Thats an exposure lamp error. Either your lamp is blown, a thermal fuse is blown, the shading plate and optics are very dirty, or you have a bad circuit board. Make sure you unlug it if you plan to poke around in the optics section.
Was this helpful?
Yes
No
Popular Solutions for Kyocera Copystar CS-1620 Black
check to see if the fuser is working yu should be able to tell if you open the side door up at the...
(More)
check to see if the fuser is working yu should be able to tell if you open the side door up at the top you will see the fuser orange roller and black.. feel to see of it has gotten hot be careful though it does get upto 180c.. if this is ok then check the toner is set right as it may be trying to load did you give the toner cartridge a shake before you put it in this can sometimes be compacted.. good luck A
I need to unlock my cell phone so I can get service through my curent provider.It use to be hooked...
(More)
I need to unlock my cell phone so I can get service through my curent provider.It use to be hooked up to inland cellular and I want to hook it up to my at&t provider. Can you please help me? Thank you!
