Question about Polaroid TTM-2401 TV
Power will not come on
TV will not power on.
  • Anonymous Mar 29, 2008
    Yes the same tv will not power on for us. One year old. Most places say they won't even try to fix it.
  • Anonymous Apr 15, 2008
    se apaga
  • 525 Answers
EEEEEEEEh check the power supply, from your power cord , fuse, rectifier bridge diode, whith out forget that the old TV got the bad connection in old solder!!!!
Posted on Sep 24, 2008
TV will not power on. Red light flickers sometimes when I try to turn it on.
TV Will Not Turn On - Troubleshooting Help for Finding ...
? 2:32
May 1, 2014 - Uploaded by
TV Repair Help for a TV that Will Not Turn On - Troubleshooting Tips for finding symptoms and causes of ...
SONY ' eSupport - The TV will not turn on or does not have ...
Aug 15, 2015 - The TV may not turn on if there is a power issue. Often power issues are caused by a drop in voltage in an electrical power. The power outage ...
TV has power but will not turn on - Page 2 - Community ...
Feb 1, 2015 - Our tv has power to it but will not turn on. The red light in the corner is lit but when we try using the remote or the power switch on the unit.
32" LCD Flat screen TV, no power, can someone help save it ... > Forums > Miscellaneous > Off-topic Chatter
Feb 2, 2012 - 20 posts - ‎10 authors
The tv will not power on manually or with the remote, there's no clicking noise, no LED light on the front, no signs of life. There is no obvious ...
TV Will Not Power On
Jan 26, 2016 | Televison & Video
I am unable to power on this TV through the remote or TV power button. Do not get a green light for power. Should I look for replacing a power supply cord or the power unit within the TV?
Hi Liz, You are not getting The green light means either the power ie AC is not reaching the TV or the power supply section inside the TV has broken down. Your guess is right about the power cord and the power unit within the TV.The Problem will be there within your guess. But I think you will need the help of a good technician to isolate the fault and rectify it. Good luck.
May 02, 2015 | Dynex Televison & Video
How to shut off manually
UN55D6400UF TV Will Not Power Off If your TV is on but will not power off when you press the power button, you could be having an issue with your remote control or a faulty circuit inside your TV.
To determine the source of your problem, follow these steps:
  1. Power the TV on if it is off.
  2. Unplug the TV from the wall outlet for 30 seconds, and then plug the TV back in.
  3. namo_fileview.jsp?type=nfs&pid=decisiontree&did=57355&
    1. Press the POWER button on the remote control.
    2. [img src="" height="51" border="0" width="50">
      • If the TV powers off when you press the POWER button on the remote control turn the TV back on continue to Step 4.
      • If the TV does not powers off then there is a problem with the remote control. Click here to go to the Remote Control troubleshooting section of this guide.
    1. Press the POWER button on the TV.
      • If the TV powers off with the remote but does not power off with the power button on the TV there could be an issue with the touch sensor on the TV. Before setting your unit up for service try these two things.
        1. Try sliding your finger accross the power button.
        2. Have other people try using the touch buttons on the TV.
        3. If either of these two options work then there is not an issue with the touch sensor on the TV. There are many variable that can limit the conductivity of a persons fingers. The conductivity of your fingers might not be enough to easily control the touch sensor on the TV.
        4. If the TV does not power off when you press either the POWER button on the TV or on the remote control, then the TV will need to be serviced. Click the Create online service request button below to have the TV repaired.
Mar 26, 2014 | Samsung UN55D6400 - 55" 1080p 3D LED LCD...
I have a Panasonic Viera TC-P42x5 TV. I had a brief power outage and the TV would not turn back on. no power at all.
I have the same tv. Upon researching how to fix this, I came upon an answer to do a reset. I tried it and it did work! Try doing this: Let's try a hard reset of the TV. To do this, disconnect the set from powericon1.png then press and hold the power button on the TV itself (not the remote), for 10 seconds and release. Then plug the TV back in, and also make sure the power cord connection to the TV itself is secureicon1.png. Then press power once . Hopefully that will do it.
Jan 26, 2014 | Televison & Video
No power
Got no power on my tv need sone advice as change fuse still not working
Sep 07, 2011 | Sansui HDLCD3200 TV
My proscan 42la45h wont get power. no red or blue light
U check the power source like the power a/c outlet?Yes?Tries tv unplug,replug it back like about an hour later.The tv should resetting itself back to the tv factory setting,tv now should have power again.Not.The tv have a power supply board problems and the causes.That the board where the tv power a/c cord plug into it.Tries websites like, to buy a whole new refurbish tv power supply board for the replacement.
Sep 06, 2011 | Proscan 42LA45H 42 in. LCD TV
Tv button on remote does not power on my tv neither does comcast remote
U try to power on the tv by pushing manual power button on the tv itself?Yes,tv still have no power than ur tv have power supply board problems,that the board,where the power a/c cord plug into it.Tries websites like, to buy a refurbish power supply board for the replacement.If it the remote problems call ur cable company for the cable remote replacement.Try website like to buy the tv original remote for the replacement.
Apr 13, 2011 | Sony KDL-37L5000 37 in. LCD TV
I lost power in my house. I cannot get the TV to power up. Is there a reset button? what do I have to do to get power on the TV? All the other components linked to the TV are working.
Now,there is no power to the tv at all?Yes.Tries tv unplug,replug it back like about and hour later.That the resetting tv back to the factory setting.The tv now should be working again.If tv still have the same result,tv power supply board have problems,that the board,where the power a/c cord plug into it.Check the tv power supply board fuse,because u lost main power to the house.If u lucky,the tv power supply board only have a dead fuse,fuse is near where the power a/c plug,plug into tv to get it power.Fuse can buy it anywhere like Radio Shack like $1.50.After u repalced the fuse,if tv still getting the same result,than sorry ur whole power supply board have problems and it is dead.Tries websites like, to buy a whole refurbish power supply board for the replacement.
Feb 23, 2011 | Samsung LN52A850 52 in. LCD HDTV
The tv does not turn on when plugged in. I do not see any lights indiucating any power. ANy suggestions?
your TV is having a power problem. The power supply board is defective that's why the TV won't power up. Its receiving power but it cannot transfer the current to the necessary part of the TV because a capacitor, diode, etc may have been faulty. Until these bad components are replaced, the TV might not come on.
This may have occurred as a result of power surge/irregular power supply or excess power that may have entered into the TV previously.
If you know about TV repairers, I would suggest that you open the TV and read the power board/panel with a meter, detect the bad component and replace it. Take note that TV stores a lot of current that can shock, so leave the TV for a while before you open it.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you.
I wish you good luck.
Nov 24, 2010 | Toshiba 32AV502U 31.5 in. LCD HDTV
No power to the TV! Outlet is fine, just no power will get to the actual TV.
Try unplug,replug tv an hour later,let the tv resetting itself back to the factory setting,the tv should have power and work now.Not,than the tv power supply board is dead.That the board,where the power a/c cord plug into it.Try website like to buy a refurbish power supply board for the replacement.
Oct 25, 2010 | Vizio VP322 32 in. Plasma TV
Polaroid TTM-2401 TV Logo
99 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
