also read others.
Dec 02, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
70 people viewed this question
Top Washing Machines Experts
