Bosch 24 in. SHE44C02UC / SHE44C06UC / SHE44C07UC Built-in Dishwasher
Problem for Bosch 24 in. SHE44C02UC / SHE44C06UC / SHE44C07UC Built-in...
Water does not drain
By grwshop on Oct 13, 2009
does not
Best Solution
posted on Oct 13, 2009
Helpful)
TheMazz
Rank: Guru
Rating: 93%, 46 votes
For the water to drain, the controller must send power to the water pump and the solenoid (drain) valve.
If you hear the pump running when it should be draining then the controller and pump are working and the solenoid is bad (usually the case).
If you don't hear the pump running during the drain mode, then either the pump is bad or the controller is bad (not sending power to the pump).
Also, check that you do not have debris inside the dishwasher where the water drains. This is around the spindle in the bottom of the dishwasher cabinet where the spray arm comes up.
If this helps you, please select YES to one of the first two ratings questions. Thank you, and Good Luck.
Was this helpful?
Yes
No
3 people thought this was helpful
Popular Solutions for Bosch 24 in. SHE44C02UC /
Questions and Unsolved Problems for Bosch 24 in. SHE44C02UC /
Do you recommend Bosch 24 in. SHE44C02UC / SHE44C06UC / SHE44C07UC Built-in Dishwasher?
Answer
Answer
there was a short in the junction box. i fixed that by stripping wires and installing new wire nuts.... (More)
Answer
The dishwasher runs to 1 minute and keeps running. it does not advance to dry cycle.
Answer
How do I remove the soap dispenser from a Bosch dishwasher? It will not lock closed.
Describe your Dishwashers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dishwasher Experts
Top Dishwasher Repairmen
in , CT
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 803-6775
Manage my home, all the technicians you need at...
Manage my Home
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
