Hello, I have a Toshiba Satellite P105. The DVD drive on it, says it is a DVD-RAM. In properties it read as a HL-DT-ST DVDRAM GMA-4082N. I bought this being told this drive supports Dual-Layer burning. Now is this true, or no? I really have never even heard of DVD-RAM before and after reading about, I understand it cant write DVD+R OR DVD-R . Can someone please tell me, if this drive can burn those and can it burn DVD-DL too? Thanks so much!
Comments:
Oct 13, 2009
- Thanks that helped clear up some things, but still that doesn't say yes or no exactly on DVD Dual Layer, by that info I am assuming it can not, or can it? That is what is puzzling me in trying to use them.
Specifications of LG GMA-4082N
General
Buffer
2 MB
OEM
Hitachi-LG
Connection
ATA
Slimline
write speed
CDR
24 x
CDRW
16 x
DVD-R
8 x
DVD-RW
4 x
DVD+R
8 x
DVD+RW
4 x
DVD-RAM
3 x
read speed
CD
24 x
DVD
8 x
Comments:
Oct 13, 2009
- No, I'm afraid if it would specify it in the specifications, I found no entries for DL support. They are not that expensive anymore by the way, I picked a cd/dvd combo with DL support and 22 X write speeds on dvd for 24 bucks on Ebay, simply remove the bezel on your present drive, there are three to four releases and the bezel comes off. Put the bezel on the new drive, the only other thing that has to be changed is the rear mounting tab, there are just two screws that hold that tab on. As long as the "interface" on the back of the drive is the same, any drive will operate. It is either IDE or Sata.
Oct 14, 2009
- I really don't shop using a model name, I really didn''t pay any attention to it. I just did a search on Ebay for a dvd drive with dual layer support and the type of interface my laptop has and that was it. Let me check my Gateway P-7811 FX and I'll tell ya what I have in it, because it also support lightscribe.
My model drive is an Optiarc
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
Thanks very much! Also could you give me the name of that drive? Or one that is similar you would suggest that can burn DL+R. Thanks tons!!!!!
" - joshpro11
Popular Solutions for Toshiba Satellite P105-S6024
I've had my DV9320us with Vista for about 2 years, and recently the hibernate stopped working, as...
(More)
I've had my DV9320us with Vista for about 2 years, and recently the hibernate stopped working, as well as the wireless, and now it starts and stops without booting, and finally after battery is out and waited over 10 minutes, it sometimes comes on after a few boots!!! Any solutions. Is it a motherboard issue? P.S. it won't let me make Restore disc...
I have a Medion 2210. When the charger is plugged in the green light on the adapter flashes and the...
(More)
I have a Medion 2210. When the charger is plugged in the green light on the adapter flashes and the computer does not charge
I have a HP Touchsmart IQ816 & the internal webcam has stopped working? I have tried...
(More)
I have a HP Touchsmart IQ816 & the internal webcam has stopped working? I have tried disabling & enabling the driver & looking for updated driver but no luck? Any suggestions please? Thank you.
I boot up this morning... got the error message that my system had found new hardware, CD ROM. I...
(More)
I boot up this morning... got the error message that my system had found new hardware, CD ROM. I have a HL-DT-ST DVDRAM GMA-4082N on a Windows XP SP 2 machine w/ media center. When I attempt to install/update the driver, it says it is not digitally signed, but when I install anyway, it displays the correct driver info (4082N) but my machine will not recognize or play it. No yellow exclamation mark in Device Mgr. Tried System Restore and the nearest one was 15 days ago and I don't want that one. In the system restore history, it showed up that an unsigned driver was installed previously on the 15th of this month, but I've been using my CD-DVDRAM drive ok and have not installed anything besides yesterday. Only thing I did yesterday was uninstall Quick Time and I-Tunes and install QT Alternative. I've had this laptop for a year and never a problem one. Guess I've been lucky,. Thanks for any help.
