Hitachi 53FDX20B 53 in. Rear Projection Television
Problem for Hitachi 53FDX20B 53 in. Rear Projection Television
Double image almost like 3D is there an
By chutchins1 on Oct 13, 2009
Double image almost like 3D is there an unexpensive repair, I have tried runningmagic focus but no help?
Best Solution
posted on Oct 13, 2009
Very Helpful)
SD Tech
Rank: Guru  Hitachi Televisions & Videos  Expert
Rating: 97%, 885 votes
This is a model first sold in 2002---if it is 3d it means one of the two convergence chips (IC's) is bad.
This set uses 2 of the STK-392-110 chips--they and any protect resistors around them that are bad need to be replaced and the set adjusted with the Hitachi remote.
I do not know if you can do this repair--consider that you can buy the pair of chips and any parts needed for less than 20 dollars--most shops charge 300-400 for this kind of repair...
Do you know how to solder if I tell you how to get at the parts etc?
Magic focus will not work if either of the chips is bad. After the set is repaired it will not have this problem again for 5-8 years---normal life span on these parts.
Let me know if you need help or advice--I am here to help people---
Regards, SD TECH
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Hitachi 53FDX20B 53 in. Rear
Questions and Unsolved Problems for Hitachi 53FDX20B 53 in. Rear
Do you recommend Hitachi 53FDX20B 53 in. Rear Projection Television?
Answer
Answer
just got this tv from a friend. he couldnt get it to work and im having the same problem. i cant get... (More)
Answer
I have a Hitachi 53fdx20b picture loked like 3d..replaced both convergance chips and checked... (More)
Answer
I have a 60+ inch Hitachi rear projection 1080i 1 HDMI port. The HDMI port is not working, is there... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Hitachi 53FDX20B 53 in. Rear...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 733
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
