Question about IBM (02R4087) Motherboard
Power i change my system spli but i dont no were i put on off cable in bord
  • Anonymous Mar 16, 2008
I have dimension 8300 mother bord . it don t power on withe standar power sply when I plug the cable alumentation the fan works and when pushed Powerboton all shutdown
See my published guide entitled My Computer is not turning on!!! Is it dead!!! No POST!!!
Check the connections to the VGA on the Graphics card or the on-board VGA out put, whichever applies to you. Ensure they are making good contact.
The next step is to remove the graphics card if you have one and clean the contacts and then reinstall.
Next remove the RAM modules and clean them, reinstall one at a time in alternating slots. On powering on each time.
Take care!
damnor01
Apr 19, 2011 | Dell Dimension 8300 PC Desktop
Tip
IDE Instillation of drive
1.) set the jumper setting to the rear of the drive, master / slave ; cl,,
2.) put the prive in the system and secure it with screws
This involves pushing one of the fround holders out and sliding the drive in.
3.) connect the ide cable from the drive to the main bord in the ide slot.
4.) connect the power cable.
NB dont worry the cables can only go in one way
5.) power on the system, your hardware should be detected and installed automatically. no 3rd party drivers needed unless its a speciality drive.
sorry i aint got any pics yet, but i will add them as soon as i can get them
on Jul 17, 2008 | Lite On LH-20A1H DVD RW Dual Layer Burner
Emachine t3418 no video pwr sply goes and that's it no boot
If you have a desktop system and it is in a no power state, I'd replace the power supply (Or if available test with a known good) before I'd replace teh motherboard, Power supplies normally fail 1st
Jan 11, 2010 | E-Machines eMachines Desktop PC
Powers on but no activity from hardware, and no warning beeps
yes it can be a power supply prbl change the pwr sply and if it steel dosent start take out the ram-s see if it beeps if not put back the ram-s and leave it powered up for 5-10 mins and touch the chipset if its burning hot its only the main bord , if its not hot and its AMD its the main b. or the processor or both it its intel its the main bord.
Jan 04, 2010 | HP Pavilion a1140n (PX774AA) PC Desktop
I have new case,but can't connect audio,front usb,mic,5v,ground e.t.c cables from case to motherboard because they are not marked on it.Motherboard model HP compaq d530 xw3100
we see each casing have written cable knobe.as hdd/ reset/ power/ we join it on bord .there diagram on about this led/cable.2/ we give power to hdd/ cd room from smps3/ we join fan squire port on bord . fan port is written in bord. 4/we join data cablehdd/cdroom from on board.
Nov 04, 2009 | HP Compaq Motherboard
I have asuse a8ne mother bord..fan not working
Dear Sir Change the FAN power Cable Related Problem but your have no idea about the cable just send me a fan we are Repair for this Fan Maximum cost 11.54 $ and Normal problem in 8.65 $ charge .......ok.
Email:support@compudesk.in
Web: www.compudesk.in
Jul 13, 2009 | Computers & Internet
Auto system on
have u ever change the front panel connectors on the mainboard else ur power switch might be defective, change a new one, and hope it works.
May 06, 2009 | Computers & Internet
I moved and do not remember how to connect printer to computer
there will be a cable for power please put this first and then conect the usb cable to the printer points usb and the other in the back of *********** bord in the usb port start your computer and should work
good luck
Jan 24, 2009 | Lexmark (12G4507) UPS System
Power supply/ no output voltage
Actually i haven't fixed the problem as yet but i did find some info that would help me to fix problem.
I went to google and entered keyword,,, Electronic parts,,there came up a page,,and i went to several manuf sites till i found a replacement transformer,,then i disassembled the power supply and am now waiting for a replacement transformer.
Sep 21, 2008 | Boston Acoustics MicroMedia Computer...
Problem in desk top computer
CHECK ALL CABLES.
YOUR MAINB POWER SUPPLY BORD MAY NOT WORKING ...
CHECK THAT ONE 1 ST....
dont forget to tell me u r problem solved or not
best regards & best of luck.
Oct 23, 2007 | Audio Players & Recorders
IBM (02R4087) Motherboard Logo
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
