Question about Cooktops
Stove problem - outer cirlcle of an expandable element not working
I've got a Frigidaire Gallery black ceramic top stove. The model number wasn't totally clear but I'm pretty sure it's either CFES388REB1 or CFES388RED1.
It has 4 elements, two small, one large (left rear) and one expandable element (right front). The inner circle of the exandable element works but the outer portion hasn't been working for the past week or so. Is there an easy way to fix this (like a fuse change?) or need I call a repair person?
Thanks a lot!
  • 447 Answers
You will need to call a professional these are very complicated and not easy to service, there are no fuses either. It will most likely be the element itself that has failed and they are not cheap. It also could be the switch too however it will take a person very familiar with schematics to properly diagnose it. Or you could just replace the element and switch yourself and that would most likely solve it.
Posted on Dec 26, 2007
Depending on the model & year purchased, these may be under recall for a fire hazard involving elements that stay on....
is the site to check, (my GALLERY had this problem, and it's almost always the expandable element that fails.... you can get it fixed whether or not you experienced this problem, they will send a free repair service to avoid future liability... yours does not appear on the list, but I would call Frigidaire anyway, to see if they will add this model to the service recall list
Posted on Sep 06, 2009
My stove top works but oven and broiler will not heat
Good Afternoon friend, thanks for your post!
I see that your oven and broiler will not work on your Frigidaire range. It could be possible that your elements are bad or the thermostat may have shorted. I would suggest performing a reset on your range and you can do that by flipping the household circuit breaker off for roughly ten minutes. If that does not help resolve your issue you may need to have a professional technician come out to pinpoint the issue within your range. Best of luck! -Matt
Feb 16, 2015 | Frigidaire Stove / Oven / Range Glass...
How do I clean under the electric elements on my basic westinghouse stove
Hello friend, thanks for your post!
I understand that you would like to clean under the cooktop on your Frigidaire range. Could you provide me with your model number please? You can locate the serial tag (which lists your model number) on the storage drawer on the right hand side. With this information I can better assist you. -Matt
Sep 16, 2014 | Electrolux White Westinghouse Stove Range...
Replaced element on frigidaire oven and oven still not working
Good Afternoon Friend,
I understand you've recently replaced the elements on your Frigidaire oven and that it is still not working. May I have your model number please? The serial tag, which lists your model number, is normally located in the storage drawer, on the right side if you have a range. If you own a wall-oven please check the front of the oven, on the left side, as you open the door. Also, think about what may have happened prior to this occurrence. For instance, did you notice any strange functions or any other error codes prior to this issue? With this information I can better determine what may be causing the issue at hand. Thank you! - Z
Sep 07, 2014 | Frigidaire Stove / Oven / Range Cooktop...
Why would there be no heat from frigidair oven elements?
Make sure the oven timer is set properly, if its turned off, the oven will not go on. Also check if the oven has separate fuse, it may have blown.
Aug 24, 2014 | Frigidaire Stove/Oven/Range Black Glass...
Boil element caught on fire and melted.
If element caught on fire, I would suspect stove needs cleaning. Do that then elements should not smoke for long. (I hope all moisture was removed from stove!!!)
Feb 11, 2014 | Kenmore Element Stove Burner Frigidaire,...
Maytag ceramic top stove with the double oven, two small burners don't get hot anymore can I fix myself and how?
It is simple . Before the process make sure the the power is off .. There screws on the back after removing them you can lift the top n easily remove the none working ones . You can buy the spear ones online or local shop . I have done it myself or search YouTube with model number youse come a cross with repair option . Good luck .
Aug 06, 2013 | Cooktops
I have a frigidaire ceramic cooktop. It started making a "popping noise" and there was a burned smell, but the stove was not on. I had to turn off the breaker to stop this.
Either there's ashort in the stove top or the wiring going to the appliance. Sorry but I would have to see it to see exactly how to fix the problem. the top needs to be removed and inspect the wiring to it. Test the top with a voltmeter forshorts.
Oct 16, 2010 | Frigidaire 31 in. GLEC30S8 Electric...
Hi my name is Ursula I have a 5 burner ceramic cooktop whirlpool model 005 and two of the elements do not work at all. How do I get this replaced or must I purchase a new stove top.
Oct 13, 2009 | Whirlpool 30 in. RC8700 Electric Cooktop
Help! My son dropped a bowl on the ceramic cooktop of our range
Hi, if you still have this stove can you please contact me? Thanks so much!
Mar 24, 2009 | GE 30 in. JP340 Electric Cooktop
Element on ceramic Frigidaire Gallery cooktop won't go off.
take knob off and check the middle is not split and hence not turning the shaft
Nov 20, 2008 | Frigidaire Cooktops
Cooktops Logo
861 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
