Static from left speaker when adjusting volume control
I get a lot of static from my left speaker when I adjust the volume control. Any idea sas to what could be causing this?
Thanks!
  • 4 more comments
  • Carina2 Dec 26, 2007
    Thanks! I'll give it a try:-)
  • mcmontgom Sep 01, 2008
    i have a infinity entra 150 watt sub when you adjust the volume on the back there is dead spots between 5-7 on the knob . i thought it might be dust in the control. it works on other levels. not sure what to do.
  • zplotz1328 Feb 07, 2009
    The left speaker goes on and off, i think it could be the wire because when i turn the wire it sometimes stays on but now it really just doesnt work
  • funraizer Mar 30, 2009
    i have the same problem but the left speaker is now completely dead. i opened the speaker, removed the board with the pots and input on it and brought it to my local electronics shop to get a replacement pot. they couldnt identify a replacement part because the 'a103' stamped on it giives no indication of the kind of pot it is. im currently looking for a schematic for the speaker. downloading the manual from numark site at the min. if anoyone has one or could give me a part number it would be much appreciated.... cheers.... Rob :)
  • Anonymous Mar 17, 2014
    Damage volume control for the speaker on the left side.
    no sound on the left speaker control
You might try replacing the connection cables. Old cables can cause the problem you have experienced.
Posted on Aug 03, 2009
    Scholar:
  • 36 Answers
Hello Carina2,
Given the description of your problem, the volume control potentiometer needs cleaning or replacing. It should be a fairly easy operation for a technically inclined person to give it a good cleaning. Let me know if this helps.
cancerags
Posted on Dec 26, 2007
Left channel static
I have seen dirty switches or pots cause constant static. I would get some contact cleaner and try spraying it into all switches and pots, and work them to clean the contacts. Also, check to see if there is static in a low-level output such as the one for a tape recorder.
Mar 29, 2014 | Marantz Audio Players & Recorders
My pc left speaker does not work. but in other devices speaker works
click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume
click start control panel sounds and audio volume advanced speakers select the appropriate speakers
from the drop down list or navigate to the device manager scroll to system devices + to expand system
speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line or use a can of compressed air specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
or if its a desktop swap the speakers around if one still does not work its either a faulty speaker or the speaker connection
hope this helps
Aug 21, 2012 | Intel Desktop Board DG41WV Motherboard
Sound is very low
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit
hope this helps
Jun 14, 2012 | Asrock 775Dual-880 Pro Motherboard
Audio cable diagrams
could be a broblem with your sound card and its drivers
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have the correct settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
hope this helps
Apr 17, 2012 | ASUS P4GE-MX Motherboard
I can not adjust the volume
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume adjustment you will need to right click on the volume icon depending on your operating system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
Jul 22, 2011 | Audio Players & Recorders
My speaker system was humming loudy and now only makes a loud static noise.
you might have to uninstall then restart your computer then reinstall both the drivers and the sound devices
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers or right click select properties to either troubleshoot,uninstall,rollback driver
or
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Feb 02, 2011 | Altec Lansing AVS 500 Computer Speakers
Why would my car stereo sound staticky when i give it volume'',it was not like that earlier
first adjust the fade and balance, checking each speaker for this issue. if they all continue to cause static when turning up the volume, then it is either the connections are crimped poorly, speaker connections are not secure at speaker or just a faulty volume control knob
Feb 23, 2010 | JVC Car Audio & Video
There is a loud hum when volume is on low to high
go to control panel
sound and audio devices
voice
under voice recording clk volume and mute the mic phone...........
or
some how your mic is conflicting with speakers. Keep your mic away from your speakers..
Do reply if this woks
Oct 03, 2009 | Bose Companion II Computer Speakers
I have lots of static on one of our vx8300, can anything be done?
try turning the speaker volume down by adjusting the volume with the volume switch on the side of the phone during a call,
otherwise it is just maybe a bad speaker
Sep 22, 2009 | LG VX8300 Cellular Phone
Speaker problems
You've probably tried this, but when you do the channel test you can turn the volume up or down on whichever speaker is currently being tested (the static). Maybe your speakers have been adjusted somehow.
Jun 08, 2008 | RCA RT2300 System
1,783 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
