Question about ION Audio iTTUSB Turntable
Appears to be installed properly but doesn't record
Software appears to be installed correctly, turntable appears to work, but when trying to record the meters do not respond and no recording seems to be occuring.
I have the same problem. I have intstalled the software, the turntable appears to be working fine but there is no signal to the meters. I have tried different usb ports, plugged and unplugged all connections, and rebooted the computer to no avail. I have windows XP
    President:
  • 1,944 Answers
When you first connect the turntable, Windows XP (and Mac OSX) will often select the "USB Audio Codec" as the audio input and output for your entire system. Since your turntable does not have speakers, audio will not be heard from your programs until you tell Windows not to use the turntable as an output device. Here's how to change these settings so that your internal sound card will always be used for playback whether or not your ION TTUSB is connected via USB:
    For Windows:
  1. On the bottom left of your screen, select the "Start" menu.
  2. Select "Settings" then "Control Panel".
  3. In the window that opens, select the "Sounds and Audio Devices" icon. (If you don't see a choice called "Sounds and Audio Devices," choose the "Switch to Classic View" option in the panel on the left of the window, and the "Sounds and Audio Devices" icon should become available in the list on the left.
  4. Select the "Audio" Tab at the top of the "Sounds and Audio Devices" control panel window.
  5. Under "Sound Playback," choose your internal sound card as the default device. This varies by computer but should not be set to "USB Audio Codec" or "Microsoft Sound Mapper".
  6. Under "Sound Recording," select "USB Audio Codec" for your default device.
  7. Check the box titled "Use only default devices".
  8. Click "Apply"...then "OK".
    For Mac:
  1. Open your Hard Disk.
  2. Open your "Applications" folder.
  3. In the "Applications" folder, open the "Utilities" folder.
  4. In the "Utilities" folder, open the "Audio MIDI Setup".
  5. In the "Audio MIDI Setup" under Audio Devices, set:
    • "Default Input" to "USB Audio Codec"
    • "Default Output" to "Built In Audio"
    • "System Output" to "Built in Audio"
Now, all programs, including Audacity, will only use your internal sound card for audio output.
Posted on Dec 26, 2007
  • Damen Wong
    Damen Wong Dec 26, 2007
    All that is left to do is to tell Audacity that you want it to play any sound from the turntable out through your soundcard's speakers. This option is called "Monitor Input." Here's how to find and enable it:
    Next to the round playback control buttons you should see the Input and Output meters. They are each labeled with "L" and "R." Underneath the "L" and "R" labels of the input level meter, you will see a small icon that looks like a microphone (see the picture below). To the right of this icon is a black arrow that points downward. Click this arrow, and select "Monitor Input." The input level meters should now be active, and you should hear sound when you play your turntable.
Turntable out of Tune
it will be the turntable speed not exact
quality turntables have bars all around the circumference and when the speed is correct under a fluro light those bars will appear as stationary or using a strobe light set at 50 or 60 cycles a sec
bars going anticlockwise are too fast and moving forward are too slow
quality tables have a small knob or screw to adjust motor speed
Jul 27, 2017 | TDK Tvt2002 Usb Belt-drive Turntable
Cartridge dragging
Check that the cartridge is fitted properly.
Jan 13, 2013 | Audio Technica ATLP120USB Turntable
Message saying windows did not start properly. recent hardware or software change may have caused
There must be a corrupted software drivers.
For quick solution tried to boot in safemode then perform system restore, if it doesn't work tried to restore the last known good configuration.
How to boot in safemode:
  1. Restart your computer and start pressing the F8 key on your keyboard. On a computer that is configured for booting to multiple operating systems, you can press the F8 key when the Boot Menu appears.
  2. Select an option when the Windows Advanced Options menu appears, and then press ENTER.
  3. When the Boot menu appears again, and the words "Safe Mode" appear in blue at the bottom, select the installation that you want to start, and then press ENTER.
  4. Once your on the Windows desktop, click on Start>All Programs>Accesories>System Tools then select System restore
  5. Choose the recent date or restore point that your computer is working fine.
How to boot in Last know good configuration:
  3. When the Boot menu appears again, and the words "Last Known Good configuration" appear in blue at the bottom, select the installation that you want to start, and then press ENTER.
Jul 13, 2011 | HP Pavilion a1620n (882780664494) PC...
PS-LX250H
Have you measured the stylus downforce. It usually is between 1 & 1.5 grams.
Apr 21, 2010 | Sony PS-LX250H Turntable
New Memorex 9285MMO, loud hissing + ring dig on record
Probably the needle, I work on them and many needles are bad from new. They were put on wrong in the first place. Try taking the red part off and make sure there is a needle part and that its straight.
Jan 16, 2010 | Memorex MX212 Turntable
Need driver for windows to have the Crosley CR249 turntable work correctly.
Insert the enclosed software cd into your computer.
Follow the instructions on the computer screen to install the software. If the software does not load automatically, browse the cd and open the Read Me folder for further instructions.
Connect the small end of the USB to the USB jack on the back of the unit.
Connect the other end to a USB port on your computer.
On your computer open the Record Recording software.
For instructions on operating the Record Recording software, browse the software cd and open the Read Me folder.
I got that from the manual. You don't need a separate USB driver for it, mate, but you DEFINITELY need the cd...
Hoping you have the cd,
Chris (ziraffa)
Dec 28, 2008 | Crosley CR249TA Turntable
It doesn't work!
with everything plugged and running go to preferences in FILE and set Recording Device and channels to Audio device USB in Audio I/O.Tick software playthrough.
now set the microphone box to Stereo mix on the home screen(box is left of small scissors) hope this helps.nigel.
Dec 26, 2007 | ION Audio iTTUSB Turntable
What computer, and are you using the ion software, or 3rd party software to record?
Keep me posted.
Dec 09, 2007 | ION Audio iTTUSB Turntable
ION Audio iTTUSB Turntable Logo
373 people viewed this question
Top ION Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Ben Armstrong
Are you an ION Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
