Usually this means that your LCD panel in your TV is bad. The only way to fix it is to replace the LCD panel.
If you can get a hold of the T-con board, which is part of the LCD panel that decodes the signal form the main board, then replacing that will save you some money and should fix the problem. The LCD panel is very expensive and usually exceeds the cost of the TV.
