Kenwood KAC-9152D Car Audio Amplifier
Problem for Kenwood KAC-9152D Car Audio Amplifier
Subs going off and on
By kraken873 on Oct 13, 2009
the red triangle will go out when i turn up my subs and I think it may have something to do with the battery. when ever they hit a certain intensity, they stop and go off and on, but the blue light never goes out.
Comments:
Oct 13, 2009
- i have around 3 to 4 gauge power wire and a 3 guage ground. I have never had a problem with them for a year up until now. All of the sudden they started doing this, so first thing i thought was check the fuses. I did that, they appeared to be fine. i changed the conection terminals and that worked for like a few days, and now its back tot he same thing. The red triangle will go out when the subs do, but the blue light still remains on. I just wish i knew what the triangle means. the amp is not bridged and Im only using two 12inch alpines that have worked flawlessly with the settings i normally have them on. up until now of coarse. I guess I can recheck the ground lead and make sure it is on paintless metal, I have a theory that the speaker wires have been changed, ive seen cases where the actuall wires for them from the terminal to the magnet melt off. Ill post my findings, but i hope this helps you out enough.
Clarification Request
Posted by smarthome2 on Oct 13, 2009
What gauge power wire? what gauge ground? where is it grounded? Power directly to battery? is the amp Bridged? what impedance are the sub(s)? single voice coil sub? dual voice coil?. Post a comment with the answers and I can help you figure this out. Without all the info, I'm just throwing darts at a board.
Solution #1
posted on Oct 13, 2009
Not Rated)
kprastik
Rank: Apprentice
Rating: 88%, 2 votes
The problem you are describing could be caused by numerous problems.
I think you might be on the right track by starting to look at power issues.
First be sure that your battery terminals are clean and connected to your battery tightly. Make sure that you have a good battery by having it checked out by your local autoparts store who will usually check it for free.
The amp needs to have the proper size wire between the battery and the amp, fused at the battery and the amp according the mfg specifications.
Just as important as the positive battery wire from the amp, be sure that the ground from the amp is secured to a solid paint free metal that is commonly grounded to the negative side of the battery. I am assuming that you do not have and old vw, positivly grounded car or some other weird car.
If the power checks out with the battery, make sure that your car's charging system is up to par. If your stereo is requiring a lot of power, you may need to upgrade your cars charging system.
Another cause of the amp going on and off would be the use of too many speakers or blown speakers. You need to check the mfg specifications for the amp to ensure that you are not overloading it.
Was this helpful?
Yes
No
Popular Solutions for Kenwood KAC-9152D Car Audio
Questions and Unsolved Problems for Kenwood KAC-9152D Car Audio
Do you recommend Kenwood KAC-9152D Car Audio Amplifier?
Answer
Answer
The hot water stopped filling about a month ago. just all of a sudden as if only a tiniest pin *****... (More)
Answer
how many wats is my amp., and is it bridgeable?
Answer
my amp keeps going into power saving mode it gets 12v at the power cable and also gets an earth when... (More)
Answer
sry i have a 2000 watt amp legacy
Describe your Car Amplifiers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Car Amplifier Experts
Top Audio & Video Equipment Repairmen
in , NV
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
(785) 842-6626
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
