Question about Panasonic KX-FHD332 Plain Paper Thermal transfer Fax
Incoming documents are too dark
How do you change the darkness of incoming documents on the above fax machine
    Genius:
  • 2,120 Answers
Your thermal head seems to be going bad. No fix for it.
Are they dark when you make a copy?
Posted on Sep 26, 2008
I need to lighten print on my richo2210L fax machine
To adjust the contrast, Press Darkness. Each time you press the button, the LED labeled with the selected mode turns on. You can choose from the following darkness modes:
1>Lighten: works well with dark print.
2>Normal: works well with standard typed or printed documents.
3>Darken: works well with light print or faint pencil markings.
Dec 07, 2011 | Office Equipment & Supplies
When sending fax, the reciever get a blacked out or very dark page. However when we recieve incoming fax, it's not dark at all. But if you copy a page , it is very dark.
hello, if you have already cleaned the contact image sensor, or cis unit, its located between both rollers when you lift up the top cover that has the buttons on it. sometimes, this cis/contact image unit fails, and will need to be replaced.
Oct 05, 2010 | Brother IntelliFAX 4750 Plain Paper Laser...
Why are all my incoming faxes all black pages?? Is it my fax or the senders? Very hard on the ink cartridge
hard to determine the problem without any make/model of your fax machine. However I would begin by looking at the fax contrast and darkness settings, they are likely cranked to the dark side. If you cannot find these settings or this doesnt help. post your make/model information. I don't believe this should affect sending faxes, its likely just a print / contrast setting for received faxes.
Aug 29, 2010 | Office Equipment & Supplies
I have a HP Laserjet 3015 fax machine connected to a phone line but not a computer. When I send a fax or make a copy a dark vertical line appears on each page. Incoming faxes print with no line. I have...
The fax scanning unit/encoder is dirty.
The fax scanning unit is like a camera. It take a picture of the document.
The glass plate is dirty and you may purchase a FAX CLEANING SHEET.
Officedepot
http://www.officedepot.com/a/products/470251/Office-Depot-Laser-Printer-Cleaning-Sheets/
or similar product to clean out the dirty area.
The dark strip is cause by semi-dry wipe out correction ink.
Give your unit a good cleaning and let me know.
Jul 08, 2010 | HP LaserJet 3015 All-In-One Printer
Dark band on left hand side of incoming faxes
Your toner cartridge is leaking toner onto the transfer roller. There is no cure except for replacing the cartridge.
Dec 10, 2009 | Panasonic Panafax UF-595 Plain Paper Laser...
Incoming faxes are too dark
u r using refilled cartridge?
remove the drum unit and u can find one blue lever on the right side of the drum unit . slide it 4,5 times then put it back . take a test copy
Jul 15, 2009 | Brother IntelliFax-2820 Laser Fax
Lazer Jet 3150 fax machine out going faxes have 2 lines on them
I went online and printed out the methods to clean the fax machine and lo and behold it worked
Mar 30, 2009 | HP Office Equipment & Supplies
Printing Faxes
try another drum unit.
Jul 02, 2008 | Brother MFC-8220 Fax
Panasonic KX-FP153 Copy too dark
Try unplugging the power cord and re-plugging. It sounds like your scanner assembly is going bad.
Jun 17, 2008 | Panasonic KX-FHD332 Plain Paper Thermal...
Brother Intellifax 2800
How do the copies look? Most commonly dark print is caused by defective generic supplies or dirty laser scanner.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Aug 15, 2007 | Brother IntelliFax-2820 Laser Fax
Panasonic KX-FHD332 Plain Paper Thermal transfer Fax Logo
108 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
jasbo
jasbo
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
