Question about IBM ThinkPad T42 Notebook
USB Ports not recognizing installed devices
I have a T42P laptop with windows xp pro 2002 with service pack 2. When I put in a USB device it does not recognize it. In Device Manager, it says all the USB controllers are working properly, and that the USB Root HUB are all ok. I am so frustrated. HELP
  • Anonymous Apr 01, 2014
    I have installed Windows XP service pack 02 on my Samsung sens x05. Then I plugged in my USB dongle in order to install it's drivers. The dongle is working (Huawei E320) and it's bulb is blinking. But the laptop does not recognize the dongle and there were no any message saying found new hardware. Also the VGA and sound drivers has not been installed. I have tried to install them with a driver pack. But I was failed. Please help me to solve this problem.
    Sergeant:
    Champion:
  • 310 Answers
Did it come with xp pro or home? pro does'nt have the drivers that home doe's. use a home disk to update the drivers with
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Posted on Dec 30, 2007
LaCie is not visible in My Computer Windows XP Service Pack 3 Vaio laptop
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.
Then restart computer then check.
Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4
if still no luck
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
May 13, 2012 | Computers & Internet
Gateway 310 s won't recognize a cd
Method 1: Initiate recognition of the USB device by using Device Manager loadTOCNode(2, 'workaround'); To initiate recognition of the USB device by using Device Manager, follow these steps:
1. Click Start, click Run, type Devmgmt.msc, and then click OK. The Device Manager window opens.
2. Click to select your computer as the location for the scan.
3. On the Action menu, click Scan for hardware changes.
Windows XP recognizes the new device.
4. Close the Device Manager window.
If this method resolves the issue, you are finished.
If this method does not resolve the issue, go to method 2.
Method 2: Disable power management of the USB hub loadTOCNode(2, 'workaround'); Note If you perform the following procedure, you may also reduce the battery life on a portable computer.
Use this method if method 1 does not work. To disable power management of the USB hub, follow these steps:
2. Expand Universal Serial Bus controllers.
3. Right-click a USB Root Hub in the list, and then click Properties. The USB Root Hub Properties dialog box is displayed.
4. Click the Power Management tab.
5. Click to clear the Allow the computer to turn off this device to save power check box, and then click OK.
6. Repeat steps 3 through 6 for each USB Root Hub in the list.
7. On the Action menu, click Scan for hardware changes.
8. Close the Device Manager window.
If this method does not resolve the issue, go to method 3.
Uninstall all the usb controller from USB controller
and now restart the computer.
If this method does not resolve the issue, go to method 4 .
Method 3: Restart the computer loadTOCNode(2, 'workaround'); To initiate recognition of the USB device, first unplug the USB device and restart the computer. Then, wait five to ten seconds before you plug the USB device into the computer or hub. Windows XP recognizes the new device.
Hope this helps.
Jan 14, 2011 | Gateway 310 S PC Desktop
Sandisk micro 2 gb not recognised on win xp laptop works on other machines. pls help
Sometimes windows XP doesn't install the driver to recognize your USB ports. For example, a fresh install of XP does not contain any driver for sound or graphics. The best way is to update your windows XP up to Service Pack 3 by installing SP1 and SP2... etc, it will take a looooooooong time, but your PC would be better.
To check whether or not you have any USB drivers install just go to control panel and then device manager. Look for Universal Serial Bus (USB)
Sep 28, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
My computer which is running Windows XP pro 2002 does not recognize my San Disck cruzer 256 mb memory key. The light flashes upon inserting in to computer and then goes out and then I get message that CPU...
try to disconnect all usb devices and install it again to another port also try to install it on another PC if it workson another PC and yours not then try to remove ur O/S and install a good one like windows Xp SP2
Jun 15, 2009 | SanDisk 4GB microSD High Capacity Memory...
Acer extensa 5620
i have laptop acer extensa 5620z, install windows xp professional os 32 bit, inside device manager open that time
Ethernet controller
Ethernet controller
Mass storage controller
Pci device
Pci device
SM Bus controller
Universal serial Bus (USB) controller
biling the yellow(!) mark, and usb device put in the usb port not open how to solve this problem, please reply me, thankyou,
my email senthil_japan@yahoo.com
Jan 26, 2009 | Acer Extensa 5620 Notebook PC
Computer does not recognize the Insignia NS-2V17
The problem is after service pack 3, xp pro does not recognize MTP devices any longer
  • Click on the Start button and Select Settings. Then click on Control Panel.
  • Double click System, and then select the Hardware tab.
  • Click on Device manager.
  • Click on the '+' for Portable device and you will see "Insignia Video Player".
  • Right click and select "Update driver".
  • A Hardware Update Window will open, Check the "Install from a list or specific location" checkbox and then click next.
  • On the next screen select "Don't Search. I will choose the driver to install".
  • Click next and then you will see a window showing multiple drivers, Select the "Portable Devices" driver and you can select MTP or USB mass storage.
  • Select "USB Mass Storage Device" and click next.
  • XP will finish installing the driver and you MP3/video player will appear and your device will now appear as a hard drive(s) (if you have a memory card) on your system.
  • Windows Media Player and other application will now recognize your device.
Jan 08, 2009 | Insignia NS-DV2G MP3 Player
Device Not Recognized
This problem mainly occurs because Sony does not support connection though Hubs or for that matter Front Panel USB ports. Try connecting the camera throught the back panel ports (There are usually four to six of these depending on your motherboard.) .
If it still remains unresolved:
1. Update windows XP to atleast service pack two (If you havent already). Uninstall Picture Motion Browser.
2. Uninstall the camera from the device manager.
This is how to do it. Connect the camera, wait for it to show as an unrecognised device. Hit "Windows + Pause/Break" to bring up system properties. (Windows is the key next to alt, that brings up the start menu.). Navigate to the hardware tab and choose device manager. Expand the last tree from the list (One for USB devices) and delete the entry "Unrecognised Device" (Select it and hit delete). Shut the device manager. Disconect the camera.
3. Now, connect the camera the one of the USB ports on the back of your PC and power it on. It should show up as a PTP/Mass storage (depending on your camera settings) device.
4. If it still doesn't work, disconnect all other USB devices from your PC and then repeat from step 2.
5. You can reinstall Picture motion Browser if you like or use Xp's photo transfer utility.
Hope this solves your problem.
Cheers,
Shaunak
Dec 19, 2008 | Sony Cyber-shot DSC-S730 Digital Camera
Usb 2.0
this is a common error with operating systems and devices.
If you go into my Computer/system/device manager. And remove the installed USB devices. shutdown the computer, and reboot it. then try putting your USB device in.
What general happens, is that if you have had an older device in the USB port at any time, the port configures itself to this setting. options are to try another port on the computer ( some older ports only support usb1.1 )
ensure you have up to date drivers on the connecting device and on the connecting computer.
Hope this helps Mike @ Compurepair.
Feb 22, 2008 | ASUS M2A-VM (0610839149438) Motherboard
USB2 high speed not recognize
Try opening up the device manager and unistall everything in the Universal Serial Bus Controllers. Then reboot and let windows reinstall the USB controllers. Windows should now be able to recognize properly USB2 devices.
USB plug in recognition
Hello Silvertop01,
This is Romeet, id like to help you with the problem. Unfortunately it seems a lot of things that you love :) wont work right? well, Let me know if you are running windows xp with what service pack? service pack 1 or service pack 2? to do this, right click the icon " My Computer " and select properties,a system properties dialog will open, on the top right you should be able to see:
System:
Microsoft Windows XP
Professional / Home ( Depends what you have )
Version ( 2002 )
Service Pack X ( X could be 1 or 2 )check this and let me know
B.Regds
Romeet
Nov 30, 2007 | Dell Inspiron B130 Notebook
IBM ThinkPad T42 Notebook Logo
339 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
