Question about Compaq MP2800 Microportable Projector sps Projector Lamp
Compaq MP2800 DLP Projector
Hi, Can anyone help me out with fixing a fault on this projector. The projector powers up fine and works for approx 5 minutes then shuts off, fans still run then the light comes back on after approx 2 mins and it goes through the cycle again. The bulb is fine and has been replaced. Its not getting overly hot so i don't think its actualy overheating. If anyone can offer some insight or has a service manual they could email me, I would be very gratefull. Thanks in advance, Jon I have the same problem
    Sergeant:
    Champion:
  • 347 Answers
Hi bitritto,
The user guide for your Compaq MP2800 DLP Projector is this one:
http://www.aboutprojectors.com/pdf/compaq-mp2800-manual.pdf
There you will find assitance and help for your problem.
I hope you can find your solution.
Posted on Dec 26, 2007
  • Santiago Vallejo
    Santiago Vallejo Dec 26, 2007
    Yes bitritto, Szwaan might be right. Check your power cord and try using by connecting it to one outlet. and remove other sleeves from that outlet.
  • Santiago Vallejo
    one last thing, check here:
    http://www.aboutprojectors.com/Compaq-MP...
    The specifications of your product.
    Sergeant:
    Champion:
  • 209 Answers
If the projector is not getting a source it might go on standby maybe check where you plug it in.
Projectors require quite a bit of power and should be on a single loop/outlet not hooked up to a powerbar with more things on it.
Hope that helped.
I have two dlp infocus X2 projectors. Both of them have lost their color. Is there something I can do to fix it?
This could be one of 2 things. It could have a bad color wheel or there is a setting problem in the unit. If the video mode is not set correctly like NTS or PAL it can give a black and white image.
The other could be your color wheel has failed. Did the unit make any noises before the color went out?
Some times the color wheels will make noises when the age before they crack or break from the heat.
I believen you can pull the lamp out and with the lamp out try and power the unit up, look into the little hole the lamp shines into and see the color wheel spinning. when you first plug it in and unplug it the wheel should spin and you should see the colors change. DONT TOUCH THE COLOR WHEEL they are fragile and can break easy. Some get more brittle over time from the heat of the lamp.
May 19, 2010 | Compaq MP2800 Microportable Projector sps...
it might be a problem with overheating, have you ever cleaned the projector? there might be alot of dust blocking the airflow.
If that doesnt help let me know.
Apr 15, 2008 | Compaq MP2800 Microportable Projector sps...
Infocus X2 projector
resolution changes. if you hit auto image, that should correct it.
Sep 03, 2009 | Compaq MP2800 Microportable Projector sps...
My compaq projector goes into standby mode after about an hour of watching....
the device gone warm which may cause follwing reasons:-
1. it may cover with somthing.
2. used in warm environment
3. heatsink/fan gone out of order
good luck
Jan 02, 2009 | Compaq MP2800 Multimedia Projector
Need ac adapter for Compaq projector
Hi Tech Lady , greetings !!
Your projector has a "Multimedia Adapter" .
You can purchase the adapter from www.trademoon.com or directly from HP.
Trademoon is a discount supplier of new and refurbished Compaq and HP parts.You can call them at 97
2-682-5000 or log on to www.trademoon.com
Or you can also call HP/Compaq at 1-800-474-6836 and say "SPAREs"
The specifications of your adapter is :
Power Consumption 5 Watts (standby)/185 Watts (full power)
Power supply 90V to 255V (auto switching): warm restrike after 45 seconds
Goodluck :)
Jun 04, 2008 | Compaq AC Adapter Projector Lamp
Compaq MP2800 Lamp powers down after a few seconds
Hi Wayne
It is normal for the lamp's fan to start running , but should actually happen within 15 seconds of starting up. Try changing the lamp's fan and if the problem still persists then you will have to replace the Ballast ( lamp's powersupply )
Mar 22, 2008 | Compaq MP2800 Multimedia Projector
Compaq MP 2800
Have you tried cleaning ther bulb housing and fan area with a soft brush and vacuum?
Dec 26, 2007 | Compaq MP2800 Microportable Projector sps...
X2 infocus projector
make sure u have the lid back on or wont come on for the lamp
Nov 11, 2007 | Compaq MP2800 Microportable Projector sps...
Compaq MP 2800 Micropotable Projector
I had the same problem!  The problem is dust on the color wheel.  At side of the color wheel is a wire connector attached wit one small screw,  with a cottom tip clean the small lens  and surface, that's all. Put the connector and screw  and it will OK!!
Oct 10, 2007 | Compaq MP2800 Microportable Projector sps...
506 people viewed this question
Top Compaq Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Computer Links
Are you a Compaq Office Equipment and Supply Expert? Answer questions, earn points and help others
