Question about Black & Decker CTO649 Toaster Oven with Convection Cooking
Top element not heating
I have this toaster oven and love it. Today i went to use it to make toast and it only toasted the bottom. I tried to broil and the upper element doesn't heat up. I've only had it about 9 months, can I fix it or what?
  • 4 more comments
  • Anonymous Jan 20, 2008
    checked the top elements...continuity and resistance is OK, but they do not heat up. Has to be a minor defect with some relay points. I do not have a schematic to trouble shoot. Any ideas?
    Thank you.
  • jtwat Feb 21, 2008
    Same problem as others, top element will no longer work on any position.
  • Anonymous Jun 17, 2008
    one element not working
  • pacifst May 11, 2010
    this solved my problem but it was really hard taking off the side pannel..... also the wire just needs to be touching the metal peice on the upper front (should be obvious) I did not have ot deal with the resistor/spring in the tube.
  • Anonymous Mar 27, 2014
    the element sparked and burned (melted?) at one spot
    can it be fixed? threw the box away
I found that the heating element in the top front was burned off at the end. I removed the side cover and the ceramic insulator from the broken end. I then grabbed the broken end of the spring inside the glass tube and stretched it to where I could re-attach it to the connector. It now works after getting it back together.
If you attempt this repair, UNPLUG THE OVEN FIRST!
There is also a security screw at the bottom of the side cover.
Posted on Feb 26, 2008
Black & Decker CTO650 Toast-R-Oven Countertop Oven/Broiler Toaster Oven stainless steel gets a bit warm on top, but the blue light and elements do not get hot? Is it the hear sensor, where is it located? Thanks
Posted on Apr 04, 2012
Why won't my calphalon toaster oven toast top of bread? Why?
If both the top and bottom elements are working then you may need to re-position the rack closer to the top element for even toasting. If there is only one rack position available then you may need to flip the bread and toast it twice.
Oct 06, 2014 | Toaster Ovens
Black & Decker Toaster Oven - elements cycle on and off, which makes for a SLOW cook.
Oven has three modes: 1) oven mode cycles elements on and off to maintain a specific temp setting for up to 60 min. 2) toast should keep all elements on for a few min. 3) broil mode top elements only always on, up to 60 min. Make sure you have dials in correct position and use the toast timer.
Apr 17, 2014 | Toaster Ovens
I have a Black & Decker Toaster Oven Plus. The only number I could see was, toaster listed 228E. It bakes, and toasts only the underside of bread. It no longer broils. Do I need to replace the top element,...
Mine has The same problem and I am trying to fix it I don't see anything burnt and everything seems to be put together and write and I can't understand why the top bars would not heat up,I need help to prepare this thing I love it so much
Aug 13, 2013 | Black & Decker Toaster Ovens
This toaster no longer toasts food evenly, it takes twice as long, it appears that the broiling coil element may not be heating...Can these elements be replaced?
the elements can be replace, BUT, it is just not cost effective. you can buy a new toaster for less the the cost of repair.
Jan 03, 2011 | Cuisinart Toaster Ovens
Burnt pie
YES YOU ARE your trying to bake something in a toaster oven :) toaster ovens have two modes toast /bake in this mode top and bottom elements get hot .and broil in this mode only the top elements get hot . the problem is the marketing the word OVEN makes you think of a normal oven that the bottom elements do all the work . toaster ovens work well melting stuff and toasting . thats about it . if you must bake in it try placeing a sheet of foil on top of your baked goods it might insulate the top of you food . good luck ... if this answer helped please rate it a 3 or 4 stars , this high rateing will help keep me in the paid answer department , thank you
Apr 13, 2009 | Toaster Ovens
Top element broken
Oster 6233 toaster oven top heating elements don't work
Nov 11, 2008 | Toaster Ovens
Toaster does not work!!!
I investigated further (took it apart again to satisfy my curiosity) and it appears that one of the top heating elements (the front one) is open (burnt out). I cannot see an easy way to replace it (contacts are spot welded) and I can't find a place to buy the element. If I could it probably won't be worth it since a new oven costs $25 at Target (B&D TR0490W). Too bad since the oven looks like new. I assume the upper elements burn out more frequently because heat rises from the lower elements and adds extra heat at the top.
Jul 02, 2008 | Black & Decker TRO360 Toast-R-Oven Toaster...
Black & decker toster oven
Black and Decker Toast-R-Oven Countertop Oven/Broiler Mfg Part No: CTO650
same problem here, toaster works, then when I go turn on the oven ........nothing!
Oct 29, 2007 | Black & Decker CTO649 Toaster Oven with...
Black & Decker CTO649 Toaster Oven with Convection Cooking Logo
2,029 people viewed this question
Top Black & Decker Toaster Ovens Experts
Shehu Pro
Shehu Pro
Are you a Black & Decker Toaster Oven Expert? Answer questions, earn points and help others
