Question about Car Audio & Video
Headphones Can you plug any headphones into the PADVD-380? If so, would you still have to have the station set to the specific frequency to hear it? I have a 3 year old and I'm not crazy about the idea of listening to Scooby Doo or the Wiggles through my car radio speakers on a 6 hour drive to visit my parents. I would like to listen to my own music while he listens to his DVDs through headphones. Is that possible?
  • EllieG Dec 27, 2007
    I was afraid of that! Thanks for your quick reply.
  • 1,944 Answers
Unfortunately, that is not possible. Sorry...
Posted on Dec 26, 2007
  • Damen Wong
    Damen Wong Dec 27, 2007
    My pleasure =)
Sennheiser RS 120 headphones won't work, only hear static
Adjust the tuning wheel on the side of the headphones so it picks it up.
Mar 20, 2014 | Sennheiser RS 120 Consumer Headphones
I own two SAVV VAC-IR14 wireless headsets that I use with my SAVV video DVD car player. I am no longer able to hear anything through the headsets. I've replaced the batteries but no sound. Any...
Try checking the base-station and the frequency they're tuned to.
If they both all of a sudden didn't work it must be an issue with the player or the base-station.
Hope this helps!
Jul 04, 2011 | Savv VACIR 22 Wireless Headphones
I'm hearing a high frequency electrical "whirring"
COuld be a grounding issue. Place a ground plug on your computer where it plugs into the wall outlet. You can get these at almost any store for about a $1.
Otherwise, you might try using a battery backup system.
Mar 21, 2011 | Sony MDR-7506 Professional Headphones
I can not get it to work with my pod touch
Plug the device into your power plug in the car. This kind of adapter uses radio frequencies to tune it in so make sure that your radio on your car is set to the same as the device. This will only work if there is no station for that specific frequency - for example, of the device is set to 88.8 FM and there is a local station set to that frequency, all you will hear is static. There is an option on the device to change was frequncy is it set to, tune your radio to the matching number and it should work.
If your problem is getting it connected, there will either be a wire at the bottom to plug into your ipod (goes in the same place as it does when you plug it into the computer) or it will be mounted right on the device. Make sure it is fully attached on both sides or it won't work.
Mar 03, 2011 | Belkin TuneBase FM (F8Z049-BLK) Car...
What fm station should my PADVD-360 sound come thru?
Sometimes 88.7 , 89.1 just run a scan and wherever the radio sounds clear then thats your station, make sure to preset it in your memory.
Good luck.
Jun 12, 2010 | Power Acoustik PADVD-360 Car DVD Player
I am trying to stream music form Archos vison 3 to
Have you turned the transmitter on I assume?
I would try other stereos e.g.) your car to see if you can rule out the player or stereo.
Some more info as well, have you been trying different frequencies on your Archos, or just cruising up and down on your stereo?
I believe you need to pick a weak, or no station frequency in order to stream to the stereo, as the player is not sending out a high powered signal.
Mine works on my samsung home theatre from 10 feet away. Have not tested the limits although. Good luck.
Mar 28, 2010 | Archos 3 Vision Digital Media Player
if your pioneer radio has the light blue ipbus/changer plug on the back of the radio, you can use this adapter and turn on the <aux> in the menu where you set the clock.
Aug 17, 2009 | Power Acoustik PADVD-330 Car DVD Player
Red light isn't indicating it detects source
I have the same model as you.
Plug in the transmitting unit into a good working power outlet. Make sure you have the audio connected to a loud source. Turn on the source device producing the loud audio to be transmitted to your headphones. (This being your IPod - Turn it full blast). Now see if the transmitting unit's LED light is on. Check headphones for audio. (May have to tune in the headphones till green and adjust its volume as well).
Note: Some radio stations bleed over into the headphones and you may have gotten the "Beautiful Music" from this radio station frequency harmonic anomaly. Keep tuning your headphones till you hear your music or audio source.
I recommend that the source of your audio have its built-in speakers off, while still providing audio out to your transmitting unit, via an external audio output. Check your source manual or look for audio jacks on the front or back. There may be a setting to turn this on and for the main built-in speakers to be turned off as well.
If this does not work, unplug the transmitting unit, and then plug it back in again, after waiting for about 10 seconds - all while audio is being provided to the unit. It should come on.
Jul 26, 2009 | RCA WHP140 Consumer Headphones
How do I preset individual radio station frequencies?
To set individual presets: 1. tune to the station you want as a preset 2. hold down the number (ie "1") on the remote until the number blinks on the system 3. repeat for all other stations
press the number on the remote to tune to your preset
this is very similar to setting the presets on my car radio
May 04, 2009 | JVC FS-D88 Shelf System
No radio in menu. only music. voice .settings .
The service may not be available in your area. Make sure the headphones are connected to the player when searching for radio stations: Here's pg 15 of the user manual:
FM Radio (if applicable)
The Sansa
player includes an integrated FM radio for listening to live broadcast FM
stations. Please note that the FM Radio function may not be available in your region.
Listening to FM Radio
To listen to live broadcast FM station, follow these steps:
1. Select FM Radio from the Main Menu.
2. A radio frequency menu will appear.
3. Press |<< or >>| to adjust and search for the desired frequency, or select
preset by pressing Select.
4. For fast search, press and hold the |<< or >>| buttons.
Feb 20, 2008 | SanDisk Sansa Clip MP3 Player
Car Audio & Video Logo
140 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
