Question about Kitchen Ranges
DCS range igniter won't stop
After cleaning my range, whenever we cook now, the auto igniter continues to spark.
  • 1462 Answers
SOURCE: igniter will not shut off on my DCS RGS-366 gas range
spark generator is faulty usually - replace
Posted on Jul 23, 2008
  • 8147 Answers
SOURCE: My DCS range continues to
Each burner has a switch and all are wired into one big happy family. Every now and then a pot will boil over and liquid will get into one of these switches. Sometimes aftera day or 2 the switch will dry out and the problem will go away. To see which one is bad you would have to access them and disconnect one at a time till the ticking noise stops. Then replace that switch.
Posted on Dec 15, 2008
  • 1543 Answers
SOURCE: GE gas range igniter continues to spark, won't shut off.
Often times, just leaving the range unplugged for a time will solve the problem, which is most often caused by water or a cleaning agent getting into an igniter switch behind a burner knob. After the switch drys out it usually starts working again. In the mean time, you can still use the burners by lighting them manually with one of those long lighters, but you will not be able to use the oven or broiler without electricity. If the range continues to spark after being left unplugged for more than a day or two, you will have to determine which switch behind the burner knobs is causing the problem. Please don't bother rating, as anything but a Fix-Ya will lower my score. Thanks.
Posted on Feb 18, 2009
SOURCE: DCS Range constant sparking at all burners even when lighting one
This happens to mine if there is anything on any of the burners, such as food residue or moisture. Check all the burners to see that nothing is touching the burner area where the gas jets are. Even a little water can make this happen.
Posted on Aug 10, 2009
  • 103 Answers
SOURCE: range top ignighters sparking
One of your "switches" to your burners is shorting causing unit to spark when in the off mode, or, you may have a bug problem, bugs have made their way into the spark module.
1: if no bug problem, disconnect stove from electricity, lift top up, remove all of the single connections to each switch to top burners(make sure they don't have any bare wires touching the frame), then plug unit back in, if still sparking then replace module.
Posted on Oct 01, 2009
  • 43501 Answers
SOURCE: Premier 20" range with electronic ignition - the
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
Posted on Sep 08, 2010
0 characters
1 Points
Igniter switch on top burner will not shut off
try thoroughly cleaning the burners, particularly the holes in the ring that the gas come through. The gas come through to heat the ignitor so that the ignitor knows to stop trying to light the burner ; if the holes are clogged the ignitor doesn't heat.
The burner is easily disassembled from the top by removing a thin bolt, and you can clear the holes with a paper clip.
Sep 21, 2013 | DCS RGS-305 Professional Gas Kitchen Range
I have just replaced all the ignitors and the spark control module on the cook top burners. Prior to this the back burners would cause ignition spark continually when lit. the front 2 burners could be...
first check to make sure all the burner tops are setting correctly on the burner base, if not it will make the flame uneven. the way the igniter works is once they feel the flames on them they will stop sparking. make sure the flames are not too low and they are touching the igniter. check them one at a time. if you have any questions message me back thanks
Apr 08, 2011 | Viking Kitchen Ranges
My DCS range burners with electric start.
Very likely the spark module. All four are supposed to click when one is turned on, however they are supposed to stop when the burner ignites. Replace the module and test. Good Luck, Appliance Specialists
Jan 03, 2010 | DCS 36-6-1 Gas Kitchen Range
Dcs 48" gas range igniter comes back when set on low/simmer
This is not a solution but something to think about for troubleshooting.
On the DCS there are two ports that feed gas to the burner.
One for high flame and one for simmer.
On the DCS if the flame is snuffed out on simmer it will automatically reignite.
So if the igniter will not shut off while on simmer, the sensor is bad and is trying to reignite the burner.
May 11, 2009 | DCS 24-24G-1 Gas Kitchen Range
Most problems with gas ranges have to do with the flame—either it isn't quite right or it's nonexistent. Many new gas ranges have "electronic ignition," a spark igniter that starts the flame as gas flows through the burners f, when you turn on a burner, it fails to spark but you hear sparking at other burners, the igniter or the burner switch probably needs replacement by an appliance repairperson. If your range has a pilot light, be sure the pilot light is lit.
have nice time..!! arte the solution!!
Apr 17, 2009 | DCS 24-24G-1 Gas Kitchen Range
Gas burners are ticking
The ticking sound you hear is the electronic ignition which is located by each burner. When you turn a burner on the electronic ignition creates a spark which ignites the gas. Once the burner is ignited. turn the knob a bit further and the ticking will stop.
Feb 05, 2009 | DCS RGS-486GD Gas Kitchen Range
Jan 02, 2009 | DCS RDS-364GD-SS Dual Fuel Kitchen Range
Dcs gas oven/range, ignitor won't go off after burner or burners are lit
They probably cleaned the stove and in replacing the parts of the burner switched the rings on top of the burner. This happened to me. While they look alike, the round rings, not the flat disks, have to be on the right burner in order for the electron spark to ignite the gas. Good luck.
Oct 29, 2008 | DCS 24-24G-1 Gas Kitchen Range
Dcs range igniter
Our GE range Profile, the igniter continues to spark with it on off. All four burners igniter contiues to spark. We have it unpluged at the moment, but it seems like it needs to reset or something. Will it stop when we plug it back in? I am not at home is why I ask this question, or I would plug it is an find out. Any help?
Aug 18, 2008 | Kitchen Ranges
Igniter will not shut off on my DCS RGS-366 gas range
Replace the multipoint gas re-igniter, it is a blue unit behind the knobs. This unit detects the flame and stops the clicking. Call Fisher and Paykel (owners of DCS) at 1 888 936-7872, they sell parts for DCS. The old inferior unit is blue and has a whte label. The newer unit has a yellow label.
Jul 23, 2008 | DCS RGS-366 Professional Gas Kitchen Range
Kitchen Ranges Logo
477 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Barrett Palumbo
Barrett Palumbo
Richard Roth
Richard Roth
Are you a Kitchen Range Expert? Answer questions, earn points and help others
