Question about Fuji FinePix A500 Digital Camera
Red Eye Hello, my camera takes awesome pictures except for the fact that all the pictures have terrible red eye!  How do I fix this?
Does your camera's flash have a redeye reduction mode? It should tell you in your camera's manual. Some cameras use a pre-flash method which causes the flash to fire several times in succession before firing the shutter in order to give the subject's eyes time to adjust to the bright light.
Redeye is actually caused by the flash being too close to the camera's lens. That's why you see professional photographers using a flash attached to their cameras by a cable so they can move it away from the lens. Because you have a compact camera, there is no way to change this flash to lens distance.
You might also try just turning the flash off. Unless you are taking pictures in a very dark area, you may find the results to be very satisfactory.
Posted on Dec 30, 2007
Red eye on sanyo digital camera xacti,always theres a red eye when taking pictures,i already adjusted everything,still occuring red eye.
Do you mean your subject's eyes are showing "redeye"? This is a common problem with cameras that have the flash very close to the lens. Almost every photo editing program has a tool to remove red-eye. Check your computer to see what you have installed. In the future, most cameras have a red-eye flash setting which shoots a short flash before the main flash to close down the pupils in your subjects eyes to eliminate red-eye. You could also turn up the lights in the room...sometimes that helps.
Apr 28, 2010 | Sanyo Xacti VPC-T700 Digital Camera
How do you activate red eye reduction in the 5900?
To take photos with red eye reduction requires your flash to firerapidly before snapping the pic. Make sure camera is in record mode pres the 4 way switch with the lightning sign on it. The flash modes will pop up. select red eye flash.
To fix red-eye after a photo is taken. Bring up the photo in playback mode and press menu button. Red eye reduction should be available as one of the menu items. Otherwise, display the pic, press OK button in center and if you like the fixed picture then select yes to store it.
Jan 12, 2009 | Nikon Coolpix 5900 Digital Camera
Canon ixus 900 ti red eye
Hi Dont know how to fix the red eye and neither did cannon so i ended up with a refund!
Cheers Garry
Apr 02, 2008 | Canon Digital SD900 / IXUS 900 Ti Digital...
Red Eye
i have a suggestion,
you can use Picasa2 to get rid of the red eye from your pics. however, this is installed on your computer and whenever you will take pictures, there will still be red eye. Picasa2 is very easy to use and you can get rid of the red eye in only matter of seconds.
download Picasa2 here
Apr 01, 2008 | Sony Cybershot DSC-T200 Digital Camera
Red eye
I know that it's possible to remove red eyes with different software, such as Photoshop. Doesn't take much time. Good luck with that, I don't think there's anyway you can change the way red eyes occur except using the blitz less.
Jan 01, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Processing pause
Turn off the auto red eye removal option......you can manually remove red eye later. If the auto red eye removal is on, it will try and process each picture after you take it and slow down camera.
Dec 22, 2007 | HP Photosmart R927 Digital Camera
Red eye and wise shot
I can help with the red eye - I've had the camera a year now and have only just found it myself!! - After you've taken your shot, review the picture and then press the Hold button, press the right side of the menu button, just as you would when switching through your pics. In the blue menu bar at the top you will see the red eye 'paint' symbol, press down on the menu button and it will 'red eye fix.
Dec 17, 2007 | Samsung NV3 Digital Camera
Red eye reduction
while in record mode, press the flash/up button repeatedly until you are in red-eye reduction mode. red-eye reduction mode should greatly reduce the problem when enabled. If this does not work, the software that came with your camera (and most photo editing applications) include a red eye reduction/removal filter.
hope this helps,
trin
Nov 17, 2007 | Sony Cyber-shot DSC-W70 Digital Camera
Red-Eye Fix
Here is a link to the product manual: http://alpha03u.c-wss.com/inc/ApplServlet?SV=WWUCA900 It states that to turn on red-eye reduction mode (p.43), go to the Camera menu, then set the top setting (red-eye) to "on". Even if you are unable to get this to work (or if you do get it to work, but are unhappy with the results), there is a really nice free proto organizer (www.preclick.com) that includes a red-eye removal tool that is really simple to use.
Feb 11, 2007 | Canon PowerShot A520 Digital Camera
Red-eye problem still existant in the F505v?
Reports thus far are very favorable with regard to a lack red-eye problems and the red-eye reduction system. Many have said thus far that they usually do not need to engage the red-eye reduction flash.
Sep 11, 2005 | Sony Cyber-Shot DSC-F505V Digital Camera
Fuji FinePix A500 Digital Camera Logo
63 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
