Hello, All of a sudden my kitchen ceiling lights are acting flakey...here is the problem. There are two ceiling fixtures, both of them were controlled by two separate on/off switches on opposite ends of the room...Now, one is a flouresent tube light (I think) in the kitchen, the other is a chandelier which takes standard bulbs. Now, the thing is flaking out...The switches don't work, or if I get the thing to work, a single switch will turn ON one of the lights (chandelier) , and when I flick the switch to the other position, it turns OFF the chandelier, and then turns ON the kitchen fixture. It was working fine and all of sudden is flaking out....What is the issue? Do I need to call an electrican or replace some tubes?PS This is Not a ceiling fan, could not find a category for my problem.
I would suggest you call in an Electrician. It sounds like there is a definate short somewhere and if you don't address the issue immediately, there could be a very real issue of a fire. Please do not put this off as something that may fix it's self. hope this helps.
Was this helpful?
Yes
No
Popular Solutions for Hunter 52" Ceiling Fan With
Hunter 52" Ceiling Fan With Light And Remote Control
I have a Hunter fan that no longer responds to the remote. The fan part works, but the lights don't....
(More)
I have a Hunter fan that no longer responds to the remote. The fan part works, but the lights don't. I replaced the battery but no luck. Fan is Cat # 85206-30 Remote Part # 85095-01. The fan was installed about 5 yrs ago. Has worked OK until this problem.
I installed a hunter dual dimmer switch. It controls two different fans / lights. When wired, the...
(More)
I installed a hunter dual dimmer switch. It controls two different fans / lights. When wired, the lights will only come on and dim properly only if the fan is on "high". As soon as we lower the fan speed to anything other than high, the lights go completely off. Note- We do have a 12-3 wire arrangement, so the fans are on the black wire and the light kit on the red wire. Any thoughts?
