Question about Nintendo Game Boy Advance Console
No sound on PS2
We have picture put no sound on our PS2.  What could be the problem?  Is there a sound menu that could have been turned off?
Have the same problem, no sound but picture, have the dish satilite, surround sound, tried the configuration you suggested going thru VCR. Thanks, MikeWhat am I doing wrong? Model# PS SCPH-79001 Sony.
mkozlosky@sbcglobal.net
  • 106 Answers
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
asd-56
Posted on Jul 23, 2009
  • 35 Answers
Maybe you have the audio and video cables mixed up?
Posted on Dec 26, 2007
I have a ps2 with sound but no picture how do i fix that
Does it display "no signal"? or can you feel a change in the black screen when u turn on the machine?
1- Check that the cables are plugged correctly, from what I remember I used to experience the same problem when the AV cable is half plugged into the PS2.
2- Make sure that your region (NTSC or PAL) is the correct one in your TV. That is by going to MENU, then Color settings.
Mar 13, 2011 | Sony PlayStation 2 (PS2) Console
I have picture, but NO SOUND???
Hows the PS2 hooked up ? RCA cables? Make sure you have the red and white cables plugged in as well as the yellow.
May 31, 2009 | LG 42PX3RV 42 in. EDTV-Ready Plasma...
Playstation 2 will load the game, but then only show black screen
You might of had one of the wires connected from the TV to the PS2 damaged and may need new ones or just make sure that the wires connecting each other from the TV to the PS2 are well connected. My little brother use to drop my PS2 a lot too and that happened to me once, but it turned out to only be that the wire got pulled too much when it fell and it disconnected from the TV to the PS2 and I had to only put it in well.
Apr 07, 2009 | Sony PlayStation 2 (PS2) Console
Sound but no picture on PS3 using AV3/4
if it's happening with your ps2 and your ps3 on teh same tv, try it on a different tv. if you're getting sound but no picture, tehn it's something with your cables or your tv. restting the display setting should get your picture back up. make sure the system is in standby and then hold down teh power button. it will turn green and beep, then flash green and beep again. it should brng up a picture. if not, check your component cables, especailly if it works with the original cables.
Apr 06, 2009 | Sony PlayStation 3 40GB System
Ps2 to lcd tele set up problem
Look at the menu settings on your TV. Some TVs you can set the video to come in through AV (the red,yellow and white), and the sound come in through something else, like HDMI. You need to make sure the TV is set up to where all are on the same setting.
If that doesn't work, I would check and see if your AV cables from your PS2 work on another TV. That way you can rule out whether the problem is the TV or the cable itself.
Feb 16, 2009 | Sony PlayStation 2 (PS2) Console
We just purchased Guitar Hero and when we put it in our PS2 it dont spin the disk??
Here's what I did to fix the same problem on my PS2 (Slim model # SCPH-70012). This should work for all models of PS2's. (Slim or Fat). Sony says all models can read a dual layer disc. If the fix doens't work then you need to send in your PS2 for service.
1) Start up the PS2 with no disc in it.
2) Highlight the 'Browser' menu and press the 'green triangle' button.
3) Highlight the 'Console' menu and press the 'green triangle' button.
4) Highlight the Diagnostics menu and press the 'blue X' button and select 'ON'.
5) Press the 'red O' button to back out of this menu.
6) Highlight the 'PlaystationDrive' menu and press the 'green triangle' button.
7) Highlight the 'Disc Speed' menu and press the 'blue X' button and select 'FAST'.
8) Press the 'red O' button to back out of this menu.
9) Turn off your PS2.
10) This step is optional.......I blew into the main unit to loosen any dust out of it and then carefully used my shirt to wipe across the lens at the back of the drive. I'm not sure if this mattered or not. Since I did this in conjuction with the above steps I can't say if this is needed.
11) Insert the disc and turn the PS2 back on. The diagnostics should run and automatically adjust your PS2 to play the game. I was amazed! Mine loaded right up after several previous days of nothing.
12) I checked the settings after the initial load and the Diagnostics and Drive speed reset to normal so it must be a one time run thing. My game has loaded everytime since and I haven't had to re-do the settings at all.
I hope this works for you too!!
Dec 30, 2008 | Sony PlayStation 2 (PS2) Console
Sony T240HD monitor TV
make sure that the plug on ps2 is connected and check the settings on tv and the settings on ps2 browser are correct if possible check ps2 on another tv to be sure of it's settings if the ps2 works the check channel setting on tv make sure it's not in pal setting it should be ntsc and also check the antenna setting make sure it might be set to cable and also check cables of any sharp kinks your problem is with the yellow cable red and white is the sound
Dec 01, 2008 | Samsung T240HD 24 in. LCD TV
Disk error
This happens often when your lens are in poor condition:
these are some actions that trigger this problem
1. If you played your PS2 without any rest for more than 3-4 hours
2. You didn't clean the lens at least twice a year (excluding PS2 slim)
3. Your PS2 fell on the ground
and these are some solutions:
1. Check your lens, it might be dirty or broken
2. Check the parts of your PS2, some parts might be damaged
3. Try a clean disc
i hope this helps
Aug 03, 2008 | Sony PlayStation 2 (PS2) Console
PS2 Picture Problem
Hi MG86,
Most PS2 games are dark and auto brightness controls will casue your LCD tv to brighten up automatically in response the dark video coming from PS2 games. I suggest you get into the menu settings of your TV and find a setting that will shut off the auto picture controls.
Nov 23, 2007 | Sony PlayStation 2 (PS2) Console
No sound on PS2
check the audio cord. and when the game is on go to options and make the volume fulllllll.
Oct 21, 2007 | Sony PlayStation 2 Slimline Console
Nintendo Game Boy Advance Console Logo
146 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
