Question about RCA F31672ET TV
Input/Output Wii System
Need toconnect it to this tv but unable to because i do not have the original remote.
Help need to get Wii off of the main tv and onto the children's playroom tv.
  • sharon wallace Dec 27, 2007
    I have a universal remote..will that work?
  • jessieandben Apr 05, 2009
    I bought an Xbox and it worked fine with the TV but then it just stoped. The remote won't work so I cant use the tv/video button onthe remote and I cant figure out how to change it with the menu button on the TV. I doubt they still make these TV's and remotes to go with it but I'd rather solve my problem then buy a new TV. Does anyone know how to fix it or do I need a new TV because the remote is acting screwy?
  • 35 Answers
Do you need the remote, or do you have the menu button on the tv? if you dont have neither, then you could try to get a new remote.. hope it helps!
Posted on Dec 26, 2007
  • Nicola Saya Dec 27, 2007
    it might work, but it depends on what type of tv you have.
How do I fix Magnavox HDTV stuck in av after use of Wii?
If the Wii is not used, and if some other source is used, does the set still stay stuck??? If it stays stuck with the Wii connected, but not with some other device, then the fault is with the Wii and not the TV. Maybe there is something in the characteristics with the Wii output that is the cause...
If that input stays stuck with any source, when I used to do TV service there were a number of things that caused this. I had to sometimes change the input control IC (input matrix IC), and or, one or a few of the components associated with this IC. These components were identified by following the digital control signal paths with a digital scope and volt meter and using the schematic diagram as reference. Sometimes I found the main uPC (micro-controller) in the TV set was the cause because it was not properly sending the command for the input change.
The most basic thing you can check is if the remote is sending the proper remote command signal to the set. If you do not have a remote control signal analyzer you can try another remote such a universal remote control to compare.
May 01, 2014 | Sanyo DS31590 31" TV
Unable to access Front Input Connectors
If you tell me where you are located I will try to find a seller for your remote. Is the TV a 27F520T 27'' truflat?
Feb 17, 2008 | RCA TruFlat 27F520T 27" TV
I have a panasonic 1080p hd tv, a samsung dvd/vcr,nintendo wii and a bt vision + box, how do I connect the nintendo wii?
if your dvd vcr has an rca input and output try going into it with the wii and out to the tv. Unfortunately mine does not have input only output and I have to swap the rca plugs on the back of the tv. If you still need help I would need to know all the connection types you have on each product to set up a pattern.
Nov 22, 2011 | Nintendo Wii Console
No game system listed in the select key option
Some tv's (RCA) you can hit 00 on the remote and get into the aux. input menue. The wii will be a composite input source.
Dec 25, 2009 | Nintendo Wii Console
I have an old emerson tv with only 2 inputs (yellow & white) and I connect to the wii, but am not sure how to have the tv recognize the wii. What channel or how to set it up. please help
If you have the original TV remote there should be a button that has Input or I Select or something similar. You need to press that button when you have the Wii turned on to find the right input it is connected to. There more than likely L1 L2 AV1 or AV2 or Front AV or something similar that your Wii is connected to. Or sometimes just going Channel Down past channel 3 will get you to one of the inputs I mentioned.
Dec 05, 2009 | Emerson EWF2703 27" TV
I plugged the red,white, yellow audio/video cables into the front jacks on my Sony Vega. They are marked input 2. When I turn the TV to all inputs, including input 2, I just get the black screen. When I...
Sounds like you have the Wii hooked up properly. I would suggest trying the other inputs on the TV just to be sure input 2 isn't faulty.
After trying the other inputs if the Wii still won't show any video then try another set of cables and after that if the video can't come up then the Output from the Wii is bad and the main board would have to be replaced.
Dec 02, 2009 | Nintendo Wii Console
Input select sttting
Normally, your TV or VCR is probably set to display the television channels you watch, through a standard cable input. In order to play your Nintendo using the A/V cables, we need to tell your TV or VCR to switch from the normal tv channels, and instead display the signal coming in from the A/V cables of your Nintendo system. There is no one particular way to do this, as it varies between brands, but below is some information that may help.
Quick Tip: Grab the original remote control for the TV or VCR you have plugged your Nintendo into, and look for a button that could be labeled:
  • TV/Video
  • Input Select
  • Line or Line In
  • Source
  • AUX (auxiliary)
  • EXT (external)
  • any other button that seems to indicate it would switch between the TV signal and the game system.
If the above tips did not help, it is possible your Input Select is a little more difficult to locate. Here are some other common ways to access an Input Select:
  • A button on the front of your TV or VCR located behind a door or a hidden panel, or located on the original remote control that came with the device. If you are using a universal remote, it may not work when pressing the "input select" button. If it does not work, try to locate the original remote.
  • A high or low end channel. Try channel surfing through every channel, even the ones that do not normally broadcast a TV show. Many times the input select is a high channel such as 90, 91, 92, 93, 99, or even 999. You should also try low channels such as 0, 00,001, 1 or even 2. For some televisions, you may need to manually select these channels by using the keypad on the TV or remote control.
  • Found within an on-screen menu. Search the menu for words such as Input, Setup or Source. Select one of these words, and another menu will usually appear that asks you to select between TV and either AV, AUX or Line. Select AV, AUX or Line to display the Nintendo game.
If you are still unable to find your input select, you may want to consult the operation manual that came with your TV or VCR, or contact the manufacturer directly.
Nov 19, 2009 | Nintendo Wii Console
Need help setting wii remotes. both remotes where reset with another wii system and now want to use original wii system and unable to change setting on wii with no active remote?
on the wiil system tere is a small red sycronize button. press this button. then a screen will appeard indicating for you to properly sync your will remotes. press 1 and 2 simotaniously then they will work properly
Oct 22, 2009 | Nintendo Wii Console
Can hook up my wii to this tv
The AV Multi Out plug that is included with the Wii will allow you to connect the console to most televisions or video cassette recorders (VCR). First, look at the back of your television AND your VCR and see if you have colored holes label "Input". Though most TVs have them, almost all VCRs do as well.
  • Audio/Video (AV) inputs are located on the front or back of the TV or VCR.
  • They are smooth silver posts with the inside showing a color, usually red, white and yellow.
  • Look for inputs marked Audio and Video IN.
  • The image on the left features stereo audio inputs. Some televisions have only one audio input. Click here for help setting up a mono audio connection.
  • Do NOT connect your system to anything marked OUT.
Where do you have these inputs?
Additional Options:
Connecting to a Television
  1. Insert the AV Multi Out plug on the Wii AV Cable into the AV Multi Out connector on the back of the console. setuptvav.gif
  2. Insert the RCA plugs on the Wii AV Cable into the input connectors on the TV. Plug the colored connectors into the following inputs:
    Yellow = Video Input
    White = Audio Input Left (or Mono)
    Red = Audio Input Right
    Interested in playing your games in Dolby Pro Logic II (simulated surround sound)? Click here setup information.
  3. Once the cables are inserted and the Wii is powered on, you must find the Input Select for your TV to view the game (it is likely not going to be seen on Channel 3 or 4). Typically this is found by pressing the TV/Video button on the Television's front panel or remote control. If you have more than one input channel, keep pressing TV/Video until you see the display from the Wii.
    If you do not have a TV/Video button, then the input could be labeled something different. Some other common input selects to look for on the TV or remote are: Input, Input Select, EXT, AUX, or a channel such as 00 or 99.
    Still can't find it? We have compiled a list of known input selects for many popular brands. Click here to see our list.
    Go to Next Step (Set Up of the Wii Remote) >
Connecting to a VCR, DVD-R, Cable Box, etc.
    In order to connect a video game system through a device such as a VCR, DVR, cable or satelite box, it must have Video and Audio "inputs." While most VCRs and VCR/DVD combos have these inputs, other devices typically have "Outputs" which will not work for playing your Wii console. Please verify the device you are attempting to use has these holes.
    While many cable/satelite boxes and DVRs may have "inputs," accessing them can be difficult. Please consult the instruction manual for the device you are connecting to, for more information.
  1. Insert the AV Multi Out plug on the Wii AV Cable into the AV Multi Out connector on the back of the console. setupvcrav.gif
  2. Insert the RCA plugs on the Wii AV Cable into the input connectors on the VCR. Make sure you are plugging the connectors into the holes labeled"Input" or "In". Holes labeled"Output" or "Out" will not work. Plug the colored connectors into the following inputs:
  3. Once the cables are inserted and the Wii is powered on, put your TV on the channel you use to watch movies (usually channel 3 or 4). Put in a video tape and play the movie. When you see the movie playing, press stop (do not power off the VCR!) and proceed to the next step.
  4. You will now need to find the Input Select for your VCR. This is usually a button on the original remote control that is labeled Input Select, AUX, Input, EXT, Line In, or a high or low channel. For more information on locating your input select, click here.
Nov 26, 2008 | Video Game Consoles & Games
Televison & Video Logo
353 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
