Question about Maytag Neptune FAV6800AW Top Load Washer
Maytag Washer Problem
When you set the timed wash on my Maytag 8608 AAW washer and pull the knob, no water flows into the washing machine, yet if you turn the switch to the rinse/ spin cycle, the washing machine works, Any ideas? Thanks.
Have you tried starting the wash cycle at several different time settings? Especially the shortest time setting, just before the start of the first spin? If it works at another setting, it's possible the dial/switch mechanism is worn and not making contact at your usual setting. In any case, a spray of a good electrical contact cleaner spray (NOT WD40 or similar) - with the power lead UNPLUGGED - sprayed into the switch mechanism might help. You would need to remove an access panel to get at the switch mechanism.
Ian from Australia
Posted on Dec 26, 2007
I pull the knob to do a regular wash and nothing happens, no water no agitation. However, when I turn the knob to rinse it that works. This suddenly happened, was working before. Is it the knob?
Rinse on most washers is cold water your wash cycles can be cold hot and even warm. Problem You may have is a bad water feed valve Or Timer and possible bad wire harness at motor to timer
check water valve Turn washer to regular wash cycle pull knob on will washer fill ?
if water starts to fill then change washer temp if washer has this.
if water comes out on all settings water valve is fine.
Check the water both hot and cold that it is turned on;at faucet.
Your Kenmore Most likely has a bad water valve check for hot water side clog or not working.
Apr 25, 2015 | Kenmore 2982 800 3.5 cu. ft. Top Load...
Water does not fill the machine
Here are a couple of tips that I wrote to help people that are having problems with the washing machine not filling...
Washing Machine Problems No Water
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
Washing Machine Fix Washing Machine No Water
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
heatman101
May 05, 2010 | Maytag LAT3600A Top Load Washer
Fabric softener cup on Maytag Neptune washer is full of fabric softener after the cycle. Checked valves in output mode. Both the main and the bleach valve turn on and dispense water, but no water dispenses...
Hi. your problem is actually a rather complicated one.
Timer and selector switches The timer switch is usually the largest dial on the main control panel. It can be either a mechanical device much like a simple clock, or completely electronic with just a digital readout.
The timer runs the washing machine in a pre-determined pattern. It provides the electricity to all of the washing machine components at the correct time and for the correct length of time.
The Start switch is usually part of the timer knob. When you set the timer to the proper cycle, you either pull or push the timer knob to start the cycle.
The selector switches or knobs vary from machine to machine. Most washing machines have one or several switches or knobs on the control panel besides the Timer/Start switch. These let you adjust certain settings; for example, the water temperature, spin speed, timer cycle, and so on. Normally, the washing machine completes the cycle selected on the timer, regardless of how you set these switches and knobs.
Jul 14, 2009 | Maytag MAH2400A Front Load Washer
Timer on maytag Atlantis
replace water inlet solenoid first if this doesnt work replace timer
Dec 08, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Washer filling up improperly
Well its definately not your water level switch, so that only leaves your water fill valve at the back of the washer, the cold valve is stuck open by debris. hope this helps
May 18, 2007 | Whirlpool LSR5132PQ Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
107 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
