Question about Dayton Electric Heater
High Altitude Electric Heaters
I am building a cabin at 8,500 feet elevation in Utah. I want to use electric heat to supplement our wood burning stove and to keep the cabin above freezing during the winter months. I have installed wall heaters in a bathroom and the laundry room. It turns out that they over heat if I wire them for the maximum wattage, apparently because of the high altitude. Do you have wall and/baseboard heaters suitable for that altitude or any suggestions.
  • lnlsennett Jan 01, 2009
    I am told that the limiter that is in most electric baseboard heaters is made for lower elevations. There are baseboard heaters that proclaim to work at higher elevations. What's the difference?
  • 288 Answers
I have never heard of altitude effecting the electric. Watts amps and volts are different than burning a gas, like propane. The high altitude has less oxygen thus requiring the combustion to be effected. If your wires are over heating when you use maximum wattage (amps) you need to install larger wire with the correct size breaker. Look up ohms law. Its a basic electrical formula and will help you get this right.
Posted on Dec 26, 2007
I'm looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
Electric Heaters and Accessories - Grainger
W. W. GraingerCount on Grainger to supply high-quality electric heaters and accessories for ...Electric Wall Mount Heaters ... Electric Space Heater,Fan Forced,120V, ... SearchQ&A ... This fuse is used on driers heater elements, I'm unable to locate these in .... in Ask and Answer are not intended to replace or supplement any professional, ...
DAYTON Electric Space Heater,Fan Forced,120V, - Portable ...
W. W. GraingerShop DAYTON Electric Space Heater,Fan Forced,120V, (3VU33) at Grainger. ... Item # 3VU33; Mfr. Model # 3VU33; NSN # ... Country of Origin China Country of Origin is subject to change. ... Alternate Search Terms ... I need a replacement fan motor .... Where can I find parts for Dayton fan forced wall heater mod.5ZK54D.
Dayton Industrial Fan:
Dec 21, 2015 | Dayton Heating & Cooling
Sauna Heater
Oil and Gas Sauna Heaters
Oil and gas heaters are the least popular heaters used in saunas.
One reason is because they're relatively inefficient compared to the others.
Some people even complain about the odor associated with the burning fuel. If they're properly vented, oil and gas heaters should have little or no unpleasant smell
Electric Sauna Heaters
Electric heaters are the most popular used in saunas.
They're easy to control with user friendly touch pads that include a timer and thermostat, and light switch,
They're also efficient and cost just pocket change to operate.
Electric heaters have controls that include a timer, thermostat, and light switch.
Wood Burning Sauna Heaters
If you have a house in the country or easy access to fire wood, a wood burning heater is a great choice for a sauna.
A wood heater may also be a good choice if you have an outdoor sauna.
Wood burning heaters don
on Jan 08, 2011 | Heating & Cooling
Portable Heat Flame Electric Fireplace
Electric fireplaces are becoming more and more popular with today's homeowner's. The main advantage of the electric fireplace is generally portability, convenience, low initial cost is important. They also are a good choice when the looks are not as important as function.
Some electric fireplaces have simulated flames that give the look of traditional fireplaces. Another great option to include is a built-in fan to help distribute the heat more effectively. With some of these high end units it can be very hard to tell the difference between an electric fireplace and a wood burning stove. Along with this option may come a heatless setting the will give the look of flames but produce no heat. The remote control has also found its way to the fireplace market. There are many units that can be remotely controlled.
Electric fireplaces are generally cheaper than gas fireplaces. A good unit can be bought for about $500 (there are cheaper models available, but they tend to have fewer options and the flames are not as real looking). These fireplace units are fairly easy to install compared to a gas fireplaces or wood-burning stoves (both of which usually need flues to vent). If you can plug in an electric cord then this type of fireplace may be for you. The electric units are perfect for apartment buildings and condominiums. These places are not suitable for the traditional wood fireplace.
Just like other types of portable electric heaters, electric fireplaces will radiate heat very quickly extreme care must be taken to not have any combustibles too close to them.
You will see how an electric fireplace can transform any setting for you. The newest modern, advanced electric units have far more aesthetically appealing views. They might include fiber optic displays, or randomized lights designed to make the look of dancing flames.
Now whether you're living in a condo or apartment and can't have a real fireplace, the electric fireplace can be a great way to get some of the warmth and ambiance. Also remember that these units are very portable, so you can take them with you when it's time to move. Even though I have never been a big fan of electric fireplaces, because of the expense of their operation, I can see why they would be very popular with many apartment or condos owners.
on Dec 25, 2009 | Heating & Cooling
How do i get even heat thru out the house with a daka wood stove
You burn wood, and smoke goes up flueway.
You're not running chimney smoke through ductwork so you have a heat exchanger.
What kind of heat exchanger?
probably air since you're running through ductwork?
How much hot air or hot water is coming off heat exchanger?
How big of a space can be heated with that amount of heat?
Is the exchanger located in optimal location?
One room log cabin with fireplace will not stay very warm.
One room house with big wood burning stove in center, with hot flue pipe running across the room and exiting on far wall, will get warm-hot, but will cool off fast.
Because the BTU output of firewood is much less than electric, coal, oil, or gas.
Otherwise they would have made wood-burning steam locomotives. But the locomotive boiler cannot get hot enough with wood ... the boiler needs coal to produce enough BTUs to boil water fast enough to rotate the turbine and turn the wheels.
Maybe your wood stove output should be measured.
Don't forget a huge percentage of fire heat goes straight up flueway.
Mar 16, 2013 | Lux Tx500 Series Smart Temp Electronic...
Will the patton electric heater significantly raise my electric bill
1500 watts is 1.5 kilowatts. Run it for 1 hour and you have 1.5 kilowatt hours. My electricity costs .08 per kilowatt hour so, when I run my 1500 watt space heater, it costs me a whopping .12 per hour to operate. I can afford 12 cents per hour, compared to oil at $3.50 per gallon and a burner that burns up to 3 gallons per hour.
Dec 23, 2012 | Patton Electric Patton PUH680-U Electric...
No hot water
Copy following links to help identify product and download possible troubleshoot resources:
Tank-type gas
Tank-type electric:
Rheem tankless:
Other types of water heaters include boiler, tankless electric, indirect, solar-assisted, solar, hybrid electric, heat pump, wood-burning, gas hybrid, 3-phase commercial electric.
Oct 21, 2012 | Rheem Water Heaters
Johnson 40hp- won't idle or troll at high elevations
Depending on the year model you may be able to adjust the mixture leaner for higher altitude. That adjustment was traditionally out of the very top of the carb pointing straight at you. Screw it in(gently- it's not a wood screw). Then out 1/2 turn at altitude.
Jul 14, 2012 | Light Boating
I am getting ready to buy baseboard heat for a 800-900 squarefoor open area, old GArage, And I am looking at 3 8' 2500W sections of base board. is this enough. And How much better is the units you have...
First, those of us on FixYa don't sell any products or appliances. Just information.
But to answer your question about electric baseboard heating ... It's the most inefficient and costly heating source you could use. With that said, a lot depends on the cubic footage of the area, as well as how well that area is insulated. This applies for electric, gas or oil heating. You rae not just heating square footage, you're wanting to heat cubic footage (i.e. Width x Length x Height = Cubic Footage). Assuming you have an 8 ft ceiling, the Cubic Footage would be (assuming a 9 ft ceiling) 7200 Cubic Feet. Based on that and if it was my home, I'd be installing a 20,000 - 25,000 Btu Vent-free (Flue-Less) Gas Heater, with built-in thermostat control. It could either be as a Free Standing, Vent-free Gas Fireplace System or simply a Wall Mounted Heater. One is decorative, as well as efficient and the other is simple and efficient. Plus, gas heat is a warm, moist heat that you feel very quickly and it's more comfortable than electric or oil heat. As a matter of fact, Vent-free Gas Heating Appliances are 99.9% efficient. And will work without electricity. Which is great during a Winter power outage. If you currently don't have Natural Gas at your home, then LPG (Liquid Propane Gas) is readily available.
So, by now, you figured out that my preference is gas. I have three Vent-free gas heating appliances in my 3000 square foot home (2-Vent-free Remote Controlled Gas Log Sets in existing wood burning fireplaces & a Vent-free heater in my 2-car garage). Our primary heat source is an electric heat pump. Which doesn't work well, when the temperature reach 32 degrees F or lower. We use the gas heaters only as a supplement heat source or as primary source, if the power goes out.
I hope you'll take a little time to research this, because in the long run, it can save you $$$. Below, is a link to Empire Comfort Systems. They have excellent supplemental and primary heating products in all looks, shapes and sizes. This will give you an idea of what's out there.
I hope all of this helped you. Please let me know. Thanks.
Jun 13, 2011 | Fahrenheat F25426 Electric Baseboard...
Is "check engine" light altitide sensitive/dependant
have to wonder. there is definately less oxygen at that elevation so i presume that's what it is. not sure about the rest of the states but i believe california has the toughest specs for pollution control on automobiles. unless of course the motor acts up just ignore the light especially if it goes out when you return to regular elevation.
Sep 03, 2009 | Chevrolet Silverado 1500 Cars & Trucks
Dayton Electric Heater Logo
195 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
