Question about Logitech Deluxe Access Keyboard
Keyboard have vista want to install corded deluxe access keyboard wont work but num lock light works
2 Suggested Answers
  • 5 Answers
SOURCE: My Logitech EX110 wireless keyboard has no light indicator
Your EX 110 receiver has 3 indicator lights (LEDs) that display the status of the Caps lock, Function key, and the Num lock during normal operating mode. These lights will also flash when the connect button on the receiver is pressed.
LED A: Indicates that the Caps Lock (Capital lock) key is on when lit.
LED F: Indicates that the F keys are in Standard F Keys Mode when lit and in Enhanced F Keys Mode when the LED is off.
  • Your EX 110 keyboard has an Enhanced F Keys Mode for F keys that provides additional functions you can program. See Knowledge Base article 9526.
LED 1: Indicates when the Num Lock (Number lock) key is on. This function allows the number pad to produce only numbers
Posted on Jun 30, 2009
  • 62 Answers
SOURCE: Caps lock and num lock keyboard lights do not come
If the "Caps Lock" and "Num Lock" keyboard lights do not come on, then press "Scrol Lock" bottom. If the light still not glow then you need to change the key board.
Posted on Aug 14, 2009
0 characters
1 Points
Logitech Wave K350 won't boot with num lock on
Have you changed or updated anything else on your system? Added any other Bluetooth devices? I have the same KB, always boots with Num lock on. It worked with both Vista 64 and now Win 7. Maybe the driver and the specific USB port combination is not working. Try plugging the BT antenna into another USB port.
Mar 04, 2014 | Logitech Keyboards & Mice
Comfort curve keyboard 2000
Have you tried my solution for keys not working here?:
Mine is toward the bottom, with the video
Good Luck
Jan 07, 2013 | Microsoft Comfort Curve 2000 Keyboard
Why would CNTRL-ALT-DELETE not work when I need to lock my computer? Where is the Num Lock located on this keyboard?
Num lock is located juz above the 7 num key on the num keypad. Try using control alt del key on another system and check if it works or not.
Aug 25, 2011 | Logitech MX 5500 Revolution Keyboard
My number pad won`t work on my keyboard
Hi there!
Make sure that the num lock light indicator is on otherwise press Num Lock.
If it still fails, I believe you have a defective keyboard. If it is under the warranty, call the manufacturer's support.
Hope this helps!
May 08, 2010 | Logitech 967437-0403 Keyboard
Old keyboard still connected note worthy keyboard
when you start computer just press del and go to cmos bios setup and set usb keyboard setup enabled and save the setting.
Sep 08, 2009 | Targus Noteworthy Multimedia Keyboard...
Dell Keyboar Problem -
This likely is one of two issues. A BIOS setting, and can be changed in the BIOS setup utility accessible at startup.
Or ...
If you are sure you have no computer virus or a hardware conflict than you can modify this setting by editing the registry on the computer. Normally, the computer applies the user settings when the user logs on, but it uses the default user profile when it is first turned on, before the user has logged on. To turn this functionality off, the default user settings must be modified. The Keyboard entry contains user preferences as defined by choosing the Keyboard icon in Control Panel. Entries are found under this registry path:
HKEY_USERS\.DEFAULT\Control Panel\Keyboard
InitialKeyboardIndicators REG_SZ Number set it default to 0.
If not:
* Run the Registry Editor (REGEDIT.EXE).
* Open HKEY_CURRENT_USER\Control Panel\Keyboard (If the Keyboard key isn't there, add it.)
* Double-click the InitialKeyboardIndicators value on the right. (If it's not there, select New from the Edit menu, then String Value, and type InitialKeyboardIndicators for the name of the new value.)
* Change the value to any of the following:
0 - all indicators off
1 - Caps Lock on
2 - Num Lock on
4 - Scroll Lock on
Or, combine them by adding the corresponding values:
3 - Caps Lock and Num Lock on
5 - Caps Lock and Scroll Lock on
6 - Num Lock and Scroll Lock on
7 - Caps Lock, Num Lock, and Scroll Lock on
* Close the Registry Editor when you're done.
All the change should take effect when next time you start Windows.
Aug 28, 2009 | Dell 0Y3740 Keyboard
Microsoft wireless keyboard stopped working
There are a couple ways to fix the num lock problem. The first is to enter the BIOS setup when you first turn on your PC. The second involves a registry edit. Neither is difficult to do, but if not done correctly can cause serious damage to your PC.
If you feel confidant we can assist with this.
Mar 14, 2009 | Microsoft Wireless Laser Desktop 3000
Dell keyboard SK-8115
(That is the the Num Lock indicator, nothing to worry about.) If it is not working it is likely because USB keyboards can time some time to be recognized by windows, let the computer boot up with the keyboard connected and let sit for up to ten minutes.
Sometimes if other hardware is detected at the same time which requires drivers to be installed, windows will never proceed to installing your keyboard, however you cannot install the other drivers until you have a working keyboard. To solve this, you will need to use an older style PS/2 keyboard to get everything installed and working as they do not need to be detected.
Nov 11, 2008 | Dell Spacesaver USB Keyboard J4624 SK-8115...
My new logitech keybord
The "A" signifies it as a capital key
The 1 signifies it as a number key
Being a cheaper model it does not have that feature.
Did it come with an installation disk?
Maybe when you install it the cap lock and number lock will be on the computer screen in the system tray.
Some do that.
If not you may want to take it back and get a more expensive one. One, that has the features you like.
Oct 23, 2007 | Logitech Wireless Access Duo Optical...
How do I unlock the keyboard
Hi There If youyr lights above the Num Lock Button are on then i would serggest you try unplugging your key board and restsrting your PC when the PC pings the replace your keyboard and check that the lights are working by pressing the Num Lock Button this should let you use the numbers hope this works Paddy
Oct 06, 2007 | Logitech Cordless iTouch Keyboard/Cordless...
Logitech Deluxe Access Keyboard Logo
Top Logitech Keyboards & Mice Experts
micky dee
Are you a Logitech Keyboard and Mice Expert? Answer questions, earn points and help others
